Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I have inserted the Cruzer Micro 2GB flash disk, its detected as unknown device i've gone to device manager tried checked driver details it says no drivers i've tried reinstalling the U3 launchpad but it says insert a U3 smart drive.....the light goes on when the flash disk is pluged in....help!
  • 35 Answers
I would try a different computer first if that does not work it may be the drive is bad and would need replacement. For the most part memory has a good warranty so you may be able to have it swapped by contacting the manufacturer.
Posted on Nov 15, 2010
  • bgahwita Nov 18, 2010
    Thanks! that worked i used another pc. So that means my drive is faulty? But i use other flash disks and they seem okay....?
How to reformat a flash drive
Hi jabbbbbb6,
The Cruzer Micro is a flash storage device that connects to your computer's USB port. It comes in various sizes and fits on a keychain. If you want to erase the drive, you can perform a reformat from within Windows' Disk Management utility. After you reformat the drive, you do not need to reinstall any drivers because Windows automatically detects the device.
To Reformat, please follow the instructions:
1. Insert the Cruzer Micro to an available USB port on your computer. Right-click "Computer" and select "Manage." Click "Disk Management" under "Storage" on the left pane of the window.
2. Right-click your USB drive on the list of drives and select "Format." Select a name and file system type for your drive.
3. Click "OK" to reformat the drive. Click "Start" and "Computer" to access your drive.
Rate this accordingly.
Hope it helps.
Thank you for using Fixya.
Oct 06, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
PC is not detecting my Cruzer micro pendrive but
I have experienced this type of problem before. But what I did was to install an Avira Anti-virus on a system using windows xp and eventually it did open.
So you can try it as well or insert your flash into any another system that had a strong anti-virus which can enable you scan/format the drive.
Best of Luck
Nov 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I accidently deleted the partition with my cruzer
Ok turn on PC, and have that drive plugged into the usb port. Find your my computer icon, right click on it and goto manage in the menu. This will open the computer manager, in the list on the left you will see disk manager under Storage. Click on disk management, in the window on the right you will see the different Hard Drives and Storage devices there. Look for the one that does not have a drive letter and may state unknown. Right Click on the device and Mark Partiton as active, then also format the drive. Viola! you should now have your Pen Drive showing up under my computer.
Oct 04, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My 16 gb cruzer thumb drive lost data and says 0 info on the drice, won't reformat od show/do anything can it be recovered or fixed?
There are 2 support links for checking the Cruzer's connection status:
  • The Device Manager check
Flash drive could not be detected by the computer:
http://kb.sandisk.com/app/answers/detail/a_id/10
  • The Disk Management check
Flash drive could not be detected due to "drive letter conflict":
http://kb.sandisk.com/app/answers/detail/a_id/76
When more help is needed just post a comment.
Sep 29, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro USB I/O device error
I would recommend plugging your Cruzer into another computer. It's possible that your computer has corrupted or incorrect drivers for the flash drive. This is one cause of the yellow alert in Device Manager. If you move the flash drive to another machine and it works, you can save your data and make a backup copy. If your Cruzer doesn't work in a different computer (I would try at least 2 other working computers), it's possible that the flash drive is faulty.
May 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk pen drive cruzer 2gb not detected by the computer
first insert your sandisk pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Mar 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do you use sandisk cruzer gator flash drive?
Try downloading the U3 driver, if you haven't already.
First plugin the sandisk to your usb port, and then check from WindowsExplorer, does your sandisk cruzer detected? you'll get a new driveletter besides your local drive or named "removable disk".
If you do see it then just do format (you'll lose the U3), copy, store, overwrite it again and again as you like.
If you still need the U3 application, pls read this:
http://www.u3.com/support/default.aspx#CQ1
You possibly haven't installed the driver properly.
If a wizard that comes up as soon as you plug the devicein, Just let it detect the device and then go to Control Panel, and System,and Device Manager, and double click on the devicedriver, or if it isn't there, double click on the unknown device withthe yellow exclamation mark and hit the Driver tab, Install Driver, andchoose the 'Let me choose the driver' option, and navigate to where youunzipped that driver you downloaded to, and click on the driver, wait forit to finish installing and reboot.
Let me know how you get on..
Good Luck!
Chris (ziraffa)
Dec 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
If i insert the flash drive into my system..but is vista....it will search for drive it wont get ...and i dont know what to do
First plugin the sandisk to your usb port, and then check from Windows Explorer, does your sandisk cruzer detected? you'll get a new drive letter besides your local drive or named "removable disk".
If a wizard that comes up as soon as you plug the device in, Just let it detect the device and then go to Control Panel, and System, and Device Manager, and double click on the device driver, or if it isn't there, double click on the unknown device with the yellow exclamation mark and hit the Driver tab, Install Driver, and choose the 'Let me choose the driver' option, and navigate to where you unzipped that driver you downloaded to, and click on the driver, wait for it to finish installing and reboot.
Good Luck!
Chris (ziraffa)
Dec 04, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk cruzer micro 2gb not detected
You only need to use disk management !!
for Win_XP:
Right click 'My Computer'.
Choose 'Manage'
In the left pane, under 'Storage', Choose: 'Disk Management'.
When device is connected it will appear as: 'Disk xx - Removable'.
It should be not allocated (Black Line), so you only need to created a new partition and format it.
Good Luck !! :-)
Nov 02, 2007 | Computers & Internet
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
538 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
