I have an old but still wonderful tsp lotus elna baby sewing machine but unfortunately in moving around I have discovered that the foot control has been lost. Do you know where I could possible find one. Thanks
there is a spring on the presser foot applying pressure when you release the lever, so that there is constant downward pressure onto the fabric from the foot as you stitch. If there seems to be no pressure on the presser foot, then this spring may have broken. If this is a Star series TSP with a beige top and white body, then you undo screws on the top panel to gain access. There is also a TSP in the Air Electronic later model range, there is also two screws on top but you need to work around the carry handle to actually lift and move the top panel to the back of the machine. I'd suggest this could be a job for the SM repair mechanic.
The Lotus should have the integrated foot controller and power cord in one. Some of these had a switch on the foot controller which reduced the power to half speed. That's the only way to adjust the speed other than the foot on the pedal. The later models Air Electronic have a slide speed control on the front face of the machine which made life easier.
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Im confused, Stella TSP air electronic has a round black and white air foot with a black air line to the side of the machine like this.
or the earlier Lotus TSP has a electric foot and cable which is made of older style plastics, these are harder to find now but Sewingpartsonline.com carry an aftermarket one like this
No, not cheap parts but beautiful machines that with TLC work so well.
I have a constant problem on my Elna TSP Electronic, for no reason it get stuck and everytime I have to take in all the consultant says is I know what is wrong eveytime a bill. I am sooo frustrated.
you can buy Elna parts from www.whitesewingcenter.com, he specialises in the Swiss Elnas and carries range of stock. Or www.sewingpartsonline.com or www.sewusa.com stock Elna parts for both early Swiss as well as the latet ones. not sure if you meant a pressure foot or the foot control. If its pressure feet the generic low shank feet may well fit your mschine too once you buy the pressure foot adaptor for the newer clip on feet. There was a Lotus Sp and a star SP but the pressure feet were the same with the built in shank you attached with a thumb screw. the air electronics had the adaptor and clip on feet but they have same height and needle position so can use on earlier ones too.
