Furnace doesn't heat the burners come on for about 3 seconds then shut off. The furnace is a Trane XL80
  • 43,501 Answers
The flame sensor is not sensing that the flame has come on....the flame sensor could be dirty or the could be ignition module problems...
I am assuming that this is not a new installation....because reveres polarity can cause that also....
I would clean/ replace the flame sensor first and then from the the control board will ned to be replaced if that don't work.....
Have had to drive a totally separate ground rod and ground the furnace separately in one extreme case...
heatman101
Posted on Nov 15, 2010
Trane XL80 downdraft furnace intermitant eratic ignition
Erratic ignition like what exactly? Comes on runs for a few minutes or seconds then turns off gas then tries again? Or erratic it won't fire the gas at all? Can you be more specific?
Feb 17, 2017 | Heating & Cooling
Trane XB80, no heating, limit circuit open
Sometimes these can be reset by gently taping them on the floor. Can be caused by not changing your furnace filter.
May 18, 2014 | Trane American Standard Trane American...
Trane xl80 blower working intermittently
hello Miss/Mrs/Mr,
I have the furnace trane xl 80, when I turned for heat everything working but only blower motor was not running, I wait for 1 minute all system suck down? I guess the capacitor blow out, that the reason why blower motor was not running
Please email me that is the
Jun 24, 2012 | Heating & Cooling
Hi I have an xl80 the burner lite and heats up till at desired temp, after burner goes out the fan keeps on running 15 minutes or so. If I go down and shut off power switch to furnace then the fan shuts...
Hi, sounds like you have a problem with the heat anticipator in the thermostat. If you replaced the fan limit, and with it running that long after the burners shut down, it would be in your stat. If it fires up after resetting breaker, was the stat set to call for heat? If not, the stat is faulty. If you remove the front to get to the stat wires, take a jumper wire and jump from RH or RC to W. Heat will start. Let it run for a minute or so and remove wire. If the fan shuts down with in a min. or so, you will know it was the stat. Good Luck and let me know the out come!
Shastalaker7
A/C, & Heating Contractor
Feb 11, 2011 | Heating & Cooling
I have a trane xl80 furnace. the fan runs but no heat. The light on the front blinks 9 times and on the panel it says something is wrong with the ignitor. can I fix that at home or do I need to call a...
The ignitor on your furnace broke... this is a common problem and not too hard to fix if you have a place to buy the ignitor from... it also can be purchased online...
If you are not confortable with repairing it then call a repairman...
Here is a tip that wrote about how to buy heating and airconditioning parts online.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Nov 30, 2010 | Heating & Cooling
I currently have dual split units (Trane XL80 & XR13) heating and cooling the house. One of the XR13's is not working properly. This is what I observe. The XR13 in question is running --the fan is...
Check how many times the light is blinking... it will flash a series of blinks and then pause...and flash the series again...
Then remove the cover nad insdie it will tell you how to interpet the blinks and then you will know why it is kicked off...
heatman101
Aug 24, 2010 | Heating & Cooling
Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
Jan 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
1994 trane furnace fan will not shut off xl 1200
Hello there:
please contact a certified trane dealer i think that you are having a thermostat problem they may be able to assist you on setting the thermostat the correct way . ok?
best regards
mike
Aug 15, 2009 | Heating & Cooling
Heating & Cooling Logo
226 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
