Question about U.S. Robotics (USR8200USR8800KIT)
Hi i keep getting the error 8007efd and cant sign in on msn host file and keyports also wireless are not ticked it says could be frewall blocking it but switched it off ,,,,,,,,,,no luck this is driving me madddddddddddddd
I cant sign in to my account keep getting error code 800488fe
If this is in regards to MSN/Hotmail, your account has been blocked due to misuse. Please see: http://windowslivehelp.com/solution.aspx?solutionid=f172cbee-3c73-4506-8a1d-4e6e82adb846
Follow these steps to unblock your account, and you should be good to go!
Jun 02, 2011 | Computers & Internet
Error code 81000306 cant sign in
http://messenger-support.spaces.live.com/blog/cns!8B3F39C76A8B853F!13932.entry
Please go and read the solution right there.
Hope this helps.
Aug 18, 2010 | Microsoft Windows Live Messanger
I am trying to sign on to msn messenger and i get the error code it is 80048820
Please follow steps to resolved issue
The Solutions to MSN Error Code 8004882080048820_lan.jpg Internet Explorer - Try removing the tick next to Internet Explorer 'Proxy server' settings, instead, go with the 'Automatically detect settings'.
1) Launch Internet Explorer, click Tools and then click Internet Options.
From the Internet Options dialog box, go to the Connections tab.
Click LAN Setting. Un check the Use a proxy server for your LAN (These settings will not apply to dial-up or VPN connections) checkbox. Finally positively tick: 'Automatically detect settings'.
2) Register softpub.dll.
Click Start (Button), and then click Run, type regsvr32 softpub.dll. Restart MSN Messenger. See also Error code 81000314
3) If necessary, logon as a local administrator and set the computer's clock to the correct date and time. (Check on the internet if possible.)
4) Turn off the firewall temporarily. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
NetGear problem, but also with some other routers
a) Enter IP address 192.168.0.1 in your browser's address bar.
b) Log on with ISP user name and password.
c) Enter Admin, password
d) Navigate to advanced menu, WAN set-up
e) Change MTU size to 1400
5) Try a password of no more than 8 characters.
6) If you are using IE 7.0 check the SSL Settings. Internet options advanced (Tab) scroll down to the bottom. Security section. Tick 'Use ssl 2.0'.
7) One of the simplest ways of curing MSN error 80048820 is to unplug, or restart your modem. This is particularly effective for cable modems.
8) We should have tried this solution before; check that the MSN site is 'up' 'available'. However, even if the site is down, you don't usually get error code 80048820.
8a) As a variation, of checking online, you could try phoning your local Microsoft Support office. Local area numbers available from http://support.microsoft.com.
9) Have you just installed any anti-virus software? Did the anti-virus software just make a big update? Try disabling and see if that cures the error.
10) A drastic solution is to try uninstalling MSN Messenger version 8.0 or 7.5 and install Microsoft MSN version 7.0.
Hope it can resolved issue
Thanks for using Fixya
Apr 02, 2010 | Microsoft MSN Messenger Connect Service
Cannot sign into msn, aswell cancel sign in!
Go to or Click your SERVER STATUS of your MSN. This problem comes up with framework.net
I have the same problem of this also.
All I do is on the Internet Explorer in the internet options then Connections, sometimes this configuration are using Bypass Proxy, uncheck it and choose automatic settings.
Oct 09, 2009 | Microsoft Windows Live Messanger
Right password and username still no sign in
This is a longshot, but maybe some yahoo.com pages are being blocked by your computer. Do a search for your Hosts file and open it with notepad. Any listings that are prefixed with 127.0.0.1 are blocked. Look through these listings for anything with yahoo.com in it. If you find any, make a copy of the hosts file with a name you'll remember, then delete the entries containing yahoo.com. Save and close the Hosts file. Try to sign in to your yahoo accaount. If this doesn't work, use the copy you made of the Hosts file to restore the file.
Hope this helps.
Jun 30, 2009 | Yahoo YHT-630 System
Error code 80072745
http://www.tweston.co.uk/2008/07/26/windows-live-messenger-problems-80072745-solved/
This error is fixed by the solution here.
Nov 05, 2008 | Microsoft Windows Live Messanger
Canot sign into hotmail account why
when you go to msn dont try to sign in look for the icon that says choose msn as your home page and down load the information then you can sign in. some internet companies block out certain web sites.
Dec 08, 2007 | Compaq Presario 5000 PC Desktop
ANY FELLOW EXPERTS I NEED HELP
There's three quick things you can try:
1) If possible, roll back or uninstall/reinstall your web browser
2) scan for spyware and viruses - Often, DNS and other server settings can be hijacked by malicious programs
3) clean up your hosts file - This is normally taken care of by 2), but just in case... In WinXP, the host file is typically located at %SystemRoot%\system32\drivers\etc\
I assume you've already tried simple things like restarting your computer and such? Weird problems like this can often be
Dec 07, 2007 | Compaq NX6110 TFT XGA Notebook
U.S. Robotics (USR8200USR8800KIT) Logo
83 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Prashant M
Prashant M
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
