Question about Siemens Gigaset 4010 Cordless Phone
The best way to discharge the handset? - Siemens Gigaset 4010 Cordless Phone
  • 35 Answers
Unplug your telephone cable from base, on the handset press the talk key and just let it sit there should take a couple of hours or so.
Posted on Nov 15, 2010
AT&T/Lucent cordless. Why is there no display on the screen?
Perhaps the battery is discharged (dead?) -- is the
"charging" light for the handset (or base, depends
on model) illuminated while the handset sits in the
base or docking cradle?
The original Owner's / User's Manual is easily
downloaded from www.manualslib.com
Look underneath the battery inside the handset for
a small sticker showing the proper model number
to ask for ( ie, CL82659 )
Mar 19, 2016 | Lands Phones
Hi - my 2yrold was fiddling with the handset, and now we have a flashing 'base 1' display. Each time we dial, it reverts back to the flashing message. I've tried unplugging the unit and leaving it...
You 2 year old disconnected the handset from the base. The handset is asking to be connected to the base. If you have the owners manual it will tell you the sequence you need to do to reconnect the handset to the base. If not, google the make and model and get the manual on line. sometime sitting the handset on the base several times in sequence will re sink it to the base.
Dec 12, 2017 | Northwestern Bell BELL 36240 Cordless...
Can the phones be left in the chargers continously?
Yes....in fact it's best to return the handset back to the cradle after use.
This is what Uniden says about battery life.
(With average use, your handset battery provides more than ten hours of talk time and approximately seven days
of standby time. You can achieve optimum battery life and performance by returning the handset to the base or
charging cradle after each use. When your handset is left off of the cradle, the battery will gradually discharge even
if the handset is not being used. The actual talk time duration will be reduced in proportion to the amount of time the
handset is off of the cradle.)
Nov 13, 2010 | Uniden DECT 6.0 Cordless Telephone...
Hi, I bought Smasung SCH BC519 Guru CDMA Mobile handset on 20th Feb2010.My voice is not properly audible by other party and sometimes breaking(Outing Voice Problem) and Recent calls are not storing and...
Battery will discharge rapidly when the phone is in fringe area (= insufficient range) or the signal strength of the tower is varying. Try another CDMA network operator which has tower near your area.
Aug 18, 2010 | Cell Phones
Trouble is it fell in to some (water handset only) Dried out over 2 months but then battery wouldn't charge properly. Bought new battery and it charges but does not stay charged and then everything on...
sounds as its still damp inside of handset. u could strip down and make sure the water hasnt coroided any contacts which is making it discharge to earth.
with regurds replacement handsets , i have been looking for spare base as mine is just started going and cuts calls off ( sound like dry joint in base unit or power supply is giving up) try a philps dealer to see what spares philps have other than that it secound hand units.
Jan 23, 2010 | Philips Zenia 300 TU7370 Cordless Phone
Dash standby has a maximum of 12 hours
Are you using the factory charger? If you use after market chargers you could basically blow the battery.
Thats kinda what it sounds like.
May 04, 2008 | T-Mobile Dash Smartphone
I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Mar 24, 2008 | Panasonic KX-TG6051M Cordless Phone
Connection between two phones
There might be two problem....1st of programming and 2nd one of internal hardware problem of your handset which is not working.
For the 1st option- Read manual carefully, there is security setting. Follow the steps with second one handset which is not responding.( I can assum that it is power on but not responding to signals..May i right?) After completing security process it will give long beep and will bond with other one and that is necessary for frequiency adjustment. This generally occures after removal of batteries.
For the 2nd option- There is crystal inside your handset which is resposible for generat stable and similar frequency as other handset. When that crystal lost its capacity it results in mismatching of frequency and occures in non connection results in no response from handset. This can be repaired by technician after getting part no of that crytal from your device and replace it with another one. But for this you have to visit technician with all of handsets and attachment as it is necessary to check it working properly after repair, even technician may also need it for setting frequency level.
Is it clears all doubt about this problem then say FIXYA......
Jan 09, 2008 | Siemens Gigaset 8800 Cordless Expansion...
Siemens Gigaset 4010 Cordless Phone Logo
425 people viewed this question
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
