My canon MP620 does not print in black but does in all the other colors> The cartriges were recently installed. What could be the problem and how can it be fixed
  • 2,069 Answers
I would suggest you unplug printer when carriage is in the center, look to the right with a flashlight and see if the filter pads are seated properly in the purge assembly, if all looks good, you may need a new purge assembly. It is most probably not capping properly or not cleaning properly.
Regards
Posted on Nov 15, 2010
Color error black
Probably not. CMY all combine to make black, if one ink tank is empty it wont print black. Try going into print settings and change to GREYSCALE only.
Dec 01, 2013 | Canon PIXMA MP620 All-In-One InkJet...
My canon Pixma MP620 wont print in black. All the other colors are fine. I've tried deep cleaning with no results..
Try this;
- Open the document you want to print - Go to file > Print - click properties in the print window - in the menu select 'Maintenance' - in the 'Maintenance' click 'Ink Cartridge Settings' - select Black Only - click OK - click OK - now you can print only using the black ink in the printer.
Hope this helps.
Please rate if this solution was helpful. thanks!
Jul 14, 2011 | Office Equipment & Supplies
My canon pixma mp620 won't print black ink but other colors print ok.
Does printer have 2 black cartridges, 1 large 1 small? if so, the small black one and colors only takes care of the color print jobs and the large black one, the main black and white jobs. Make sure you don't have an empty large black cartridge.
Aug 15, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Black/white setting for printing?
Hi there
No sorry but the printer will not work with just the black it needs all inks to work
All the best Pineworks
Apr 25, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Print with single cartrige. I rarely use color. The color cartrige ran dry and nothing will print in b&w until I buy a new color cartrige ( for about $37.50) and install it. HOW DO I BYPASS THIS...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up and prompt you to chose this option, you should be able to tell the printer to print in black .
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | HP Office Equipment & Supplies
My canon mp620 won't print the black color. printing an email is blank. test page prints OK
I had the same problem, after replacing both black cartridges. I solved the issue by running the print head cleaner. Below is the link to the instructions.
For Mac:http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=17406
For PC: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=17406
Mar 20, 2010 | Canon PIXMA MP620 All-In-One InkJet...
U130 ink message on pixma mp620
Very simple solution: When the pixma mp620 screen shows error U130, Hold down the stop (red triangle) key for about 7 - 10 seconds. This overrides/turns off the ink monitoring function. The printer will begin "thinking" for a bit and then start printing. Note: you may have to do this seperately for each color. You'll also notice that when the lid is open and the cartridges are in position for changing, the cartridges that used to be "out" are no longer flashing red, nor a stead red. They are dark.
Feb 17, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Printing with only the Black ink cartrige.
Yes. The printer won't operate without both cartridges installed, even if one is empty.
Mar 15, 2009 | HP DeskJet 842c InkJet Printer
My Canon iP4500 does not print with "black" cartridge
hi im josh in cebu phils. may i help you? Friend the problem is your cartridge and on the tank lever.it causes spoiled ink that stuck on it. To solve this problem. you may visit the Cannon Pixma support manual site and follow the steps there:here:
http://www.generalmanual.com/Printers/Canon-PIXMA-iP4500-Photo-Printer.htm
good luck friend hope i helped you.
Mar 14, 2009 | Canon Pixma iP4500 InkJet Printer
IP90 WONT PRINT BLACK
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. My color and black and white print came right back!
Hope this helps.
Jan 30, 2009 | Canon PIXMA iP90 InkJet Printer
21 people viewed this question
jasbo
jasbo
