Question about Video Game Consoles & Games
My xbox360 has three red flashings red lights?
    Champion:
  • 207 Answers
Ok it sounds like 3 rings of death.. now this will sound crazy but it saved a few 360s that came through me...
Take 2 towels and wrap it around the 360 to make sure it can heat up (YES I AM SERIOUS) turn it on for 15 min and let it sit.. the 3 lights will blink.. after the 15min unwrap let it rest for 30 seconds then boot it up again.. somtimes thats all it needs let me know asap if it worked.. It worked on mine and saved my cod3 life!
Posted on Jun 19, 2008
My xbox360 has 3 red lights what wrong sian
Three flashing red lights means there is a hardware problem with your Xbox 360 console or its power supply.
Jul 07, 2011 | Microsoft Xbox 360 Console
My 360 has 3 rings the rings are red and it wont turn on
The three red lights mean that your XBOX360 is experiencing hardware failure. This is caused by overheating of your XBOX. Contact Microsoft and have them fix the problem. They have given free extended warranty for three red light problems. If you have bought your xbox360 within 3 years, you're in luck.. They will fix your console for free...
Mar 13, 2010 | Microsoft Xbox 360 White Console
Three red lights flashing
If this is your Xbox 360 console you are referring to, then you need a repair. If you are under your 3 year warranty from MS go to www.xbox.com/support to fill out a repair request, otherwise look for someone in your area that has experience repairing the Red Ring of Death.
Jan 03, 2010 | Microsoft Xbox Console
I have 3 flashing red lights on the console and a yellow light on the power supply
3 red flashing lights is known as the red ring of death. Your power supply showing a yellow light is ok, that just means that your power supply is on standby. The first thing you should do is check with microsoft to see if your unit is still under warranty with this site: http://support.xbox.com/support/en/us/xbox360/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/xbox360/registerdevice.aspx?step=repair
If your unit is not under warranty, go to www.wiredextreme.com. We are a console repair company based in Texas, and we can fix your console. We give a free diagnoses on your unit(excluding shipping), and will call with an estimate before any work is done on the unit. All our work is covered by a 90 day warranty, and you can buy up to 4 years worth of warranty coverage.
Nov 16, 2009 | Microsoft Xbox 360 Console
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
Xbox360 3 red lights
YOu are having problems with the three red lights right (red ring of death)? How old is your xbox?
Dec 12, 2008 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
I have 3 red lights flashing
For future reference please enter what system you are having a problem with. I'm guess that it's an xbox360 since it's the only one with red lights that flash. If you have three of them, it's a hardware malfunction. Microsoft has announced that they will refund anyone with this problem because it was a problem from the factory not you. So you need to speak with Microsoft and get another one sent to you.
Nov 09, 2008 | Video Game Consoles & Games
3 red rings on power button. General Hardware failure. xbox360
On July 5, 2007, the Vice-President of Microsoft's Interactive Entertainment Business division published an open letter recognizing the console's problems, as well as announcing a three-year warranty extension for every Xbox 360 console that experiences the "general hardware failure" indicated by three flashing red LEDs on the console.[16] During GDC 08, Microsoft announced that the "Failure rate has officially dropped".
Go complain they should fix it under warranty its a know issue - look up "XBox360 Red Ring of Death" on the internet or on the Microsoft Site.
Aug 01, 2008 | Video Game Consoles & Games
Video Game Consoles & Games Logo
26 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
