Question about Epson Office Equipment & Supplies
Can't find manual. How to put in new ink cartridge
  • Epson Master
  • 4,338 Answers
Here is the support page, just follow the prompts to find your printer and manual.:
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Posted on Nov 15, 2010
2 Suggested Answers
SDtester
  • 41 Answers
SOURCE: new ink cartridges
There is a Manual in the Home1.gif Center Software1.gif under help there is a link "User Guide" or it can be downloaded from Kodak. Here is a link for the manual download.
Kodak.com 5300 support link
Once you click the link above look for the "User Guide" below that pick the language you want. (while you are on the kodak site you can also get the new software and printer firmware to make sure everything is up to date)
If you dont have Adobe1.gif Reader you will need that to view the file you can get it free from here
Adobe Reader
Kodak did not include printed manuals to save money and its better for the environment (less waist).
As for the printing problem, If it is actually picking the pages and going through the motions of printing but the pages come out blank, you can try running the printhead cleaning. From the control panel on the front of the printer use the arrow keys to navigate through the menu to find maintenance and press OK button. then scroll through and find clean printhead or printhead cleaning. try running the deep clean, then print. if it still does not print try running the cleaning a 2nd time. If it still does not print you need to call kodak customer service and go through them to get a new printhead.
I hope your able to get your printer printing again!
SDtester
Posted on Mar 16, 2008
How do i put in ink on 926 dell photo scanner and copier
From the online manual...
1. Turn on your printer.
2.Lift the printer unit, and then position the scanner support between the tabs to hold it open.
3.The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4.Press down on the ink cartridge lever to raise each ink cartridge lid.
5.Remove the old ink cartridges.
6.Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
9. Snap each lid closed.
10. Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
Manual can be downloaded here.
Oct 30, 2012 | Dell 926 All-In-One InkJet Printer
Put new ink cartridge in Epson NX 110
I have a epson stylus NX110 Printer the ink cartridges will not stop so that i can put in new ones.I press the stop button but the ink cartridges will not stop onthe arrow so that i can put in all new ones.
Apr 21, 2010 | Epson Stylus NX115 All-In-One InkJet...
Out of ink message but just put new cartridge in
fix your cartridge properly...maybe it is not in plce...refer for manual so that you have put it in right place...
try to rest your printer if you know how...
Feb 06, 2010 | Epson Stylus Photo 1290 InkJet Printer
I have a lenmarx x5150 printer and have no manual with instructions.How do I use it and replace ink?
  • Press the "Power" button to turn on your Lexmark
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color ink cartridge.
  • Step 4 Remove the new black ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black cartridge into the slot on the left side and push it down. Slide the color cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the cartridge until it clicks closed. Push the purple plastic cover down over the cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Nov 19, 2009 | Office Equipment & Supplies
HP Photosmart 3310 printer shows all ink cartridges need replaced
If you ran the ink cartridge refill routine, from your desktop using the utility supplied by HP, this should not occur, so try running the head cleaning and alignment routines and see if this clears up the problems.
I am assuming that all your cartridges are relatively full and trouble free and that the printer has been successfully and recently used, prior to your replacement of the one new cartridge.
Sometimes, if the printer has been idle for some time without use, the ink will dry on the heads of perfectly good cartridges, causing the problem you cite.
Use alchohol based cleaner with the kind pads supplied with a new cartridge to regularly clean the heads of your ink cartridges, according to instructions in your manual and CAREFULLY, so as to not damage the heads.
Apr 07, 2009 | HP Photosmart 3310 Printer
Says the yellow ink needs replacing,have a new ink cartridge in
pulled plug, removed yellow cartridge, cleaned point where yellow ink goes in, put plug back in and it worked.........Thanks
Jan 27, 2009 | Brother MFC 210C All-In-One InkJet Printer
Problem with new ink cartridge
More that likely the refilled ink cartridges are faulty and should be replaced. While some folks have pretty good luck with refilled cartridges, it is generally better to stick with the new ones.
As to the problem with old cartridges, keep in mind that the estimated ink levels are just that - estimates. However, if your printer has an option for cleaning the cartridges, try that before chunking them. Take them out, put them back in, and run the cleaning process. Sometimes the nozzles can get clogged up and running the cleaning process will clear them up. ( DO NOT TRY TO CLEAN THE CARTRIDGES MANUALLY!)
If none of this helps, you will more than likely just need to get some new cartridges. - Graye
Oct 29, 2008 | HP PSC 1410 All-In-One InkJet Printer
Ink Cartridge Error
on your cartridges there is a chip that detects if the ink is low. The chip on your yellow cartridge is bad. You should return the cartridge for a new one(if you still have your receipt) or visit a Cartridge World in your area and they can put a new chip on for you
Aug 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  2. Lift the front cover.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
