Question about Cobra 19 DX IV CB Radio
I need to know how to tune my cb radio. I have a Cobra 19DXIV and I can only hear certain people and they have to be within 50 feet. I also need to be able to hear the people close to me and people that are a block or two away. Is there anything I can do without tuning the antenna. Thanks for your help.
    Guru:
  • 773 Answers
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to CAL. (CAL stand for calibrate.
3. Key the radio. (Important. Do not talk while keying the radio.)
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Posted on Nov 17, 2010
Tip
Cb ranges in mileage.
I have experimented for many years with various antennas and gain in the frequencies 26.965 to 27.405mhz. I have found that best performances on the Citizens Band is upper channels 37 or 39. This is where the band gets quieter and more close to Fm type communicating. Performance in antenna and hearing is best here. The Antron A99 sitting just 15 feet will get you 50 miles with decent results on a cheap Cobra 19plus or Cobra 21LTD. I can tell you by fact that a Cobra 21Ltd is equal to Cobra 25Ltd's(don't let noone tell you different) Its the same board, same calibration, same wattage plus its about $15 or so dollars cheaper than. Antennas have to be set for your frequency. I have found that the 8.5 ft(102 inch) steel whip performs best at approximate Channel #37 to 40. Homemade antennas built with a 8.25 ft element and 2 8foot rods down the side(ground) with a rod crossing the bottom at 1.5 feet. In the shape of a womans skirt.( Do not let the ground "skirt" touch the pole,seperate it by plastic PVC or milk jug with trash bag ties) I got 50 to 60 miles with this homemade job I would say had a DB gain of 10dbi. I have built home antennas that outperform Antrons. To be safe though and quick to setup is Antron A99 for about $65. Antrons have already set the frequency and low SWR. !!!DO NOT TUNE ANTRON A99 - IT BREAKS INTERNALLY!!! The average range one can get is say 10 to 50 miles average(best at night 10pm to 3 am) Don't expect any better with a Superior radio and tower or linear. A linear may kick hard within 25 miles but after that it fades into low in the distance. Unless you use 10 kilowatt or 25 Kilowatts(Electric bill will increase by $300 more--who needs it) A good power Mic on a straight radio Cobra 21LTD or 25 Ltd will be better than any mid-size linear say up to 250 watts. Your radio itself has potential with antenna gain of equal 25 to 45 watts alone. Mathematically your best with a Super Antenna and Height above 35 feet, plus heavy grounding(chain link fence buried into earth 20 X 20 feet about 8 feet down(a rod 8ft also will work) or if possible a Junk car buried into earth 8-10 feet under your Antenna. Use heavy gauge thick LOWLOSS 50 ohm coax 95% shield less than 100 feet to achieve max power out. Lengths in coax are great at 9,18,27,36 up to 72 feet(No higher than needed) The old timers swear by 72 feet. Antenna Height say: 45 feet tower with 72 feet of Coax is the usual Base setup. FCC restricts antenna towers to 60 feet above ground. No more than 20 feet above your house somewhat(when attached to house roof). No need to put $10,000 dollars in a setup with no more range than others. A mobile radio(Tuned) with Antron A99 will about outdo all Base station radios. Hope this helps you. 73's to you all.
on May 04, 2011 | Radio Communications
How can I make the 19DXIV VHF capable
There is no way to make that radio VHF capable, CB radio's operate in the AM band, and most, if not all VHF radio's operate in the FM band. CB radio's are not capable of VHF frequencies either, VHF is considered around 40MHz and above, CB radio's operate between 26.965 MHz and 27.405MHz that is considered 11 meter band HF. CB radio's are not broadbanded enough to cover anything that far away, expecially the newer radio's, as most of them are controlled via a microcontroller and PLL tuning circuit. the 19DXIV is a great little radio, but will never be able to operate in or even around VHF. sorry.
Oct 21, 2012 | Cobra 19DXIV 40 Channel Mobile Compact CB...
What are the basic codes used on a CB Radio?
I found a very precise chart that lists all the codes.
Jul 18, 2012 | Cobra 19 dx iv 40 channel cb 05/10 19dxiv
How do I reset my Cobra 19DXIV CB radio to factory Settings
If you are ask that vague a question you should not open case. However that is your business.
pages 14, 15, 16 http://www.cbtricks.com/radios/cobra/19dx_iv/graphics/cobra_19dx_iv_sm.pdf
and of course all the tools listed in the link.
Jun 28, 2011 | Cobra 19 DX IV CB Radio
I want to know how to tune my cobra 19 3 ultra cb so that i can recieve and transmit
you can't tune the radio. You must tune the antenna. I have a generic thread which explains everything you need to know about tuning your antenna.
See here. Hope this helps you.
Aug 22, 2010 | Cobra 19 Ultra II CB Radio
I can not get out on my cb i can hear them but they can not hear me its a cobra
turn the mic gain all the way up. Make sure the antenna has been tuned for best SWR.
Take your radio to a CB shop and have them peak and tune it.
Mar 29, 2010 | Cobra 19 Ultra II CB Radio
Tuning troubles
I wrote a couple of articles that have all the info you need on a forum.
Here are the links.
How to tune SWR
High SWR causes
Hope this helps.
Nov 22, 2009 | Cobra 29 LTD CB Radio
Cobra 19 DX IV CB Radio Logo
1,534 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
