Question about Gateway 510 X (10272197) PC Desktop
The computer will turn on with the start button but will only start up with the rest button how do I fix this
  • Gateway Master
  • 11,800 Answers
I'm sorry to tell you but your motherboard is dying - you should replace it as soon as possible otherwise when it will fail it will fry everything else that's attached to it and you'll lose all your data. For that you have 2 options: either you buy yourself a similar board online (you are not going to find a new one - the pc is too old) and replace it yourself or you take the pc to an authorized Gateway repair shop - that will cost a lot more than the first option but is going to be hassle free.
Or you could just buy a new pc.
Posted on Nov 15, 2010
Have 2003 gmc envoy everything works but won't start
Reset your fuel pump rest button is in your owner guide or call service dept they know the rest button location quick and easy fix hope it helps
Jul 24, 2015 | GMC Cars & Trucks
To shut down computer i have to keep power button pressed
use the start menu, click it to open it, you will see shut down button there, if you rest your curser on it it will give you different options
Mar 07, 2013 | Computers & Internet
Won't stop cycling through brightness settings
sounds like it might need a cleaning. are the buttons hard to push or are any of them giving you a different feeling then the rest?
Aug 13, 2017 | Samsung SyncMaster 2233SW Monitor
Mac won't turn on
Plug the laptop into the wall with the included charger. If that does not fix the problem, check that the battery is properly installed- it should be flush with the rest of the computer and locked in place.
Oct 14, 2012 | Apple MacBook Pro Notebook
Should I replace Monitor?
Your monitor is telling you that it is time for you to replace it. Your monitor is going bad on you and will only get worse.
Mar 26, 2012 | Computers & Internet
Maintenance Required light on after dead battery
No its easy . here are the steps turn ignition to acc/ first turn hold reset button located next to odometer rest button. Hold this button for 30 seconds. then turn ignition to next turn/click where lights come on on the dash ex brake air bag etc. hold for another 30 seconds. The maintenance light should flash and go out start vehicle and your maintenance is done. Good luck ad thanks for using FIX YA
Mar 13, 2009 | 2002 Honda CR-V
Maint. Required Lght on
Use the procedure:
1- turn off the engine.
2- press and hold the select/Reset button on the instrument panel, then
turn on the ignition switch ON (II)
3- Hold the button for approximately ten seconds until the indicator resets
Dec 18, 2008 | 2005 Honda Pilot
Computer keeps shutting off
The problem more likely seems with the power supply or the front power button. Donnot try switch on the computer again and again it may cause damage to the motherboard. Use the following link to pin point the problem.
http://tinyurl.com/5bbrxc
Thanks
Proton
Do remmber to rate the solution if it was helpful or fixed your problem.Thanks for using fixya
Jul 05, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Hp nx7010 not starting
hi
it is mother board problem replace it it will help full to you.
by by.
Nov 18, 2007 | Compaq Presario 700 470024-192 Notebook
Gateway 510 X (10272197) PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
