Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
The stud that the clutch is held on has broken off flush with the clutch housing - howe do I extract it to replace it and secure the clutch so I can use the saw again ?
  • 173 Answers
You Cannot Fix This Problem.You Will Have Too Tear It Apart And Replace The Crank.Your Best Bet Is Too Buy A New One.
Posted on Nov 15, 2010
How do I remove and replace the starter bendix gear on a 1987 Harley Davidson FLHTC Electra Glide with original Evolution 80 cu in engine?
Hi Lewis, first thing disconect the battery negative cable first. If you have a dry clutch remove primary cover and if memory serves me correctly " I THINK " you can wiggle out the starter drive and shaft pass the ring gear on clutch pack while pushing in on the throw out fork, no promises that stuff goes back almost 30 years and my memory is a little fuzzy. If it won't come out that way your going to have to pull the starter, solenoid, and gear housing. Disconnect all wires and cables, draw a wiring diagram so you know where everything goes back to each stud. Pulling the solenoid, starter motor and gear housing are pretty straight forward. Remove the chrome starter end cover, the bracket that it screws into is held in place by two very long studs that go completely through the starter motor and screws into the gear housing. Completely loosen these studs. !!!! WARNING!!!! when removing the starter leave the studs in the motor and grab the starter at both ends and pull it away from the gear housing, you do not want that starter coming apart which is extremely easy to do trust me. If you can remove either the starter or the gear drive housing or solenoid any of these as a unit even better. Now you can get the starter drive out. Put the shaft in a vise and unscrew the the two sided nut clockwise it has reverse threads pull of the old starter drive off and install the new one piece a cake. Now if you have a wet clutch drain the primary first then remove then cover and see if its doo-able from that side first. Take your time inspect everything you touch and reassemble in reverse order and when securing the studs and nuts tighten firmly but do not overtighten all the torque specs are in inch lbs which calculate out to between 2-4 foot lbs be carefull and good luck.
Apr 07, 2015 | Harley Davidson Motorcycles
I have a 2001 wide glide, and one of my exhaust studs snapped off below the surface on the front cylinder head. Does anyone know if I can extract it with the head still on the motor or do I need to pull...
Hi David, you should be able to extract the broken stud piece with the head on the engine. you will need a screw extraction kit snap on makes the best one but any place that sells tools, ie sears or harbor freight ect. will have some type of kit. it requires also a drill bit, and be aware that the straighter and dead center the hole will maxamise your final result. also the drill bit must be new or extremely sharp to keep the bit from walking also use a center punch to dead center the stud giving the the drill a primo place to start drilling. Now if you fail with this method dont feel bad it happens alot even to the most experienced tech. There is a second option buy a 5/16-18 helicoil kit and follow the instructions its fairly easy again drilling the hole accurately will give you the best results. good luck
Mar 23, 2015 | Harley Davidson Motorcycles
Water pump thermostat
The hard bit is:-You will need to drill a hole down the centre of the broken bolt, when you have drilled about 2cm use a stud extract to ease out the broken bolt. Stud extractors are relatively cheap they are a tapered left hand thread which grips the side of the hole as you try and unscrew it. If you put a drop of brake fluid round the broken bolt and let it soak in, it acts as a penetrating agent. Take the drilling easy don't force it!
Dec 30, 2013 | 1992 Cadillac Eldorado
I am unable to get the bar and chain off of my Poulan Pro 260 42cc chainsaw because the stud for the clutch brake housing has broken loose inside the housing. When turning the clutch brake nut the clutch...
I ran into the same problem and I "cheated" my way through this. First of all, the thread is metric on the stud. Take an imperial nut and start to thread it on the stud. Don't force it, it will stop after half a turn. Now you hold the imperial nut with a socket or a wrench, and use a flat wrench to undo the other nut(the one that is stuck). It took me 2 minutes to remove it and no damage done at all.
Hope it helps
Mike
Jun 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do you change out a broken front wheel stud on a 1999 Isuzu Rodeo
if it is broken at a point where you can still grab hold of the stud partially try using a pair of vice grips and maybe even the boxed end of a longer wrench around one of the handles of the vice grip for added leverage. if it's broke off flush with the rotor you'll need a strong enough drill with a carbide tip and an easy out aka an extraction kit to back it out of the threads. A little bit of heat from a torch or some penetrating oil might help loosen it up as well. Just remember one or the other not both or you may need a fire extinguisher. good luck
Apr 01, 2011 | 1999 Isuzu Rodeo
Fix 2002 buick rendezvous side view mirror
it sounds like the mounting bolts embedded in the mirros housing were pulled out somewhat.You will not know untill the mirror is removed. If the studs that hold this mirror housing to the door are pulled out take a heat gun to get the studs warm and twist them back in flush. them apply JB Weld to the studs lowest part to the mirror housing so they stay secured
Feb 06, 2010 | 2002 Buick Rendezvous
How do you get the stud out of the right front fork
If the stud you need to remove isn't broken & you can access all the thread try this trick.
grab 2 spanners that suit the nut that fits on the stud.
Now grab a second nut that fits the stud.
Now place one of the spanners on the stud followed by the first nut.
Screw the first nut down the thread so you can put on the second nut.
Screw the second nut down untill its flush with the end of the stud.
Next tighten the first nut against the second making sure the front one is flush with the end of the stud.(this will leave you with a spanner on the inside followed by two nuts that are tightened against each other).
Next tap the front nut with a hammer.A good tap.
Next using the spanner that is captured behind the two nuts,try to loosen the nut (at the bottom of the stud).
9 times out of ten this works.
If it doesn't tap the end again(not too hard as you don't want to break/bend the stud) & try again to loosen.If its still stuck apply some heat to the housing around the stud & try to loosen again.
If this all fails(Which it rarely does) you'll have to by a stud extractor from your local tool shop.
If the stud is broken,with some potruding out try using vice grips as you'll need a new stud anyway.
If the stud is broken flush then that is tricky. You'll need to drill a hole in the stud & use an easyout or screw extractor. If your not carefull you can seriously damage it. If it is broken flush I suggest taking it to a shop for the repair(unless you've used easyouts or screw extractors before)
Thts should help you out
Regards Andrew Porrelli
Dec 06, 2009 | 2004 Honda CRF 230 F
How to replace rear wheel stud. 2003 dodge caravan
Should be a pressed in wheel stud, remove hub and have old one pressed out or you can do it the primitive way, by double nutting the old stud and striking it with a hammer to pound it out, if threads are bad then just strike the stud by itself , then replace new stud in opposite fashion...
Sep 15, 2009 | 2003 Dodge Caravan
I was attempting to replace my thermostat adn i broke both stems to the thermostat HELP!!!!!!!!!!
That's because of corrosion. It happens!
The broken studs have to be cut, or ground down flush, with the thermostat housing. Then a center punch is used to make a deep dimple, in the center of the broken stud.
Next use a small drill bit to make a pilot hole.
Two times smaller than the stud. (Bolt)
Use caution, as you don't want the drill bit to walk off to one side. Keep the drill level, and vertical.
Now come back with a larger drill bit, but one that is smaller than the stud/bolt, and will stay away from the threads. Try to drill at least one-half inch in depth. Use an Easy Out, bolt extractor.
If it feels as though the Easy Out bolt extractor, is being forced too much, and you think there is a possibility of it breaking, STOP!
Use a drill bit that is large enough, to drill a hole that will not touch the threads. Then work a small chisel along the outside edges of the bolt 'Shell', and work that thin shell to the inside. Use a pair of needle nose pliers to try to extract the shell out. One piece at a time.
(After you have drilled the center of a stud, or bolt, out to where the threads are, there is a thin metal shell left behind)
Jun 12, 2009 | 1991 Chevrolet Caprice
Broken manifold bolts / manifold removal
Whatever it takes, but make sure you soak some penetrating oil oi wd40 on others to avoid any more being broken. Pulling the manifold is the safest and quickest way. With it out of the way, you'll have someting on the broken bots, now studs to work with. Always drill a broken stud or bolt clean through. Penetrating oil can work from both ends and a broken easy out can be driven in far enough to work arounf -Good Luck, force nothing, Tap stud and apply only stesdy even presure when extracting.
May 19, 2009 | 1999 Ford F150 Regular Cab
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
49 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
