Question about Hotpoint Washing Machines
My hotpoint aquarius WMF760 started making strange buzzing sounds this morning (whilst it wasn't in use) followed by clicking as if it was moving through the programmes. On trying to wash a load, nothing happened and I got a fault 1 notice. When I moved the machine to unplug it , I notice a drip from the bottom far left corner (as you look at the machine from the front). It is just a few days over 1 year old and very lightly used. Any ideas? Jan
  • 3 Answers
SOURCE: Hotpoint Aquarius WD440
u might have a blockage in the drainpipe. hope it helps. good luck!
Posted on Jun 29, 2008
  • 679 Answers
SOURCE: Hotpoint aquarius WF541 will not switch on
If the washer doesn’t operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power, or, if the motor stopped mid-cycle, the machine’s overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself. Then restart the machine. Otherwise:
1) Be sure the machine is plugged in and turned on. If necessary, check the receptacle it’s plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely.
2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit.
3) Unplug the washer, and check the power cord. If necessary, replace the cord.
4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch. If it doesn’t click when you do this, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call a repairperson.
5) If the washer still doesn’t work, the controls may be faulty. Call a service person.
Thanks for your question
Posted on Jan 03, 2009
  • 497 Answers
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
Posted on Sep 06, 2009
  • 3463 Answers
SOURCE: hotpoint aquarius wma34 washing machine - flooding and clicking
Sounds like it could be relatively expensive to put right.
Personally, I think you would be better in investing in a new washer, more so in view of the fact that is 7 years old.
There are numerous possibilities for the symptoms you describe.
Hope this helps you to come to a decision.
Posted on Dec 29, 2009
  • 104 Answers
SOURCE: Bra wire stuck between inner and outer drum how to
Depends where it is stuck. If near the very front you can sometimes get them by removing the door seal to gain a small access between drums. Other ways is remove the outlet pipe from the bottom of the drum or easiest and most probable area where it stuck is remove heating element. Provides a better view and bra wires normally get stuck on them.
Posted on Jan 28, 2010
Washer dryer door open and key sign and clicking noise when I try to start up washing machine Amber light flashing
Is the door fully closed or has some debris got into the the child lick on?try resetting the machine by switching off power at socket, then whilst holding the start button for five seconds whilst you switch it back on at socket.door solenoid should cluck once and the key sign should disappear.hope this is of help.
Jan 18, 2015 | Hotpoint Aquarius WD640 Front Load...
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
The wash dial on my hotpoint wmf760 is not selecting
The knob needs to be removed and the knob and the mating part will need to be replaced. The teeth on these parts wear off with time. There is a clip on the back of the knob that pulls off this holds the knob on. Then the mating piece will pull out. Eneter your model # at for diagrams and illustrations. All parts come with installation instructions.
May 03, 2010 | Washing Machines
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius belt slippped
It sounds like your washer may have a major problem.
If it was so noisy, it sounds to me as though the main drum bearings have gone, or the motor bearings, that being the case, I woukld recommend that you do not use the washer until it is checked out.
Hope this helps!!!
Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
check your door .. door lock damage or doot pin damage
Sep 06, 2008 | Hotpoint Aquarius WD640 Front Load...
TDC32 making a strange noise when running
sounds like bearings on your tdc32
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Dec 11, 2007 | Hotpoint TDC32 Electric Dryer
Washing Machines Logo
52 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
