Question about HP StorageWorks DAT 160 USB External Tape Drive - Tape drive - DAT - DAT-160 - Hi... DAT Tape Drive
Error: Error 4305: Block size is larger than the maximum allowed transfer size.
Change camera resolution
Most digital cameras will allow you to select the resolution at which it captures images and/or videos. Some call it "resolution" while some call it "image size" or other similar terms.
The higher the resolution or larger the image size, the larger the file. Many online services restrict the maximum size of image and/or video files they accept. Lowering the resolution or reducing the image size will reduce the size of the files.
Please refer to your camera's documentation. If you still need assistance, please reply to this post and specify the make and model of your camera.
Aug 29, 2012 | Computers & Internet
What's the maximum hard drive I can install in a Compaq SR1420NX I have a 80 hard drive right now I want to install a larger one. Will this computer handle a larger Hard Drive
The BIOS has a max. hard drive size limitation. Check the manual for the maximum size the motherboard can support.
If the maximum size hard disk it can support then you can add a second hard drive in the computer as a SLAVE hard drive to double your disk space capacity.
Mar 15, 2011 | HP Compaq Presario SR1420nx...
How do I send video via text message? Keep getting the message 'Unable to insert object. Maximum message size is 300kB' Is there a setting I need to alter somewhere to send something larger? Thanks.
Hello Megan
Unfortunately the maximum size for video sending is 300kB in this case. If you are within 15m of the other phone you can try to Bluetooth the video. Bluetooth has a much larger limit on file transfer.
So, in a nutshell, there is no setting which will resolve this issue.
Please feel free to let me know if you need any further assistance.
Kind regards
Lock123
Feb 07, 2011 | Nokia E72 Smartphone
I Am installing a Generac 20Kw air cooled unit with a 200 amp service disconect ATS What size conductors do i use from the generators 100 amp breaker to the transfer switch
It is always good to install a large enough wire where the maximum load can be drawn plus a little extra for safety. 7 gauge wire will do, if it was mine I would use 6 gauge wire. If the length is over 20 feet but not longer than 80 feet go to the next larger size wire.
Dec 18, 2010 | Generac Guardian RTSE200A3 200 Amp...
How do i program my embroidery machine hoop to cover larger design
Hi! We got disconnected with our chat session.
Anyway.. What you could do is first load the design. After that click on edit then auto-split. You then set the maximum size that your machine will allow. 110x100 mm for example. click on ok. After thatyou then click on file then save separated as. That is what you use to transfer using the USB.
I hoe this helps.
Jubert
May 19, 2010 | The Learning Company Computers & Internet
I can't transfer file larger than 4GB on my transcend 16GB but i can transfer different files less than 4 GB if the sum does not exceed 16GB
If your device uses the FAT32 file system, 4GB (minus 1 byte) is the maximum file size supported. It's simply a limitation of the file system.
Apr 22, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I can not receive e-mails with attachments
It might be happening if there are some limitations/restrictions imposed as a part of the standard policies/procedures. for e.g.
Maximum message size of an email including all attachments is 20 megabytes. Incoming messages larger than that limit will be rejected, and error message returned to the sender.
Note that other email providers may have a lower attachment size limit, so attachments smaller than 20MB sent may still be rejected by the remote destination. Additionally, downloading large attachments will take a long time for recipients on slower internet connections.
We are using Microsoft Exchange as the email system. Preferred personal accounts are hotmail, gmail, yahoo....Gmail gives max attachment size approx. 10MB so is quite useful to transfer some bulky files....thks....do let me know if you have more queries....hv a nice day!!!
Warm Regards
Mar 13, 2009 | Computers & Internet
M t u
In computer networking, the term Maximum Transmission Unit (MTU) refers to the size (in bytes) of the largest packet that a given layer of a communications protocol can pass onwards.
MTU parameters usually appear in association with a communications interface (NIC, serial port, etc.).
The MTU may be fixed by standards (as is the case with Ethernet) or decided at connect time (as is usually the case with point-to-point serial links).
A higher MTU brings higher bandwidth efficiency. However, large packets can block a slow interface for some time, increasing the lag on other packets. For example, a 1,500-byte packet, the largest allowed by Ethernet (and most of the Internet), would block up a 14.4k modem for about one second.
The default MTU on a PPPoE connection is 1,492. The default MTU for a DHCP or PPPoA connection is 1,500.
Increasing the MTU size beyond these levels is possible on a client computer, but not recommended, because the MTU size on the outbound connection to the ISP will nullify any potential gains from a larger MTU.
Apr 20, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
IDE HARD DISK
Normally 137gb but updating the bios will allow a larger size to be recognised.
Oct 05, 2007 | EliteGroup P4VMM2 Motherboard
Print size DiMAGE E201
The maximum print size for an E201 image is approximately A4, when printing at 150dpi. For Photo-quality prints, we recommend printing at 300dpi, no larger than postcard size.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
HP StorageWorks DAT 160 USB External Tape Drive - Tape drive - DAT  - DAT-160 - Hi... DAT Tape Drive Logo
474 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
