Question about Weather King 10AJA3601AH Air Conditioner
Furnace comes on and ignites but goes out when fan kicks on
    Scholar:
  • 77 Answers
There are a few things that can make a gas furnace short cycle when did this problem start and how old is the unit there are a couple of things to try it could be a bad rollout swith they look like little buttons just pull the 2 wires off and connect them to each other you can find them on both side of the burner box jump them out and try it again if this is the problem you can reconnect one at a time starting the furnace after each one to find the bad one then replace . try this first if nothing try jumping out the limit switch it will be in the middle of the furnace looks like a small board with 2 wires connected to it jump it out and start furnace to check.
Posted on Nov 15, 2010
Furnace wil, not ignite when calling for heat
For this answer, we need a model and serial number.
Generally, be sure the power is on, does the heat moving device run? (Fan for air, or pumps for water)
Nov 02, 2017 | Heating & Cooling
I have a coleman 7956c856 direct vent forced air furnace it ignites fine but the blower wont kick on
main fan should come on once furnace has heated up to supply hot air to the house. make sure proper voltage going to the fan. fan relay in board may be shot
Jan 29, 2014 | Goodman GMS90703BXA Heater
Furnace goes on red light stays on exhaust fan for heat chamber goes on gas igniter comes on but soon as gas comes on furnace kicks off have to shut off power for furnace for it to reycyckle but same...
Check your filter to make sure it is not plugged. If it is plugged - replace with filter recommended for your furnace. Every manufacture recommends you have your furnace checked and cleaned on an anual basis to keep itrunning safely and at it's top efficiency. If the filter is plugged or the blower wheel plugged, the furnace will shut itself off. Make sure all registers are uncovered - suppply and return registers.
Jan 03, 2011 | Heating & Cooling
Rheem 90+ NG Furnace. When furnace starts, draft inducer starts, ignitor glows and gas ignites. Burners stay lit for 10 seconds or so, then the flame reduces for a few seconds then goes out. Main blower...
Check the draft inducer air switch ( vacuum diaphragm switch) If the switch is opening when the burner starts, you might have a blockage on air piping coming into the furnace. Also prime the condensate trap on the condensate drain from the combustion fan. Also check the gas pressure, if your gas pressure is dropping, the gas pressure switch will shut it down. If it's too high the moment it comes on could raise the pressure in the furnace dropping out the combustion fan proving switch.
Oct 29, 2010 | Electric Circuit Breaker Kit for Furnace
My furnace kicks on and then goes off after one minute
if it goes on flame heat etc and no fan than shuts off check fan and relay if goes on and is trying to start check for fuel problem line bent filter clogged air in line clogged nozzle if fuel check ignition box and rods for short and oil build up
Oct 13, 2009 | Honeywell Heating & Cooling
Ruud Silhouette II Fails to Ignite
sounds like you have bad flame sensor or the sensor is in a bad postition. To get eliminate the lockout turn the power off to the unit and back on again. Look at the circuit board light and see what the troubleshooting code is.
Jan 13, 2009 | Heating & Cooling
Weather King 10AJA3601AH Air Conditioner Logo
204 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
