I have a canon mp272 printer scanner, it will not scan just displays e the scanning bar does not appear to move
SOURCE: Scan problems with Canon MX310
I had the same problem. After replacing the USB cable with a good one the scanner came back to life.
I suspect scanner has a higher requirement for USB data transmission thats why printing and copying work but scanning does not.
Posted on Sep 20, 2008
SOURCE: trying to scan, but keep getting error code
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Posted on Sep 05, 2009
SOURCE: trying to scan, but keep getting error code 2,162,0 My scanner pr
This works!:
noavatar_s.gif the_sunman
Rank: Apprentice
Rating: 94%, 4 votes
Posted on Oct 21, 2009
kerguney
  • 577 Answers
SOURCE: CANON MX 320 SCANNER PROBLEM
You need to control the scanner thru your PC with canon software that came with your scanner otherwise you cant scan anything..first open the printer/scanner software ,select scanner,then place your document and command "scan" on your PC..thats it..
Posted on Jan 15, 2010
SOURCE: My Canon MP510 scanner won't
You can scan to your PC from the printer buttons once the PC is set up for it. Two steps get it ready.
1. After pressing the button on the printer to scan, glance over at the computer screen. Select MP Navigator from the "Which program?" dialog box.
(If MP Navigator does not appear in the list, install it from the CD that came with your printer or download from the Canon website.) 2. Before clicking OK, check the "Always use this program" box. Next time you scan, it will automatically open MP Navigator and the scan will appear on screen.
Posted on Jul 31, 2010
Have mx510/512 canon printer/scanner/fax with new windows 10 computer. How do I scan documents or photo into my pc? no scan option when I open canon utility...
Step Connect the all-in-one printer to your computer through the provided USB power cable. Install all drivers that came with the Canon product. Without the drivers the computer is unable to import scanned images to your system.
Step Power on the printer and lift the cover on the top of the scanner bed. Position the image face down on the scanner glass, positioned in the corner when a green arrow points. Close the lid to secure the image.
Step Click the "Start" button, then choose "All Programs," "Accessories" and select "Scanner and Camera Wizard." This is a pre-installed application found on all Windows based computers.
Step Choose the "Scan" option, then select the connected Canon all-in-one printer and click "Scan" again. The image is scanned into your computer with a display of the picture on the screen.
Step Click "File" in the upper left corner of the desktop, followed by "Save." A save window appears on the screen. Title the image, choose a location to save the file to and click "OK." The image file now saves to your computer.
Aug 27, 2017 | Canon Office Equipment & Supplies
Canon PIXMA MP272 Faulty usb print port
The possible causes of your problem are numerous. Therefore, I want you to let Microsoft perform an easy three (3) click scan in an attempt to diagnose the specific problem. CLICK HERE
Please get back to me with any identifiable problems that might remain.
Ben
May 03, 2012 | Canon PIXMA Office Equipment & Supplies
How do I scan a page; the printer only wants to
Well have to look at the parameter of the printer as it is assumed that the scanner and then print and if it is not so problem is in the bar program and printer that scanning the display with the bar program of a printer just google in a printer CANON.
Nov 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I am trying to scan a doc on my canon MP272 and just get the numbers : 1, then E then 3. What's that mean?
According to the manual, the error code E, 3, 1 (cycles) means that the printer is not connected to a computer with a USB cable. If you have a cable connected, remove and reseat it, or try a different USB port on the computer.
If you're trying to scan, you need to be able to send the scanned image to a computer. If you're trying to copy, press the Black button for black/white copies or the Color button for color copies.
May 27, 2010 | Canon Office Equipment & Supplies
Jan 05, 2010 | Canon PIXMA MX310 All-In-One Printer
Same here
make sure the scanner lock on the rear is not engaged
Aug 17, 2009 | Canon CanoScan LiDE 90 Flatbed Scanner
Prints but No copy No scan
I have seen this before. The scanner does go bad on this model and the entire upper portion had to be changed.
Aug 12, 2009 | Canon Office Equipment & Supplies
Cant find lock switch for canoscan 8000f
The bar is locked in the a protected position. That the bar tha moves across the scan.. To unlock the scanner, find the lock on the back of the scanner, remove the tape securing the lock, and pull up on the lock. Rate this with 4 diamonds before logging off.
Mar 22, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Clicking Sound when scanning
sounds like the drive belt is missing a cog. With the curent price of scanners it most likely would be cheaper to replace it
Mar 03, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
836 people viewed this question
k24674
jasbo
jasbo
