Question about HP PSC 1610 All-In-One InkJet Printer
Can't turn it on
If i turn it on, a small square flashing like a marque on the control panel display and turn off automatically. i'm having a hard time fixing it but to no avail. please help. thanks
  • janders12 Oct 31, 2008
    Similar problem with the little boxes, but I then get an error message 0x0805d0a0f2613:fm...can't find any information on this code
  • Alvin Barnabas
    Alvin Barnabas May 11, 2010
    What is the make and model and manufactorer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Check whether the power adapter is heating or not. If the power adapter is heating then power cycle the all-in-one.
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then reconnect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Posted on Jun 19, 2008
Hi, My Olevia 42 inch, model342-B11, has a problem with its picture. At first I had vertical lines running down the screen, then it turned into small squares. What do you think is wrong with it?
Parts are hard or impossible to find for this brand but it sounds like the "main" board which processes all signal in and out of the display.
Apr 30, 2012 | Olevia 742I 42 in. LCD TV
HP LaserJet M4345 - The printer display is mangled, the touch screen does not respond properly to commands. Is there a way to reset it?
Calibrate the control panel
Use the following procedure to calibrate the control panel:
1. Turn the device off.
2. Press and hold the # key and the C key.
3. Turn the device on.
4. When a small white square appears in the upper-left corner of the control-panel display, touch
the square with a stylus.
5. When a small white square appears in the lower-left corner of the control-panel display, touch
6. Allow the device to finish the boot process.
Hope this helps.
Jan 25, 2011 | HP LaserJet M4345 MultiFunction Printer
Cant hardly read the screen the printing is so small and a little fuzzy
Change the display font size. In Win 7, right click on the desktop and choose Screen Resolution then choose make Text and other items larger or smaller. This brings up Windows Appearance and Personalization > Display (small, medium, large buttons). With Win7, you can also turn on Clear Type for LCD displays.
The earlier versions of Windows have the same display font option but it may be a subset of the Accessibility Control Panel. Macs probably have a similar control in the OS.
I hope this helps.
Apr 17, 2010 | Compaq Computers & Internet
System shuts down automatically
Remove the battery and adapter. Press power button for 30 sec. Then connect the adapter. Press power button. When pc started, go to
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
Apr 12, 2010 | Lenovo 3000 Y410 Laptop
I want to kill KLOMPA
run acroos the walls and reach the top of the walls to gain his height. when you jump (1) hold R1 for few seconds...dagger will automatically flash on the screen...when it flashes, press square button at that time...this will enable 1st attack by which you reach on him...(2) now when he is about to throw you down, again press and hold R1 for few seconds...dagger will automatically flash on the screen...when it flashes, press square button at that time. this will enable 2nd attack. (3) after that again press and hold R1 for few seconds...dagger will automatically flash on the screen...when it flashes, press square button at that time. this will enable 3rd attack and this time his one eye will be gone.
Repeat the above dagger procedure for another wall.
Now when his both eyes are gone, attack him and cut his legs. Now when he is down on his knees, prince will run on his back. Now (1) again press and hold R1 for few seconds...dagger will automatically flash on the screen...when it flashes, press square button at that time. (2) After this prince will jump in the air automatically and dagger will flash at that time automatically. Press square button for another attack at this time.
(3) And at last when prince reach his head again press and hold R1 for few seconds...dagger will automatically flash on the screen...when it flashes, press square button at that time to finish arena boss "Klompa".
In broad sense you have to press R1 and square button, 9 times to kill Klompa....!!!
Apr 04, 2010 | Ubi Soft Entertainment Prince of Persia:...
Fire flashes from the small right side panel inside the microwave
This is usally a problem with moisture that got between the layers of a mica coverplate. If the burned bubble is in a cover that looks like a hard plastic or fiberglass piece, then you need to replace that mica cover. The cover is usally 3 to 6 inches square or rectangular. Microwaves will arc between the layers if there is moisture in the mica. Good Luck
Dec 11, 2009 | Washing Machines
Front Panel Display is Blank - only small black squares
the front panel display initializing and then disapear and then the functional buttoms begin to flash. nothing happen again. when i press the on buttom the same thing reocurre
Jan 06, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
49 people viewed this question
Ben Johnson
