I have Lg Golden eye CRT TV, It has a problem .When I turn On my TV then the power LED just blinking with no screen and sound.....Plz send the solution with CKT diagram..
SOURCE: Turns on but not picture or sound. Power LED blinks
directly inside the tv on at the end of the power cord is a fuse needs replaced
Posted on Jun 15, 2007
  • 98 Answers
SOURCE: Samsung LNR408DX/XAA Powers on with sound but no picture
I think you need to exchange the Main Board.
Posted on Feb 06, 2009
  • 239 Answers
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
Posted on Mar 04, 2009
SOURCE: power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
Posted on Mar 15, 2009
freetek
  • 5568 Answers
SOURCE: tv will not power up
If it's failing to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself but it will likely have the same problem eventually unless they have altered the design.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Mar 30, 2009
LG 74cm Golden Eye, screen is blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Main power regulator board fault too can cause this flashes.
Jul 28, 2014 | Televison & Video
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Dec 28, 2013 | LG Electronics 47LS4600 47" LED HDTV
Lg golden eye 21inch ctv stand by led glows but switchin progress key only clicking sound found,set unable to on
Shorted component/s in the main circuit board's horizontal output section. Check and replace the damaged components there.
Jan 05, 2013 | LG Televison & Video
How to disable camera on LG golden eye
Refer its user manual for details. You haven't provided the exact model number of your LG TV here. If so, I might guide you.
Apr 27, 2012 | LG Televison & Video
In my Lg Golden Eye 21" television remote control
Which type of remote control can I use for golden eye TV
Aug 12, 2011 | LG Televison & Video
How do I work the subtitles on and off on my LG Golden Eye 32" tv can't find a button anywhere to do it or anything in the manual or on the screen menu
if you have a set top box its probably the solution, we had the same thing happen and it was the subtitles on the set top box just locate it on the remote and turn off
Oct 10, 2010 | LG Televison & Video
Hello sir, i hav LG CRT 15" monitor. After turning on, its LED continuous blinks and power button does not work and displays nothing. so plz suggest me what should be deffect?
Any 15-inch CRT-style monitor should be replaced by a 15-inch or 17-inch LCD-style monitor. You can find "previously-owned" monitors for $30 to $50, which is less than taking your CRT monitor to a TV/video repair-shop for an *attempt* to get it repaired.
Oct 04, 2010 | Computers & Internet
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
When the power on monitor led is blinking and
It sounds as though the power supply for the monitor has a problem - it may be a capacitor that is failing. It is obviously trying to turn on but the voltages are not right. The simple solution may be to replace the power supply board, but take it to a reputable electrical/electronic repair man.
Nov 22, 2009 | LG Studioworks 563N 15" CRT Monitor
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
