Question about Keurig B30 Mini Coffee Maker
I put the keurig cup in the top and the water in and then the coffe cup. Close the lid and the blue light fails to come on that starts the brewer. All lights shut off.
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote about how to register your Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
Keurig Registration, User Manuals, Cleaning, and Troubleshooting
heatman101
Posted on Mar 01, 2011
Clean a keurig coffe maker
Cleaning & descaling your Keurig brewer is an important step to enjoying the best tasting coffee and keeping your brewer in good shape for years.
4 Comments 2
How often you need to do it depends heavily on how often you use your brewer and how "hard" your local water is ("hard" meaning how many minerals are in it). I try to do this 3-4 times a year.
Open the top of your brewer and remove the K-cup holder. CAUTION: There's are two sharp needles in there. Be careful.
The cup holder is dishwasher safe. You can toss it in the dishwasher if you want. Otherwise a good rinse under warm running water is usually good. There's a sharp needle in here, so be careful.
Turn the cup holder over and ensure these holes at the bottom are free of any obstruction.
The drip-tray is removable. Give it a good clean either by hand or in the dishwasher.
The upper portion of the K-cup holder also has a needle. This needle has three holes in it. Insert a straightened paper clip into each hole to remove any buildup or obstructions.
Here's a close up: There's nothing you can break in here, so use some force and get that paperclip a good inch in and wiggle it around vigorously. Repeat this for the two other holes in the needle.
Use a damp, soft cloth to wipe away any coffee grinds or water stains in and around the cup holder area, and down the front of the brewer.
Be careful of that needle inside when wiping it down.
Put the K-cup holder back in the chamber. Make sure it's the right way around by aligning the arrows at the top of the holder.
Empty the water in the brewer's external reservoir.
Refill the reservoir with undulated white vinegar and replace on your brewer.
Run four large cup brew cycles. DO NOT use a K-cup, just run it empty . Dispose of the hot vinegar after each. This pushes the vinegar through the inside heating tank as well as all the valves inside.
Leave your brewer to stand, powered on for four hours. This allows the vinegar time to break down any build up in the tubes and valves inside the brewer.
Discard any leftover vinegar then refill the reservoir with water only.
Run large cup cycles until "Add Water" is displayed on your brewer's screen. This washes out all traces of vinegar from the insides of the system.
Comment 18
If you notice a vinegar-like smell or taste to the water coming out of your brewer, refill the reservoir with water a second time and run hot water cycles until empty.
3 Comments 19
Congratulations!! Your Keurig brewer is now clean and your ready to enjoy full cups of delicious coffee for months to come!
3 Comments
SUPPLIES
Keurig brewer 1 Paperclip White vinegar (approx 48 oz) 1 Mug
Feb 20, 2015 | Keurig Platinum B70 Coffee Maker
Keurig troubleshooting
First open and close the lid again to ensure the brewer was prepared to brew BEFORE you close the lid on a kcup. Failing that, you could try unplugging the brewer for a few seconds, and trying again once the brewer has indicated it is ready to brew.
Sep 08, 2014 | Keurig Coffee Makers & Espresso Machines
B40 WR Keurig shooting out water instead of brewing
Turn off your brewer and use an unfolded paperclip to clean out the holes in the top needle
Dec 26, 2012 | Keurig Special Edition B60 Coffee Maker
Won"t brew the coffe right and hot water coming
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 22, 2011 | Keurig Platinum B70 Coffee Maker
THE 1 CUP KEURIG DOESN'T BREW COFFE. THE WATER GETS HOT BUT NEVER GOES THROUGH THE MACHINE TO MAKE THE COFFE
heatman101
Mar 01, 2011 | Keurig B60 Coffee Maker
I have a keurig b30 and has been working great but now it will not recognize any of my cups so the flashing blue light will not come on to start brewing? none of them are clear and have all worked in the...
I haven't solved the problem, but I continue to disassemble my K30. Most likely points of failure for the blue start light not coming on appear to be a sensor to detect the cup is in place (two small holes on the left/right front edge of the cup holder) or a sensor in the resovoir lid where the blue pin presses on a pressure switch. I did find that the red wire to this switch gets caught in the lid hinge and may be damaged. I will post more if I finally discover the root cause but may just go to Bed Bath & Beyond and buy the resovoir model with a 2 year warranty. Lesson learned. Cheap switches and mechanical devices.
Nov 06, 2010 | Keurig B30 Mini Coffee Maker
Keurig B30 Mini Coffee Maker Logo
885 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
