Question about Seagate (ST380011A) 80 GB IDE Hard Drive
Total size is not 80 GB IDE Hard Drive
I have 2 hd with the sam model ST380011A 80 GB. But they have difference size ( 74.53 GB and 31.50 GB)
When I run the software Active KILLDISK for DOS v4.1.
Disk 1 has 155061 cylinders.
Disk 2 has 65530 cylinders.
Disk 1 and 2 have the same tracks/cylinder = 16.
Disk 1 and 2 have the same sectors/track = 63.
Disk 1 and 2 have the same Bytes/secter = 512.
But:
Total size of disk 1 = 74.53 GB
Total size of disk 2 = 31.50 GB
Could you please show me how to fix the disk 2 in order to get the same size with disk 1 ?
I'm so appriciate your help.
Again thanks for you time and you help.
(Before i have 2 disk with the same size, but after i used the CD Seagate software and did some things that cause this problem. Now i don't have that CD Seagate)
    Brigadier General:
  • 6,966 Answers
Two possible solutions but both calls for another software/utility.
1. Use FDISK but you should be booting and running in DOS mode;
2. the other is Partition Magic which runs under Windows environment.
The idea is to delete the existing partition (that shows only 31.50Gb) and thereafter re-partition to the full capacity of the drive. of course doing so would erase the contents. Further, a format after the re-partition is required.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 19, 2008
  • Louie  Role
    Louie Role Jun 25, 2008
    Glad that your concern has been addressed.
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How to transfer data from seagate barracuda 7200.7 ST380011A 80 GB hard drive to another hard drive after crash?
You need a usb cable to harddisk. than a computer running linux. connect hd by usb to linux and copy.
Jan 13, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Need jumper setting for slave drive ide
If the drive is the Seagate Baracuda series, then simply remove all the jumpers from 8-pin jumper block and it will be a Slave drive.
If you want any other settings, the jumper settings are described here:
Jan 09, 2010 | Seagate (ST380011A) 80 GB IDE Hard Drive
My seagate 80 gb ide has got its MBR corrupt, help me out ihave tried almost all things, i want a direct MBR writer. please
the same problem i got few days back. but did;t find any proper sollution. The only thing u can do to format it.
Jan 06, 2010 | Seagate (ST380011A) 80 GB IDE Hard Drive
I have a st380011a 80g hard drive
you need diskmgmt.msc if its a slave drive unalocated.. create partition then format it OR .. if its to install windows on it. boot from xp cd . sometimes sata drives need F6 floppy motherboard driver for installation cd to see sata hd through chip of sata on motherboard.
Jul 14, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Trouble in HDD
I dont think its supposed to copy data in a boot process
copying and booting are totally different processes
Did you mean to say you have hdd issues
Feb 28, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Seagate (ST380011A) 80 GB IDE Hard Drive Logo
158 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
