Question about Mitsubishi Televison & Video
I have amodel WS-55857 It is pugged in but all of a sudden it is receiving no power at all
  • 1 more comment
  • bonasb Nov 15, 2010
    Dont have tools for that- what does board cost to replace or repair?
    Dont have tools for repaie of board-- what does it cost to replace / repair?
    Thanks for your help== bonasb
  • 10,594 Answers
Does power indicator lit if tv plugged in?
If power indicator/ green light does not lit or blink then it is problem with power supply section.
Let me know if you are handy with electronics stuff repair and can replace parts in circuit board with proper tools to provide you more technical info.
Thanks.
Posted on Nov 15, 2010
  • Shahid Electronics
    Shahid Electronics Nov 15, 2010
    Repair cost would be approx $200 and tv is an old model so complete board is no longer available.
    Thanks.
When i turn on my mitsubishi ws-55857 it turns off after a few seconds. should i call a repair guy???? i am a handyman??/ what should i do
Hello
this has two general failures that cause this type of problem... The first and easiest is that when the bulb gets older the tv's start turning off by themselves. Pop in a new bulb and the problem goes away. The second is a power supply issue, and those are generally available on ebay or shopjimmy. If you like the tv, I would find a new bulb ...
Best of luck
Nov 26, 2010 | Mitsubishi WS-55857 55" Rear Projection...
My tv has power and sound but no picture. its a mitsubishi projection model ws-55857
You need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 10, 2010 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55857 turn on/auto turn off problem
After it shuts off, you need to get a code from the tv by pressing the menu and device buttons together for 5 sec. A code will flash at you made up of 2 digits. Example. 2 flashes a pause and 2 flashes points to a convergence failure. If this is not your code post yours and I will help you.
Jul 06, 2010 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55857 55 in issue
Hello Rodfamy:
You will need to look in the small signal board section of your service manual.
Aug 10, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS 55857
Hello Phyko14:
The convergence needs to be realigned, that is something that a repair center will need to do.
Aug 08, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55857 won't turn on
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
May 19, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55857 55 in connection problem
there is a setting in the menu under setup i believe it is called
"LABEL VIDEO INPUTS". check you owners manual. you need to make sure that
the DTV input is set to YPbPr NOT RGB.
Feb 22, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
Open Questions:
Televison & Video Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
