Question about ASUS K8V-SE Deluxe Motherboard
Boots up crashes 3-4 times starts working then crashes after several minutes. Have replaced cpu & processor
  • 1,179 Answers
If the CPU is working then I would put this down to either a corrupt windows installation or faulty RAM. It could also be a fault due to heat, but if you have that in check then I think it's the Windows install or RAM.
To test the Windows install, power on your PC with all hard drives disconnected, power included and if it is stable on the screen that says NTLDR is missing or insert system disk then this confirms the windows installation is corrupted.
damnor01
Posted on Nov 15, 2010
Are you getting a BSOD when your system crashes?
If so, try uploading the minidump files for analysis at somewhere like Motherboard Forums and then someone should be able to see what is causing the crash.
Like damnor01 said, it's probably a problem with Windows (usually drivers) - but if you can swap out the RAM or run MemTest, I'd do that too.
Posted on Nov 18, 2010
Display driver crash when playing sims 3
Hello, there are many reasons for a computer to lag and crash. But most probably is because the cpu could be working at 100%. If the cpu is working at 100%, you need to find out if it's Windows, or some kind of malware.
Please, search for "My cpu is working at 100%" and some instructions on how to identify the problem should be display.
May 14, 2017 | Dell Inspiron Computers & Internet
PC keeps shutting down and then re-boots automatically about every 20 minutes .
Shut it down.
Remove the power-cord.
Buy a can of compressed air ($3 to $5).
Remove the side panel(s).
Hold the can of air vertically (do not tilt it),
and blow away the dust from everywhere: inside the power-supply,
between the "blades" on the heat-sink & fan on top of the CPU.
Replace the side panels.
Reconnect the power.
Start it up.
Click Start
Right-mouse click on My Computer
Choose Properties
Choose Advanced.
Under "Startup and Recovery", click "Settings".
Click to disable "Reboot Automatically".
The next time that it crashes, what error-messages _stay_ on the screen?
Oct 10, 2009 | Microsoft Windows XP Professional for PC
Amd phenom faulty
Replace cpu fan , failed cpu fan might have caused CPU stoped working. If you are sure about the CPU fails then replace the CPU. If the problem seems continues after that too, then PC might have failed to boot due to other reasons. What shows on the screen once you power on the computer? There could be , motherboard , or harddisk faults too. Try unplugging other parts and see if the computer boots from CD or USD flash or floppy drive!! Once you know that motherboard works then replace the CPU. There could be BIOS setup problem. Did you check the BIOS for harddisk is set properly.
Sep 17, 2009 | AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+...
System powers on but no video
Check the cmos battery, or replace the battery by a new one
Jun 17, 2009 | E-Machines eMachines W2686 PC Desktop
ATI RADEON x1650 PRO 512 Crash...
Their is a reason that it crashes and it is not because of the game if  it crashes at other times too. Toom much HEAT is usually the problem. Look for slow or stopped fans. Dust on the heatsink.Run the antivirus. After that clean and defrag the hard drive. Let me knw that that did not take care of the problem.
Jan 18, 2009 | ATI RADEON X1650 Pro, (512 MB) PCI...
Problem Regarding Booting
due to the increase in temperature inside the cpu for the protection of the motherboard and components it might not be getting started ..
this happens if the processor fan is not running properly or if it stucked due to some dust or obstacles ...
try cleaning it after separating heat sink and processor ....
after refitting the processor trying booting it should work ....
if needed replace the processor fan ..
regards
-Dileep
Nov 27, 2008 | Intel D845HV (735858149143) Motherboard
Computer hangs after 5 minutes from boot
Check the CPU fan (working) and heat sink as these over time clog up with fluff and dirt overheating CPU also check the rear of power supply for blocked ventilation holes
Jul 20, 2008 | Intel Pentium 4 1.7G, 1.7 GHz...
My acer t310 beeped several times an switched off the cpu is very hot
hi
did u try to to boot it again and was there long beeps again.
if yes then ur RAM has crashed.
if no then let me know the whole detail how and what happened then may be i could help further
Jun 30, 2008 | Computers & Internet
Failure to boot after several hours of operation
assuming you set the date and time, the error message checksum can refer to incorrect memory timings along with the front side bus speeds, so check the processor bus speed eg 533MHZ or whatever and check the memory speed as if they are different you wont get it to boot, you will need to reset the bios if you cannot get it to run at all.
Sep 09, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS K8V-SE Deluxe Motherboard Logo
97 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
