Question about Panasonic Microwave Ovens
Panasonic microwave oven NN-S960BC/WC begins to operate then stops after about 30 seconds, no warmth, control panel stays on but program ends.
  • 1 more comment
  • gstewart309 Jun 30, 2008
    blew a capacitor on the inverter board, decided not to repair it just in case the problem cascades due to the age of the unit. It had survived daily use for eight years!, We called Sears as they assume the warranty for items they sell and WOW they offered a deal on a new unit even though the warranty had long expired.
    Our new microvave is back ordered... but with a 100.00 discount we can wait a week or two!
    anybody need a magnitron? I pulled it and a few other parts!
  • Anonymous Mar 13, 2014
    how to remove control panel
  • Panasonic Master
  • 9,098 Answers
Is it by chance running only 22 seconds before it shuts down?
The 22 seconds is the giveaway. In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 29, 2008
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
www.panasonic.com/repair
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
Microwave stops mid cycle
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Dec 27, 2012 | Panasonic NN-T664SF Microwave Oven
My Panasonic Genius Prestige model microwave is in the "Demo" mode and will not operate. How to fix it?
RESET THE SYSTEM BY UNPLUGING THE MICROWAVE CORD FROM POWER FOR 30 SECONDS, CONNECT BACK TO POWER IF THE MICROWAVE CONTINUE WITH THE PROBLEM MAY HAVE A BAD CONTROL BOARD OR BAD ELECTRONIC CONTROL PAD...
Feb 19, 2011 | Panasonic NN-SD797S Microwave Oven
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
Microwes panasonic nn-t553w
hi, check that the cooling fan is operating and to sufficient speed to cool the magnetron or the thermal cutout mounted to the magnetron will cut power
Mar 06, 2009 | Panasonic NN-S753 Microwave Oven
Oven shuts off on cook after about 2 seconds
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do
Your actual model number is located on a tag around the control panel frame, door or below the cooking cavity.
Jan 12, 2009 | Panasonic NN-T654SF Microwave Oven
Panasonic NN-H264SF now requires holding a control panael to operate
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 28, 2008 | Panasonic NN-H264 Microwave Oven
Microwave Ovens Logo
675 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
