Question about HP Compaq Presario SR2010NX PC Desktop
Which port do I plug my deskjet printer into?
    Problem Solver:
  • 17 Answers
The back of your computer does not have a conventional paralled printer port. If your printer has a USB connection, then you will want to use either of the two USB ports, located directly under the LAN port. #6 in the illustration below.
If your printer uses a conventional parallel port connector , you will need an adapter like the one shown at the bottom of this post. You can get these at Amazon, Newegg and probably Best Buy, but I have not checked there.
Best wishes!
Posted on Sep 23, 2011
  • Rick Brengle
    Rick Brengle Sep 23, 2011
    Sorry about the pictures. The back of your machine can be seen here (just scroll down on the page).http://h10025.www1.hp.com/ewfrf/wc/docum...
    The adapter can be found here:http://www.newegg.com/Product/ProductLis...
    Best of luck!
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
Printer only works on one USB port
You can swap thye ports areound on Vista, but Xp is more difficult. What happens is the USB is converted to an LPT port like lpt1 or 2. This remains in the device manager list because it is usally a fairly permanent object. USB printers are rarely totally USB, like other items. So windows fails to recognise the printer on other ports or, it will require a new installation for that port. With Vista you can go into Device manager and reassign a USB port to a printer port. XP is another ball game you might not want to play in.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 18, 2009 | HP Deskjet 5740 InkJet Printer
Can't print from Quickbooks Pro 2008 to HP 6500 All in one
You can install Deskjet 990c drivers to print from Quick Books
We need IP address of printer for this.
Please perform following steps to get IP address of printer.
On printer press Setup >>>> select Network >>>> select View Network Settings >>>> select Print Network Configuration Page >>>> press OK >>>> this will print network configuration page >>>> note down the IP address of printer showing on this page
Now you need to install Deskjet 990c driver
On computer click Start >>>> Control Panel >>>> Printers or Printers and Faxes
Click "add a printer"
Select local printer (uncheck automatically detect my plug and play printer) click next
Select LPT-1 port and click next
select manufacturer as HP and printer as deskjet 990c and click next
make printer name as Deskjet 990c and click next
Use as default click next
Do not share click next
Select "no" to test page and click next
This will show a new icon of deskjet 990c in printers window.
Right click on Deskjet 990c >>>> click Properties >>>> click Ports
click "add a port"
select "standard tcp/ip port" and "new port"
type IP address of printer in the column of printer name
type IP_IP address of printer in column of port name
device type "generic network card"
Complete the process by clicking next/ok/finish
Try to print from quickbooks by using Deskjet 990c icon
Wish for all success..
Harpreet_351
Jul 15, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
I need a LPT 1 port for a HP895 Deskjet 895Cse printer.
If you have an USB cable and a spot on your computer to plug it in...it is a much better way to go. The computer will detect it and just work so much more easily.
Apr 02, 2009 | HP DeskJet 895cse InkJet Printer
Don't know how to get my hp deskjet 6840 to print wirelessly
Should have a USB connector and needs to be plugged into the USB port.
Hope this helps. Bud
Dec 31, 2008 | HP DeskJet 6840 InkJet Printer
Where does plug go ?
Need to known what plug it is to answer that if its a usb plug it goes to the usb port but if its the big printer plug you would have a slot on the back of you computer box that would take that either a printer port or com port
Sep 16, 2008 | HP Deskjet F335 All-In-One InkJet Printer
HP Deskjet 970cxi
go to control panel, and look at the ports to make certain they are enabled..if not, remove them, then do a scan for hardware changes, and then try it again. I recommend you remove anything plugged into those ports while doing this.
check your computers warranty here 4 FREE
Mar 24, 2008 | HP DeskJet 970cxi InkJet Printer
Question about usb for printer
Make sure that the USB ports on you computer are configured properly. You should try plugging another USB device in and see if it is detected.
Dec 24, 2006 | HP Deskjet 3915 InkJet Printer
HP Compaq Presario SR2010NX PC Desktop Logo
114 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
