Question about Dell OptiPlex GX280 PC Desktop
Can i change the power supply of my optiplex gx280 to a standard atx power supply 500w or more?
  • 3,940 Answers
Yes, Opti GX280 is a standard ATX powersupply
Posted on Nov 15, 2010
  • Marlon Mendoza
    Marlon Mendoza Nov 15, 2010
    my gx280 is a tower type,so i can use a psu 500w or more?tnx very much
  • IQUIT Nov 16, 2010
    yes, standard ATX fits in the 280 tower, it it was the desktop, then you'd need a specially designed one.
I need a replacement Sunbeam/Black Steel 480W Power Supply made by casegears
If it's a standard ATX case, then any power supply is compatible.
equal or higher power output is fine.
so a 500w will still only use the power needed by the hardware.
Mar 20, 2014 | Dell Inspiron 518 Desktop Computer
Where can I find power supply for HP model ATX300-12ZBD
There are lots of ATX power supplies on the market. You do not need to use a HP 300 watt power supply. Just purchase one that suit your requirements - 300 watt or more. These power supplies have standard mounting holes.
Mar 10, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
I am looking for a schematic for a Dell Optiplex GX280 power supply. The supply is model HP-U2106F3.
I just replaced my GX280 power supply (mini-tower) with the following 400W for $30.
http://www.cputopia.com/hp-400w-dell-optiplex-gx280-mini-tower.html
The only place I can think you will find an actual schematic for the PSU is from the manufacturer.
Feb 13, 2011 | Hi-Pro Refurbished HIPRO POWER SUPPLY FOR...
Optiplex GX280 - loud fan at start up and amber power light - does not boot
Most likely you have a bad Power Supply, replace your power supply
Thanks
DiegoTech
Nov 14, 2010 | Dell OptiPlex GX280 PC Desktop
I recently purchased a Dynex 400 watt atx power supply for my Dell optiplex gx280 (slim form). The reason I did this is I have a new PNY geforce 8400 GPU and my old power supply is only 160 watts (1/2 the...
Sounds like the power supply is not compatible with the motherboard. If the motherboard can't support a 400 watt powers supply you will either get a blinking light or nothing at all. Those optiplex's use a proprietory power supply because of the pin connectors and how a power supply is supposed to fit in there. If you can't find a 400 watt power supply that fits then get a hold of Dell and see if they sell one for that computer.
Sep 22, 2010 | Dynex 400-Watt ATX CPU Power Supply
No power up, there are no +12 and +5 volts
Sounds like a power supply failure, System should accept a standard ATX power supply
http://support.dell.com/support/edocs/dta/P60L/00000023.htm
Jan 13, 2010 | Dell OptiPlex GX260 PC Desktop
Dell Optiplex GX280 - On power ON , no Fan movement no display
Confirm no leaking or bulging capacitors on your mothboard.
refer to here
http://en.wikipedia.org/wiki/Capacitor_plague
As this was a common problem with the GX280.
If found, you will need to replace the capacitors.
The other check is to make sure the heatsink is fitted correctly, perhaps reaply the thermal paste if you have any. I know that high temps would switch the GX280 off.
Jul 15, 2009 | Dell Optiplex GX280 (99301) Motherboard
Dell Optiplex GX280 Video Card Install Problem
You hit that one right on the dot.  ATI website showed the specs for that graphics card you installed as needing a 300 Watt power supply.  Good news though... I researched newegg.com and I believe I found your 300W power supply.  There are 4 different Optiplex gx280 designs with 4 completely different power supplies.  Since you bought the low-profile video card, I believe you have the slim computer case and this power supply should work for you...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817374002
Good Luck
Jun 10, 2009 | Dell OptiPlex GX280 PC Desktop
PSU problem
The total connection is two part if you disconnect 20*pin one part then four part is other part. when you connect 20 pin in mother board .the four pin connect anther port. then the power supply is on.
Jan 24, 2008 | Computers & Internet
Dell OptiPlex GX280 PC Desktop Logo
140 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
