Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Motor runs, output shaft doesn't. - KitchenAid KP2671 Professional 6 Series Stand Mixer
  • 36 Answers
When you hear the motor running and you can visually see the shaft does not, a gear is stripped. Which gear? You have to open/bring to a repair center to find out.
Posted on Nov 15, 2010
RESET A HOBART 140 QT MIXER
The V-1401 has a power bowl lift that is belt driven by the same motor that is used to mix. Remove top cover to check the belt. If belt is good and not slipping, is the operator handle working on /in the bowl lift gear box? If not, could be broken shear pin on handle or worn out parts in gear box. Next thing to check is the output shaft of the bowl lift gear box. If it is turning when the operator handle is engaged and the bowl lift jack shaft is not turning there is a broken shear pin between the output shaft and jack shaft. If everything is good to this point the bowl lift yoke has a large brass nut on back side of it that the jack shaft goes through. If the nut is worn the bowl lift yoke will slip, fall and/or jam. to unstick and lower the bowl , one can turn the jack shaft by hand. WARNNING : if the nut is worn enough the yoke can drop suddenly and it is very heavy.
May 06, 2015 | Hobart 140 qt Mixer Model V-1401 Used Mint...
How to replace motor in kitchenaid artisan mixer
Sounds like a worm gear problem to me, it's impossible for the motor (armature) to move far enough to not drive the gear. There are driving pins in the system from fuse gear to paddle.
1) in the fuse gear
2) inside gearbox above planetary joining shaft to bevel gear
3) through planetary and shaft
There is also one joining the little gear inside the planetary to the shaft, doubt you'd break that one though.
Jun 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Hobart 20QT guessing old a200 motor runs fine removed top cover to see but gears not working and mixer does not spin Any diagnosis Help greatly appreciated
The first vertical shaft has a brass gear that runs off the rotor. The ancient models had a spring loaded slip clutch built onto the gear. Upgrade it with a worm shaft kit which gives you a complete new shaft and fixed gears. I think it includes the upper and lower bearings. Maybe replace the grease if it has not been done. Or look for a sheared key on the worm shaft.
Feb 19, 2014 | Food Mixers
My D300T motor is turning but shaft is not. How do I open the shaft area.
Weird sound usually means something in the gear box. I found a copy of the manual which includes many exploded drawings; perhaps something in here might help:
http://www.bakedeco.com/ebay/pdf/HobartD300.pdf
Nov 23, 2013 | Hobart D300 Stand Mixer
Motor spins but blade doesn't
If there is a shaft sleeve available from Kitchen Aid you will need to replace that and most likely the chopping blade if there is any damage up inside it.
May 01, 2013 | KitchenAid 3.5-Cup Food Chopper KFC3511
The mixer runs but the beater doesn't turn. Drive shaft?
a gear or gears. their usually plastic and will damage before the drive shaft
Feb 07, 2013 | KitchenAid K45SS Classic Stand Mixer
I have a KitchenAid Professional 600 Series 6-Quart Stand Mixer, model KP26M1XBS, which no longer works. I was mixing pretzel dough and the mixer stopped turning. I initially just thought it overheated...
Don't worry about the Worm Gear for now. You have to make sure that the Motor
is fully functional by itself: Remove the Transmission Housing Cover (4 screws) and
the two screws holding the Motor down. Lift the Motor off the Worm Gear and set it
on the side (be careful of AC voltages from the Motor and Control Assembly).
Select Stir setting and observe the motor shaft. Is the Motor running? If it is,
Select other speeds to see how the motor performs.
With the motor now fully functional, you can now check the Worm Gear Follower
for worn out/broken teeth. Remember the motor drives the Worm Gear, it then in
turn drives the Worm Gear Follower (you may have to remove the grease to see it)
The Bevel Gear sits right on top of the Follower and drives the Attachment Gear.
Jul 06, 2011 | KitchenAid Food Mixers
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
Hobart A-200 Motor Direction
No, do not swap hot and N.
First, verify rotation. As the attachment shaft rotates, it should push the engagement pin into the keeper slot. Looking down on top of the mixer, the planetary should rotate clockwise.
If the unit runs backwards, does it start slow? Can you get it to run either way by giving it a push start before turning on the power? If so, your start switch is not working properly. (Which is my guess) Check your capacitor.
There is mechanical and electronic start switches. (Metal arms and a contact or a little gold rectangular metal can.)
Check it out and let me know what you find -- Mike
May 19, 2008 | Hobart A200 Stand Mixer
My electric stand mixer stopped mixing - the motor stills runs but nothing mixes
You hopefully broke a keyway. Which is usually the case. (The key on the shaft that engages the motor worm gear is the place to look. Sometimes the center shaft gives way. Check all three gears.
The transmission uses grease. So "taking a look at it" is not a easy task.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
Apr 30, 2008 | Hobart A200 Stand Mixer
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
75 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
