Question about ASUS P5KPL-AM SE Motherboard
My pc is beeping - ASUS P5KPL-AM SE Motherboard
  • 1,179 Answers
Your PC is beeping, this is a good sign as it shows it is alive, a single beep is good as this represents a POST signal and all is good to go. However a string of multiple beeps represents that either your RAM is not recognized or it is not connected. Clean the RAM module fingers with tissue paper and reinstall. This is all explained in my published guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Happy testing
All the best
damnor01
Posted on Nov 15, 2010
I have a Acer Verton E430 Desktop. Suddenly upon restart after the initial beep and Acer splash screen returns to restart with one short beep and process continues on and on.. Advise how to solve.
One short beep can be DRAM refresh failure.
  1. Remove RAM memory, Graphics card, other Plug-in cards, and Drive cables from your mainboard.
    Only CPU + Fan + Power cable are installed on the mainboard.
  2. Power on the PC, and listen to the beeps:
    • no beeps => Power supply, CPU, mainboard or BIOS is most likely defective.
    • some beeps => remember the beeps and next step.
  3. Power off the PC, and insert the RAM memory.
  4. Power on the PC, and listen to the beeps:
    • no beeps => RAM incorrectly installed.
    • same beeps as before => RAM is most likely defective.
    • beeps have changed => next step.
  5. Power off the PC, and insert the Graphics card.
  6. Power on the PC:
    • some beeps => Graphics card is most likely defective.
    • blank screen =>Graphics card is most likely defective.
Dec 02, 2014 | Acer Computers & Internet
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
When I turn on my pc it beeps three times and there is no signal to the monitor. What do the beeps mean?
hi,
please write your beep description
ex: one long beep two short beep
repeating short beep
Sep 11, 2010 | Gateway 838GM (RB838GM) PC Desktop
Diagnostic beeps
try google on motherboard error beeps good article and see if you can match up the beep pattern. it says 2 short one long for video problem. good luck
May 23, 2010 | E-Machines eMachines Desktop PC
When booting the screen says no signal and the it begins beeping intermedately
I think the graphics card has become unseated as the PC does not need a monitor to start up so there would be no beeps; Here is a list of beep codes with there meanings.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Apr 19, 2010 | Gateway Profile 5.5 PC Desktop
When I power up my acer PC I get a beep beep beep
Open your cpu cabinet cover.
Then Refix RAM memory on mother board.
Remove pci cards from mother board if any.
Make sure motherboard is not ground with cabinet.
Reattach ATX power connector to motherboard.
Pull cmos cell from motherboard for 10 minutes then refix it .
Then it work again.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 06, 2009 | Acer (AST135-U-S3100) PC Desktop
My presario 1600 just beeps when I turn it on...
there are 4 kinds of beeps that the pc produce when you turn it on, base on your beep it is indicating that the memmory is damage,
a single beep means the pc is ok
and your beep is memmory damage
a long beep pause and then beep long again means video card damage
if the beep sound like a firetruck the processor or memmory is over heating
Sep 24, 2009 | Compaq Computers & Internet
Definition of beep codes on power-up beep-------beep beep beep-------beep beep beep---------beep on a t2542 emachine
Sounds like a video error. It may be caused also by a bad memory, but I suspect problems with video.
Sep 07, 2009 | E-Machines eMachines Desktop PC
On startup it beeps and wont startup. i hit F12 and it works fine now. thats all i did. so what could be the problem? i've already replaced a power supply about a year ago. and also my dvd player is kinda...
On startup beep how many beep do you hear?
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Hope it Help you out ^_^
Jun 29, 2009 | Dell XPS 200 PC Desktop
PC will not reboot.
Check
Click on underlined items for further information
1 Beep
If the PC boots properly, then this beep is normal. It is an audio cue that the PC has passed the POST and started to boot.
  • (AMI) Memory problem
  • (AWARD) Memory problem
2 Beeps
3 Beeps
  • (AMI) Memory or motherboard problem
  • (AWARD) Video problem
  • (IBM) Keyboard problem
4 Beeps
  • (AMI) System timer failure
  • (AWARD) Video Problem
5 Beeps
  • (AMI) CPU or motherboard problem
6 Beeps
  • (AMI) Keyboard or motherboard problem
7 Beeps
8 Beeps
  • (AMI) Video card or video memory problem
9 Beeps
  • (AMI) Motherboard problem
10 Beeps
11 Beeps
  • (AMI) Cache memory error
Continuous Beeping
  • (AMI) Memory or Video Problem
  • (AWARD) Memory or Video Problem
  • (IBM) Power problem or loose card
Oct 28, 2007 | Gateway GX7022E (RBGX7022E) PC Desktop
ASUS P5KPL-AM SE Motherboard Logo
54 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
