Question about Lexmark X2550 All-In-One Printer
Hi. I cant get my printer to allign. I've just replaced the black ink cartridge and when i put the allignment page inside the scanner it wont scan
  • brady12xli Nov 17, 2010
    When i hold the scan button for three seconds nothing has been happening. I've even tried using an allignment sheet i had printed from a couple of months ago
  • Lexmark Master
  • 4,338 Answers
Did you try to align the unit manually or with the computer?
Alignment page does not print
1 Make sure you remove the sticker and transparent tape from both print
cartridges.
2 Make sure the color print cartridge is secure in the left carrier and the black
print cartridge is secure in the right carrier.
3 Make sure you loaded the paper correctly and did not force the paper into
the printer.
Aligning your print cartridges without a computer
Make sure you follow the steps on the Setup sheet to complete hardware
installation. Continue with the following steps to optimize print quality.
1 Make sure you have loaded paper into the paper support, and then press
and hold Scan for three seconds. For help, see "Using the control panel"
on page 4.
An alignment page prints.
2 Place the printed alignment page onto the scanner glass.
3 Press Scan. For help, see "Using the control panel" on page 4.
Once scanning is complete, your print cartridges are aligned for optimal
print quality.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Posted on Nov 15, 2010
  • JDTec
    JDTec Nov 18, 2010
    You may need to reinstall the Solution Center. Here is the User's guide:
    http://www.lexmark.com/publications/pdfs...
Allignment page will not print correctly
Print heads alignment completes after scanning fully printed align page. In this case all colors are not printing due to cartridges faulty.. You need to replace both cartridges at a time to this types of errors..
Jan 05, 2013 | HP PSC 750 All-In-One InkJet Printer
Heavy black stripe on back side of every printed page
This is probably due to miss alignment, there is an option of test page which will be scanned to allign the cartridge, if ur's a all in one printer. This test page is printed at the first time and scanned instantly for first time operation.
Thankyou
Mar 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
I bought an HP 6110 printer and had to put a #57 ink cartridge in.Now it's saying that my paper is too narrow.I have 8.5" by 11" paper in and all my settings are for that.And it won't print if I...
Hi
after changing cartridges printer needs to alligned printheads
and this can hapen only with A4 paper
just put one page A4 in your printer until allignment is done
if i help you pls vote me
Oct 27, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HP SOLOUTIONS CENTER, C5280 SCAN - when trying to save scan in a specific location Drop down menu is blank. THANK YOU
Put new ink cartridges in printer and will not allign properly, what should I do? Alreadsy printed the allignment page and it is off.
Dec 03, 2009 | HP Office Equipment & Supplies
I changed the black ink cartridge as per instructions and the printer printed an alignment paper which i then placed in the printer for alignment but the alignment failed
the page should be absolutely new.and the scanner glass should be absolutely cleaned.and 1 main thing u replaced your black cartridge.but if your colour cartridge is empty it will not accept the allignment complete thing.it will show allignment failed as the particular colour is missing in your allignment sheet which is required to get the allignment complete.
Nov 23, 2008 | HP Office Equipment & Supplies
After putting a new black and white ink cartridge into the printer, it keeps printing the alighnment sheet everytime I turn the printer on. Ugh! What a waste of ink.
actually it is given in that allign page printout that how to stop this.
but listen the procedure.
after the allignment page is printed just place that allignment page in the scanner .the readable side of the page on the glass.then press OK/ENTER what button present in your printer.
the allignment will start.the printer will read the page.and allignment will get completed.then after u ON the printer it will not give you such problem till u replace the cartridges.
Nov 14, 2008 | HP Office Equipment & Supplies
ONLY WANTS TO SCAN
Once the alignment page is print you need page the page in the scanner bed and hit the scan button on the printer once it done you be able to print again this process is know as scan back alignment ..
Good luck.....
Oct 25, 2008 | Lexmark X2500 All-In-One Printer
HP 6110xi cartridge align under Vista Home Premium
it is necessary to place the allign page in the scanner and then press the enter button and the scanner will read the allign ment page as it will take 2 minutes and then it will display the message allignment complete message then it will become normal as it was .so after u get the allignment page place it in the scanner unit of the printer and then press enter.
Oct 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Allignment
when you insert the new cartages then when the align page will print put it in the scanner and scan it once the align page will be scanning it will not print the align page up to you not change the cartrage
Jul 26, 2008 | HP PSC 1510 All-In-One InkJet Printer
Align Print Cartridge Failure
hello..
You may be need to buy a new color cart., becuase the allignment page depend on the Yellow color when it become to scan..
or you can pring any allignment page from a friend and put it in the scanner instead that one you printed out....
Hope it's work
Yasser
Feb 20, 2008 | HP PSC 950 All-In-One InkJet Printer
Lexmark X2550 All-In-One Printer Logo
234 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
