Question about Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725
My husband accidently was turning the freezer off when he shut the hot water heater off to save money. Now after found water in freezer it runs 24 hrs,won't shut off and the air from the back vent is only barely coming out on the right side. Is there a reset button to push?
    Brigadier General:
  • 3,917 Answers
Thank you for contacting Fixya.com.
Probably the drain tube at the back of the fridge is plugged and not letting the condensation on the freezer to run out. So check for this tube on the back that is where they plug up. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom or inside of the refrigerator. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Please get back to us if you have any further query.
Have a nice day.
Posted on Nov 15, 2010
True Freezer T23 compressor will not stop running
Have him check the t'stat. And freon lines. I believe the t'stat is the problem. Are the door gaskets ok and does it seal properly when closed. The fan should always run, so this could be in the rewiring. I am assuming you will be working out of a freezer where the working temp is a little higher.
Feb 16, 2013 | True T23F Freezer
Ice build up in the bottom of a woods upright freezer. have romvoed ice and taken hair blower to the tube and water drains. Does not solve problem ice continues to build up
ic Defrost Thermostat
This is the component that controls how long the heater stays on when the machine is in defrost mode. Say the defrost cycle is thirty minutes, the heater may only be on for ten of those thirty minutes on the timer controls. On Adaptive Defrost Controls, when the heater shuts off, shortly after the machine exits defrost mode. Basically if the heater only stays on for ten minutes, the whole defrost cycle will only be about 12 or 13 minutes longe is continueing to build up due to one of the defrost cycle parts not fucntioning properly this is the most likely piece to be causing your ice up issue do a continuity test on the thermostat to assure that it is working properly
Basically when the heater comes on, it starts to melt the frost on the evaporator. Once all the ice and frost is gone, the temperature behind the panel will start to rise. Once the temperature behind the panel rises to a certain temperature, the thermostat will break the current of electricity going to the heater. Bam, it shuts off and prevents your freezer from becoming a sauna, or an oven. I'm sure you get the drift. The heater is on the bottom of the evaporator coils and the defrost thermostat sits on top of the evaporator coils.
Defrost Heater
This is the last component in the defrost system. This one should be pretty simple. By now if you have read this far you should already know what this does and how important is it. Some defrost heaters are a coil of wire in a glass tube under the evaporator coils. Works like a light bulb basically. The other style looks like the bake element in your stove. They both get red hot either way and melt the frost
Defrost control or timer.refrigerator-defrost-timers.jpg Some refrigerators have a defrost timer. This type works like a clock. Every eight hours or so the machine hits the defrost spot and that's when defrost occurs
Some refrigerators have an Adaptive Defrost Control. This is what makes a refrigerator energy efficient. It varys the length of time it takes the machine to go into defrost. So instead of the energy hogging heater 240545401adc-board.jpgcoming on every eight hours, it may be 24 hours, 18 hours, 10.5 hours, who knows. It depends on how many times you have opened the doors, how long the compressor has run. This is good because the refrigerator may not need to go into defrost every eight hours. Now you are saving energy.
and lastly there is the fan also if it is not working will not allow the flow of air to leave the inside of the freezer. Continuity test can also be done on the heater as well and the least likely would be the timer to go bad in some models they have a board on the back of the machine instead of a defrost timer if you have any further questions please message me back and please remember to rank how this opinion has helped as well Thanks again Rick
Jan 15, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Ive got an upright Whirlpool freezer that doesnt want to defrost. It takes about two weeks for the evaporater and defrost coils to totally ice up and then I have to take all the covers off and throw warm...
Fixing the defrost circuit is relatively simple. It made of three things, the defrost heater, the thermostat and the timer. The usual parts that fail are the heater and the timer. The first thing to check is the defrost timer. It looks like this:
slamfix_25.jpg It can found either near the compressor or in the little box inside that controls the temperature. What it does is that it powers the compressor for about 8 hours and then turns off the power for 45 minutes to allow the defrost heater to melt the frost buildup. The timer is run by a little motor. Often the motor stops working and the freezer is either stuck running the compressor continously or the defrost heater.
On the side of the timer is a little cam that you can turn with a straight blade screwdriver. Turn it until it clicks. When it does, the compressor should shut off and the heater should start to heat up. If you hear the crackling of ice melting, then the problem is with your timer not working. If the ice is not melting then the problem is either with the heater/thermostat. Check to see if the heater is burned out or use a meter to check continuity between the heater and the thermostat. If it is open then replace the heater and thermostat.
Any of the defrost parts should be available from an appliance supply house or online. Hope this helps you.
Jan 11, 2011 | Whirlpool 19.6 cu. ft. Commercial Freezer...
I have a true 2 door freezer with bun rack rails...it is runninig between 7 degrees up to 59 degrees...we vacumed the vents...do we need more coolant or what do you think...it is about 4 years old and...
Vacuuming the coil is not usually sufficient to clean them properly. Hold a flashlight behind the radiator on top of the freezer to see if you can see freely through the coils. If not, the best way to clean the coil is to spray coil cleaner on there and flush with plenty of water. It is a mess but it will get the grease off the coild. If you do not have gauges to check the pressures of the refrigerant (lets call it freon), you can get a good guess by doing the following: Get a ladder, climb up so you can see in the top of the cabinet where the compressor is located. It looks kind of like a bowling ball. There will be one small copper line and one large copper line running from the compressor. The small line is the high pressure line. It should be hot enough to burn your finger. It then goes through a small pan where it evaporates excess water, then to a "radiator" which has a fan running behind it. If the machine is running this fan should be on. The small line then runs into the freezer box. At this point the line should be warm, not hot to the touch. If this is not happening you are probably low on freon. The other copper line on the compressor is returning from the freezer box to the compressor. It should be very cold to the touch. It should have moisture collection on it. If this is not happening you are probably low on freon. Other factors can effect your freezer. Make sure the fan near the compressor is running. Make sure the fan or fans inside the freezer are running. They will stop running when you open the door, so hold the door button in when you check the inside fans. Check also to see if there is a build up of ice on the inside coil. Your freezer should run a defrost cycle 4 times a day to remove the ice. If it has ice it will not run properly. If you can remove your product for 24 hours and shut the freezer down, prop the door open and the ice will melt. On restart if the freezer goes down to 0 quickly (30 minutes) it was probably frozen over. This may indicate a bad defrost timer or heater. Try these things.
Sep 08, 2010 | True Freezer TG2F-2S
Not freezing
Either the defrost circuit has failed or the refrigerant is low - my money is on the defrost circuit.
Most defrost circuits have three main parts:
1) defrost electric heating coil
2) defrost terminator
3) defrost timer.
The heating coil and terminator are in the freezer compartment - behind a protective panel. The heater is usually piggy-backed on the freezer coil and the terminator is in contact with the freezer coil to detect its temperature. The defrost timer is a simple assembly of a clock motor with switch contacts that can be located anywhere the manufacturer desires. The timer turns on or enables the defrost circuit every 8 or so hours for up to 30 minutes give or take.
When the timer has enabled the defrost cycle, the cooling mode ceases; the compressor shuts off and power is sent through the terminator to the heater. The heater warms and melts any ice build up on the freezer coil. The water drips to a pan and flows down the tube to a pan under the fridge - where it is evaporated off. The heater warms the freezer coil until either a) the timer returns to cooling mode or b) the terminator senses a preset rising temperature on the freezer coil. Once either condition is present, power is interupted and heating stops. The compressor is energized through the adjustable thermostat in your fridge. Since it is warm, the compressor turns on and cooling begins.
If any of the components listed above (1,2 or 3) have failed, the defrost cycle never warms the freezer coil and the ice never melts to clear the freezer coil as intended. Air can not be circulated through the freezer coil since it is choked with ice, so even though the compressor runs, the fridge and freezer spaces never get colder. The adjustable thermostat never sees the temperature you've set so the compressor never shuts off.
Water dripping in the fridge is melting ice from the freezer space - as the freezer is not getting colder - only the protected space around the freezer coil is.
To fix this, you'll have to get the service manual or schematics for the fridge to determine where the parts are located and do some troubleshooting with a multimeter after disassembling the freezer compartment and wherever else to access the timer if needed. This is not a good first appliance repair job for a DIYer due to the danger of refrigerant and testing live electrical parts in closed in spaces.
I hope this helps.
May 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
Upright Deep Freeze Stopped Working
the compressor relay is gone For a few dollors you can still save it.
Mar 27, 2017 | Kenmore Freezers
GE TBX21ji Refridgerator/Freezer Factory Icemaker quit making ice
Normally, when the temp of the icemaker gets to about 14 degrees F, the icemaker goes into the harvest mode, turning on the mold heater and attempting to eject the cubes. When the heater has warmed the mold sufficiently to release the cubes, the ejector can continue and push out the cubes, then the icemaker fills with fresh water to beging to make a batch of ice again. Manually starting the cycle as you have done only allows the cycle to start without the temp sensor seeing the 14 degrees. The mold heating generally takes a couple minutes. If your mold heater or the temp sensor are not working, you will have to replace the icemaker, as they are not available as a repair parts.
Jul 04, 2009 | Freezers
Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
Jun 15, 2008 | Frigidaire Freezers
Freezer doesn't freeze
it could be that something in the defrost system is faulty. in the compressor area find your defrost timer, using a flat tip screwdriver advance the timer until you hear aloud audible click and the freezer shuts off. now wait a minute or two and feel for heat at the heater (careful it gets red hot) if the heater is on the timer is bad, if no heat you will need to check for continuity on the def thermostat and defrost heater to determine which is bad (most likely it will be the thermostat.)
i found this parts breakdown http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/FRIDGES/517704%20Series%20R%20VERTICAL%20FREEZER%20N388.pdf
that should help.
the def thermostat is item #11 on the evaporator and components page 9 and 10
good luck
Dec 15, 2007 | Freezers
Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725 Logo
65 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
