Question about Miele Refrigerators
Fridge freezing up in the back. Model no K 9752 ID
Huskee mower did half my yard ok, now sputters when blades lowered. No trouble with restarting, though it seems I have to pull the choke. Model # 13A8693G131 44-9752-6.
the spindles are freezing up,make sure your blades turn freely by hand and check for obstructions around the blades
Jul 02, 2015 | Garden
Very noisy fridge, back wall freezing up
Possible bad freezer fan motor. I need more information such as brand and model number
Mar 10, 2014 | Samsung RS2630WW Side by Side Refrigerator
Refrigerator
It depends on your fridge ice forms at 32 degrees and shelves one about 35 to 45 u have to know how much is in it also food wise lot on shelves id say before the snow flake on thermostat part because it can freeze soda cans if it's to low and stuff is pushed to far back
Dec 11, 2013 | Danby Compact Refrigerator DCR-101W
Kenmore elite coldspot model 106.74219400 freezes in the fridge never gets above 5 or 10 degrees and it never shuts off.
there is a flap in the refrigerator side usually near or behind the light bulb the freezer side is thermostatically controlled with the compressor being controlled. On the refrigerator side the cold air comes from the freezer side. when this flap is open the refrigerator will cool continuously, Check the flap or the duct assembly
here is an illustration of the part
http://www.repairclinic.com/Kenmore-Refrigerator-Model-10674219400-ID-927868-Duct-Venting-Parts
Apr 14, 2013 | Kenmore Refrigerators
Hi. The fridge part of my fridge freezer model HNMF2805AL80 is freezing my food , it is set at its lowest setting
My HNMF2805AL80 did same. Replaced control moduile - still freezing. Have just replaced fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just put sensor inside fridge at back - so far so good, will let you know.
Nov 24, 2010 | Hoover Refrigerators
Everything in Fridge side is freezing
your thermostat is probably defective. is an electronic or mechanical thermostat? there is a website called repairclinic.com. where you can enter your model number and get tech. help along with part #'s., its a very good website
May 08, 2009 | Refrigerators
Further questions about one of your posted solutions
make sure that the thermostat id correctly wired in
May 29, 2017 | Refrigerators
FRIDGE COMPARTMENT FREEZING
i had the same problem the sensor starts at the back of the pcb and snakes its way dow the back of the fridge into the freezer conpartment i ordered a new sensor thinking it was a temp sensor but turned out to be a defrost sensor compleat and utter hassel to fit due to the expanding foam i had to eventualy cut the block off that conects to the pcb and then reconecting it once i got the cable through the foam first 2 days seamed to work fine while there was nothing in it as soon as i put food in it again the fridge started to freeze everything again then about a week later it still ices up at the back the fridge but doesnt seam to freeze the food so much now so still unsure about it all
btw it was the exact same model and before i changed the sensor the light and the super light used to flash on and off
Dec 02, 2008 | Hoover HCA390FFK Bottom Freezer...
Kenmore Refrigerator Model #25357677791
stuck defrost timer/ thermostat. id go with both stuck because I'm looking at a diagram of your fridge now and there wired together.
i'd recommend changing both of them.
hope to be of any assistance.
Apr 26, 2008 | Refrigerators
Refrigerators Logo
41 people viewed this question
Top Miele Refrigerators Experts
mike cooper
jhnolson
Paul Bade
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
