Question about Whirlpool Dryers
Hi, I have a Whirlpool dryer mod LHE780 that is running without heating up. Can you suggest a fix?
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Nov 15, 2010
I have a whirlpool gas dryer there is no heat and the dryer does not shut off
best advice is call a service man as GAS is dangerous to mess with
Apr 13, 2015 | Whirlpool Dryers
I have a whirlpool dry mod#5636 in my home I have 110 the cord on the dryer is for 220 can I change it to 110 and will it work right..
No it will not,dryers with 110 volt plugs heat on gas,220 dryers heat with electric,putting a 110 vac plug on dryer for 220vac,the motor will run but it will not heat
your 2 options are
1) have a electrician come and run 220 vac circuit
2) purchase a gas dryer
Jul 28, 2011 | Whirlpool LER5636P Electric Dryer
I have a whirlppol gas dryer Mod-LGR7648KQ1 which runs but does not heat up. I dont know if it's a sensor, the ignitor or heating unit or even the thermostat. It's old and I'm not looking to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 18, 2011 | Whirlpool Dryers
Whirlpool dryer mod.yleq5000pwo runs but won't heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 21, 2010 | Whirlpool Dryers
Whirlpool Dryer heats and hums, but does not spin. Mod WED8300SW1.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 13, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
Dec 12, 2009 | Whirlpool Dryers
Whirpool Dryer Heating and timer issue
YOU NEED CHEK:
1-thermal fuse.
2-heater element.
3-hi-limit switch.
4-temp sw.
5- electronic control.
Oct 05, 2009 | Dryers
Heat will not stay on
Hi, very common problem.
The problem is with the gas coils.
When they get weak, they only come on for about 10 minutes and then the machine will blow cold air. There are 2 of them with one being the booster coil. They come in a pair and run less than $20.
Best of luck. Please e-mail me if you have any other questions.
Sep 15, 2009 | Whirlpool LGN2000LWH Gas Dryer
Dryer only heats when empty
Replace the 2 coils on the burner valve . Without model number , cant give you part number .
Jul 28, 2009 | Whirlpool LGR5636L Gas Dryer
Element heats, dryer tumbles, no heat in drum, never shuts off
Hi, If the dryer heats but will not advance in either time or auto cycles, you need to change the timer.
You can test to see if the timer is getting voltage. Remove the top rear panel and locate the two wires going to the timer motor. There should be 120V when the dryer is running in time dry.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
87 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
