Question about Nokia X3 Cell Phone
I had got a service message and when i tried to delete that message the software became corrupted and i had to install new software . now i need my contacts back please help .
    New Friend:
  • 92 Answers
I think you cannot restore your contacts. It is better to contact a service center.
Posted on Nov 16, 2010
Email Services - Recent Questions, Troubleshooting & Support
Error messages are quite common while working with MS Outlook email client. This error appears in case if the Outlook profile is corrupted or Outlook folders are moved across drives. For resolving this issue i can recommend this app
https://www.pstrecoverykit.com/
Best Regards.
Nov 07, 2016 | Computers & Internet
Why can't I get into my Asus K53U laptop?
This sometimes happens with Windows installations - your user profile gets deleted or corrupted and this error message results. If you aren't into heavy computer software fixes, I would take it to a computer-savy friend, or a computer service provider. Here is one set of instructions to try and remedy the problem. You receive The User Profile Service failed the logon error message
Sep 04, 2014 | ASUS Computers & Internet
Supporting software became delete, became message delete
Hi there.
You need to do a deep reset by using the *#7370# sequence. This will completely format phone memory. Default files are cleaned up and rewritten.
Hope this helps! Cheers!
Jun 18, 2011 | Nokia 3110 Cellular Phone
EVERYTIME I TRY TO OPEN PHOTO EXPLOSION LATELY I RECEIVE THIS MESSAGE.....ENCOUNTERED A PROBLEM AND NEEDS TO CLOSE. WHAT CAN I DO.
This problem can occur for any software not only this. It can be due to file corruption.
Once the files are corrupted or deleted from your PC or Laptop then the particular software wont be able to run properly and while running the program it show error message.
So a solution to this is re-installing the software ..That will help you. If there are some saved files then before re installing try to back up ..
Thanks..
May 20, 2011 | Nova Development Photo Explosion Deluxe...
Cannot detlete corrupted printer software
That is correct, it was not installed correctly. Try running setup and choosing FULL and if you get a note that says "Has already been installed" then look for an option to 'reinstall anyway' If that should fail, contact Dell.
Aug 28, 2009 | Microsoft WINDOWS XP PROFESSIONAL SP3...
Cannot install yahoo toolbar on firefox.....
this error message can be caused by either:
  • corrupted configuration files on your computer.
  • security software, which may be preventing these files from being updated
try this
Corrupt extension configuration files can cause problems when trying to install an extension. Deleting these files will make Firefox recreate them (removing any corruption) the next time it starts. You won't lose your extensions or their settings by deleting these files.
  1. From the menu at the top of the Firefox windowbar, select FileFirefox and then select the ExitQuit FirefoxQuit menu item.
  2. Go to your profile folder.
  3. Delete the following files:
    • extensions.ini
    • extensions.cache
    • extensions.rdf
  4. Restart Firefox.
Apr 04, 2009 | Computers & Internet
Entourage crashes when I try to delete "sent messages"
If you suspect that something is corrupted at the end of the message, you might need to recreate the messsage. if you're sending a message with an attachment, the attachment might be too large. Try sending the message by deleting the images on your signature.
Hope this helps!
Cheer!
Jan 10, 2009 | Microsoft Entourage For Mac for Mac
The contents of this file cannot be unpacked.The executable you are attempting to run has been corrupted.
When I try to install the software, I get an error message. The installation just quits. trnsp.gif Answer An installation error is defined as any issue or error that prevents the Setup program from fully completing the task. Installation errors can manifest themselves in several different ways. One common installation problem is the Setup program is interrupted with a message indicating some type of problem. Another type of installation error is when the Setup program simply disappears or doesn't complete for any reason. When Setup is interrupted with an error
Many installation issues will be accompanied with an error code and then an error message that identifies the problem. Because the camera software uses the Windows Installer, the exact definition of the problem can be obtained by looking up the error code on Microsoft's website. Two common errors are Error 1904 and Error 2711.
When Setup simply disappears or doesn't complete
Note: When installing software, administrative rights are needed to install all the files for camera software. If you are logged in as another user without administrative rights, the software may not install/function correctly.
First try booting clean. If you are using Windows XP, Windows Me, or Windows 98, click here for instructions on booting clean. If you are using Windows 2000, click here for instructions on booting clean. Once you have booted clean, then try to install the camera software.
Since booting Windows clean may disable CD-ROM support, we recommend you download the latest camera software for your camera and use the download file to install after you have booted clean.
All other installation issues
If you are unable to find a solution to the installation issue given the above information, please try the following suggestions. After each suggestion, try running the installation program again.
  1. Reinstall the Windows Installer. This Windows Installer engine can be downloaded from http://www.microsoft.com/downloads/release.asp?ReleaseID=17343
  2. Windows 2000 Only. Stop the Windows Installer service and reboot the machine. To do this:
    1. Right-click on My Computer
    2. Choose Manage
    3. Click on the plus (+) sign next to Services and Applications
    4. Click on Services
    5. On the right side on the pane, double-click on Window Installer
    6. Choose STOP
    7. Reboot the computer.
If the service was already stopped, try starting the service, then stopping the service and rebooting.
If following through on the specific instructions above do not resolve the issue, please try the following standard diagnostics:
  1. Try a different installation media. For example, if you are attempting to install the camera software via the CD, download and install the latest web release. If you are trying to install the web release, try the camera software CD. Please note, the latest software can be downloaded here.
  2. Run ScanDisk and Disk Defragmenter. Both of these utilities can be found in the Accessories program group of the Windows Start Menu.
  3. Search for and delete all TMP or CHK files.
    For Windows 98 and Windows Me Users:
    1. Click on "Start", "Find" and choose "Files or Folders".
    2. In the Named field, type *.TMP and click "Find Now"; delete all files found.
    3. Repeat this procedure with *.CHK.
    For Windows 2000 Users:
    1. Click "Start", "Search" and choose "For files or folders".
    2. In the Search field, type *.TMP and click "Search Now"; delete all files found.
    For Windows XP Users:
    1. Click "Start", "Search".
    2. In the "All or part of the file name" field, type *.TMP and click "Search;" delete all files found.
  4. Empty the TEMP directory; this folder may contain files that are interfering with the installation. To do this, use the following steps:
    1. Right-click on My Computer and choose Explore.
    2. Click on the plus (+) sign next to the C drive.
    3. Click on the plus (+) sign next to the Windows directory. (For Windows 2000, it is the WINNT directory.)
    4. Click on the plus (+) sign next to the Temp directory. The right side of Explorer will display the contents. Select all the files listed in the Temp folder and delete them.
  5. Reboot the system and try installing the software again.
Jan 21, 2008 | Logitech QuickCam Express Web Camera
Nokia X3 Cell Phone Logo
42 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
