Question about Whirlpool Refrigerators
Whirlpool Gold GB22DK.... freezer works fine, is keeping everything cold, yesterday noticed fridge isn't getting cold, even though I have it on the highest setting. What could be the problem and how and what do I check to try to solve the problem?
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 15, 2010
Why is my fridge warm
There is a fan and a damper the blows cold air from freezer to refrigerator compartment. Damper is stuck closed or fan is not working is a good starting point.
May 07, 2017 | Whirlpool Refrigerators
Whirlpool gold conquest, freezer working fine, fridge warm.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 05, 2011 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
I have a Whirlpool Gold refrigerator, model GB9SHDXP, about 2 and a half years old. It has a bottom freezer. Yesterday I noticed that the food in the top part were not as cold as usual. I came back...
ok,when you open the freezer door do you hear the fan blowing?all that happens is the freezer gets cold,a fan in the back wall of the freezer turns on and blows cold air up into the fridge section,a thermostat tells it when it's cold enough or it's getting warm then it will blow more air up top,if the freezer is working correctly then either the fan isn't working or the bottom freezer door was left open,warm air got sucked up into the air vents causing water droplets to be formed,then they freeze blocking the air vents with ice and now the cold air can't go into the fridge section.is there any ice on the ceiling of the freezer or frozen water droplets on the bags in the freezer?if so the door was left open.unplug the maction,and with a hair dryer blow the hot air into the holes on the back panel,keep doing this until you don't see any more water draining through the holes,turn it back on and see if the cold air is blowing up into the fridge.if the evap fan motor is bad the part number is W10128551 and it's around 25 to 30 dollars.you must of got the model number off of the book,it's not the full model number,check in the fridge section on the right hand wall near the ceiling and you should see a tag with the number on it.also down at the bottom kickplate,you can remove the kickplate and there should be a tech sheet tucked away in it,read it and it will tell you how to put the machine into defrost mode,if you can do this,instead of unplugging it if you have to melt it out with the hair dryer you can put it into defrost so the heater will come on and this will help you to defrost the vents quicker.let me know what you find and if you need any more help.good luck with your machine
Apr 12, 2011 | Whirlpool Gold GB9SHDXP
Whirlpool Gold fridge not working at all even at maximum coldness adjustment, while freezer is fine. Red light on, indicating bad filter, but frdge not connected to water supply, so changing that wont fix...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 16, 2010 | Refrigerators
Our Whirlpool Gold GB22DK model is not working...the freezer works fine, but the refrigerator is warm and not working. What part would I need?
check the thermostat is working by turning the tem down it should drop the tem if its dont change the thermostat
Aug 22, 2010 | Whirlpool Refrigerators
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool Gold Conquest Mod# GS6shexnt00 side-by-side. About 18 months after buying it the refrigerator section stopped getting cold but the freezer section still worked even though it had iced...
Yes, the difusser door is not allowing cold air to enter the fridge section, a fridge freezer is actually just a freezer, some of the cold air is drawn off from the freezer to chill the fridge protion, if the door is stuck, broken no cold air is getting to the fridge section
Aug 22, 2009 | Refrigerators
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
346 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
