Question about Samsung AQ24 Air Conditioner
Working but not cooling. Filters clean - Samsung AQ24 Air Conditioner
  • Samsung Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Nov 15, 2010
How do you clean the filters on the outside unit of split system Mitsubishi reverse cycle 18RV
Outside unit does not have a filter. You can try to pull the disconnect on the outdoor unit. Reinsert after 10 seconds, see what happens.
Jul 08, 2017 | Mitsubishi Heating & Cooling
Will not cool, fans are clean, appears working.
You should check Freon (or whatever cooling agent) it is using and refill if needed.
Jun 21, 2015 | Furniture
Stopped working
Open the front panel to expose the filters. If they are dirty they should be cleaned. If that doesn't work, maybe you need to check the cooling gas level. That requires a special tool that most A/C technicians have.
Mar 19, 2014 | Panasonic Heating & Cooling
Ge air conditioner/heater neither working, i cleaned filters
I think there may be a limit switch to the blower door for safety.take the door off, turn thermostat on and down for cooling. then, hold in the limit switch and see if the blower kicks on in a few seconds.
Jul 28, 2012 | GE Heating & Cooling
Our HC 6800 projector will work for about 10-20 minutes before displaying a solid red screen and shutting off.
Projectors shut off when they overheat. They overheat when air does not move through the projector cooling it. This happens when the fans are not working or air filters/vents are not working.
Check to see whether the fans are working. If they are working, open the top cover and see whether air filters/vents are covered with dust. If so clean them.
Sep 26, 2011 | Mitsubishi HC6800 1500 ANSI Lumens 3LCD...
I have Scouts lightware projectors In the equipment the extractor is working, but there is too much temperature and turn off the equipment only if I take out the back cover the equipment work also dont...
The unit might not cool down if the air filters are blocked. You can check whether the air filters are blocked.
Remove the top cover and check the air filters for dust. Clean the filters and your problem will be solved.
Sep 22, 2011 | Lightware Scout XL Multimedia Projector
Hi my name is Tom, The problem I have is my airconditioner runs and i've also cleaned filters, but it only blows nomal air...it dosen't seem to cool...
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Check indoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3 degrees less than room temp.6.Check compressor is working with correct pressure.
Thanks. Helpful?
Jan 03, 2011 | Heating & Cooling
All filters are clean on unit but while warming up it locks out on warming temp. If all filters are clean what else would cause this fault?
hi,
check , is the fan is working or not. a fan is used for cooling the lamp,( through out till it is on.) if the fan is not working the lamp will get over heated and the worming message will come.check it first.
ok
Dec 22, 2010 | Sanyo PLC-XT16 Multimedia Projector
Ruud a/c heating system problem
Get service tech to check charge. Clean condensor check filters first.
Jun 12, 2009 | Heating & Cooling
Heating & Cooling Logo
97 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
