Question about Toshiba Satellite 2400-S251 Notebook
After i replace dvd drive not recornizet - Toshiba Satellite 2400-S251 Notebook
    Brigadier General:
  • 8,909 Answers
You must download the correct driver for the DVD drive or it will not recognise it.
Does it load from a CD at boot up? If it does the DVD drive is a good one but if it doesn't check the type number of the drive.
Hope this helps.
Posted on Nov 15, 2010
DVD Wont Eject properly
Sound like you might have a bad DVD drive the only recourse might be just replace the DVD drive. If it won't open.. most often you can use a paper clip to open the drive. There is usually a small hole near the eject button on the DVD drive where you can insert a paper clip end to open the drive and pull out the DVD. After removing the DVD you can test if the drive eject or not correctly with nothing in it. If it doesn't, have the drive replaced.
Nov 06, 2013 | Acer Computers & Internet
My xbox 360 stopped game update due to fault in lighton drive replaced drive with replacement now all that show up is status code 3080-351f-2800-0f00-c000-0034 help
this is because the ORIGINAL dvd drive was swapped out by whoever modded it, or you had the dvd drive replaced, but it was replaced by a different dvd drive type.
the error code means that the dvd drive inside is not the original dvd drive. and that the console has been flagged.
the only way to fix this would be to have someone switch out the current dvd drive with a model that's the same as the one that was originally in it. after that the console would be able to update just fine.
I offer to replace dvd drives for $50 + shipping costs
Sep 02, 2013 | Microsoft Xbox 360 Console
Xbox 360 DVD Drive Not Reading Games Only DVD,CD after replacing the dvd rom
If you replaced the DVD-ROM drive yourself, some newer Xboxes do not recognize and/or function properly with older drives. I tried replacing a drive in an older Xbox with an older yet DVD-ROM drive, and it would not work. When replacing a DVD-ROM in an Xbox, it is advisable to use the same model drive, as the Xbox does strange things when you introduce different hardware. The url of a page is below that details the different drives that Xboxes use. See if your new drive is the same as the old one, and if not, that is almost certainly the issue.
http://www.llamma.com/xbox360/Xbox_360_DVD_Drive_Comparison.htm
Good Luck!
Jul 07, 2011 | Microsoft Xbox 360 Console
Can lite-on-ltn4865 48x play dvd movies
If your Drive is a CD-Rome drive, surely it cant, for the drive cant read dvd disc. Replace the drive of yours with DVD-Rom or DVD-RW in order to play dvd disc, DVD-RW simply has the added capablity to burn on DVD discs
Jan 12, 2011 | Lite On (LTN486S) Internal 48x CD-ROM...
DVD optical drive does not play all dvds all the time .one time it will play(same DVD)next time it won't.Also sometime finalize failure.Finally tray will not close w/dvd in the tray(sometimes).Is there a...
It sounds like the DVD-RAM drive is about dead. Panasonic did not make them to be very durable.
Panasonic sells replacements at a high cost.
Replacement drives may work from used models including:
DMR-ES15
DMR-ES25
DMR-ES45
DMR-ES46
Oct 01, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
Plays dvd but not games
When you replaced the DVD drive did you swap the circuit board (on the bottom of the DVD drive when you open it up).
Every DVD drive is "paired" with the Xbox 360, so you need to open up the DVD drives, and swap the green circuit boards on the bottom of the DVD drives. Should work after this.
Feb 08, 2010 | Microsoft Xbox 360 Console
Can you replace the internal DVD drive for LG RC797T? This is the 2nd time the internal drive has failed; LG wants more than the unit is worth to repair.
If the DVD drive is installed in a desktop computer, you can replace it with any branded DVD drive.
If the DVD drive is in a laptop, then you are most likely restricted to one from the laptop manufacturer.
Sep 11, 2009 | LG Computers & Internet
Dvd drive of my hp dv2000 is not working. it does not read dvd or a CD, and message pops up insert a CD or DVD. drivers are updated. in its hardware config. it says drive cannot be started. do need to...
There is a screw (tiny machine screw) that holds the entire DVD/CD assembly in place. Usually this screw is located by looking on the bottom of the laptop and has a little picture of a cd embossed in the plastic. Sometimes this screw is under a "lid" such as the cover for the RAM or HDD, depending on how your laptop is engineereed.
Find this screw, unscrew it, set it aside and them pull entire cd/dvd assembly from computer. Replace the cd/dvd drive into the slot you pulled it out firmly and quickly.
Turn on and test reading of CD/DVD.
If love is found, replace screw holding asembly, etc.
If no love, replace CD/DVD drive.
Other sources of love:
correct cd/dvd driver.
remove/replace cd/dvd driver
update cd/dvd driver
Mar 04, 2009 | HP LightScribe dvd640i (DVD640I)...
Can a user swap in a replacement DVD drive?
Any type will do but please ensure it has dual layer burning and comes complete with drivers
Jul 25, 2008 | Samsung DVD-VR357
HL-DT-DVD-RW GWA-4082N
Sounds like the board went on the dvd drive. Replace the DVD drive with a new one.
Apr 04, 2008 | HP DVD DRIVE DVD Drive
Toshiba Satellite 2400-S251 Notebook Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
