Question about Kenmore Washing Machines
I have a kenmore 600 top loading washer. over loaded it and now the white cap and clear cone shaped top of the agitator came off. Does the clear cap slide into the white cap. If so open end facing up or down. thanks
  • 35 Answers
Visit http://appliancejunk.com/forums/ they have more information on this/
Posted on Nov 15, 2010
Pieces of matal broke off under agitator in washer
THATS THE TRUNION ON TOP OF CONE SHAPED PART IT HAS 2 BOLTS AND A PIECE OF METAL THEY SCREW INTO ON THE CONE SHAPED THING THOSE BOLTS BREAK ALOT IN OVERLOADING
Apr 14, 2014 | Frigidaire FWS833A Top Load Washer
Does the Whirlpool, top loading lsr6332kq1 have a lint filter?
I will suggest you steps to check whether your washing machine has a lint filter. Follow the instructions below.
1)Turn off the washing machine and open the lid or door if you have a front-loading appliance.
2)Place your hand on the upper lip of a front-loading or top-loading washer tub and feel around the circumference for a flat tab. Pull out this tab, which is the handle for the lint filter. If you cannot find a tab on a top-loading washer, continue troubleshooting.
3)Unscrew the cap on the top of the agitator in a top-loading washer. The agitator is the center cone inside the appliance.
4)Pull the lint filter out of the agitator and rinse under cold, running water to clean.
5)Slide the filter into position as far as it will go. Replace the agitator cap if your appliance uses a lint filter in the agitator.
Mar 28, 2013 | Washing Machines
Stopped agitating
Its probably what they call "dog ears". My washer was doing the same i took off the cap on top of the agitator and un screwed the bolt. I grabbed that white piece out and there were four little plastic pieces that looked like dog ears and i replace them for under 1.00 and mine was fine after that.
Aug 25, 2011 | Kenmore 22422 Top Load Washer
Kenmore #110.26954690 won't spin in spin cycle
If it doesn't pump out water either, yes, first, I would suspect a broken belt (or motor coupling if direct drive).
Unlikely that the center cone is jammed.
Charlie
Aug 23, 2009 | Kenmore 22422 Top Load Washer
CAR KEYS IN MACHINE
If the keys are in the washer they woud be around the agitator It is unlikely that keys on a ring would be under the agitator but if youwant to check you can do the following:
FIX
1 Unplug from the wall
2 remove the plastic cap on top of the agitator hold one of the blades of the agitator and turn the top area counter clockwise and the top should unscrew allowing you to lift up the bottom blades
3 Reverse procedure
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
I have a kenmore 110 238 121000
remove agitator cap remove bolt in middle of agitator top section will pull of replace the 4 dogs (slightly off white objects whirlpool part # 80040)
Dec 22, 2008 | Roper RAB2121KW Top Load Washer
Agitator will not turn
yes ,,, they are called agit dogs ,,,,, replace and that will fix it
Nov 22, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Oasis, fabric softer thing exploded...
Okay...the cone actually goes inside the the two other pieces you mention. The cone is to be inserted upside-down. That is, the opening of the cone should be facing UP. The way this fabric softener dispenser is supposed to work is, you place fabric softener thorugh the opening of the dispenser. The cone actually holds it like a cup. When the washer goes through the initial spin cycle before the rinse cycle begins, the centrifugal force of the washer spinning forces the fabric softener out of the cone and into the wash tub.
The dispenser assembly should just snap right on top of the agitator. If the dispenser does not stay on securely any longer, you may have to replace it with a new one. You can find replacements at searspartsdirect.com. Just type in the same model number you provided and look for item number 1 under the "Motor, Basket and Tub Parts" heading.
I hope you find this information helpful. If you still have questions, please let me know.
PS It is also a good idea to periodically remove the dispenser and soak it in some hot water to get rid of accumulations of hardened softner. They will clog from time to time.
Sep 04, 2008 | Kenmore 24032\24036 Top Load Washer
Fabric softener doesn't dispense
Fabric softener dispensers are notorious for getting all gummed up and clogged. Remove the dispenser cup and soak in some hot water to dissolve all residue. While you have the dispenser removed check under the dispenser cap in the agitator for gummy residue as well. Clean with hot water. There should also be an agitator seal cap under the dispenser. Make sure the cap and rubber o-ring are seated properly. Last of all, if the dispenser has a cone shaped cup inside, make sure it is inserted cone-side UP. The cup is designed to allow fabric softener to roll down the sides of it, NOT hold it. I hope this helps.
Apr 09, 2007 | Kenmore 24982 Top Load Washer
Washing Machines Logo
52 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
