Question about PANDIGITAL PhotoLink OneTouch SCN02 PassThrough Scanner
Light keeps blinking on scanner - PANDIGITAL PhotoLink OneTouch SCN02 PassThrough Scanner
The lights keep blinking?
Hello, Usually this is caused from no paper ,a paper jam. Check for paper jam or no paper. Or engine driver failure this is a hardware failure and will have too be service repaired.
May 29, 2014 | HP Laserjet Printer P2035 P2055 Laser...
Scanner error
your printer scanner had damaged please check for broken cable or gear wheel if find replace it
Jun 06, 2013 | Epson WorkForce 600 All-In-One InkJet...
My Pandigital scanner the light keeps blinking
Blinking usually indicates a card error. You must have an unlocked memory card in the slot in order to scan. Make sure that the card is fully inserted and has free space on it to save pictures.
Jan 11, 2010 | PANDIGITAL PANSCN01
Airbag dashboard light keeps blinking. In 1997 Ford Thunderbird.
The air bag computer will have to be scanned and the code read to know what the fault the computer detects. The problem will have to be repaired for the light to shut off. Keep in mind, when the air bag light is illuminated the air bag system is deactivated. Meaning, in the event of a collision the bags won't deploy.
Dec 05, 2009 | 1997 Ford Thunderbird LX
Ink light of my tx101 keeps blinking
Hello, Amit.
From FixYa, give this a try:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Hope this helps.
Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Lights are flashing on printer and it will not print . the voice says there is a problem with the printer. I did the alignment process but the voice keeps saying there is a problem. I took both cartridges...
There 3 light on the printer that able to indicate to user when problem occur. Which is the light u mean here?
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
YBC (/\)
Sep 28, 2009 | Lexmark X2500 All-In-One Printer
Error message -4431
If the scanners keeps blinking while powering on, it is because it has not been intialised. Check for loose shreds of paper in the paper path. Unless the scanner intialises, it cannot scan. If simpel 'countonly' option works, then the scanner is okay.
S. Mohan, Chennai, India
Sep 04, 2008 | Canon DR-2580C Path-Through Scanner
Broken Lamp Blinking
Does the lamp light up while warming up? If not then there is a fault with the lamp driver.
Oct 25, 2007 | Ricoh IS 430 Flatbed Scanner
Minolta Dimage multi pro
Initially, I get a green flashing light when unit turned on, but after a minute or so, it turns to a red flashing light. It will take in the film tray only when blinking red, not when blinking green. My iMac has a hard time seeing the scanner, keep getting "scanner not found" messages. I have to go to system profiler and have it refresh and then it finds it, then the scanner software sees it too. But I have been unable to one preview out of it, says LED error and that's it. Using 10.4.10 on an iMac 20" with 2.5gb of RAM, using Pshop CS2 or going through Minolta Driver of OSX I got off of VersionTracker. I did remove the screw for transport right away. Will feed in 35mm tray with red blinking light, will not feed in 120 tray except partially with red blinking light, and only a couple times out of maybe ten tries.
Aug 23, 2007 | Konica Minolta Dimage Scan Multi PRO Film...
The Scan Dual IV will not initialize on startup although the door is closed.
 Hi I'm GusGusGus, I just posted a solution that might help. It's under the post about "2nd request for help on the scan dual 4", Hope it helps. Good Luck!
Jan 07, 2007 | Konica Minolta Dimage Scan Dual IV Film...
PANDIGITAL PhotoLink OneTouch SCN02 PassThrough Scanner Logo
66 people viewed this question
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
David Payne
David Payne
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
