Question about Microwave Ovens
THE TOUCH PAD ON THE OVEN DOES NOT WORK - Microwave Ovens
    Brigadier General:
  • 8,909 Answers
If the interlock door switches are in line and OK, change the touch pad as there is a shorted contact.
Contact the manufacturer for details of a dealer that will sell spares.
Hope that helps.
Posted on Nov 15, 2010
Why are GE Profile JT930 touch pad numbers not working?
Seems problem with the touch pad. Try replacing the same.
Aug 16, 2014 | GE Appliances 30" Trivection Built-in...
Touch pad inoperaive
Unfortunately, if you are having problems with a touch pad you will probably have to replace either the touch pad itself, if you can get it or the whole control board and touch pad as a unit which normally ends up running as much as a new microwave. I would check your warranty and see if it still is covered and proceed that direction.
Aug 13, 2013 | LG LMV1630 Convection/Microwave Oven
Only certain buttons of microwave oven touch pad work.
Hi, welcome to Fixya!
From your question, I suspect the fault is from the control board of the microwave. This is why some buttons on the the touch-pad are not working.
Have the control board replaced and the buttons that refuse to work will start working again.
I hope the above is clear. If not, please let me know.
Regards.
Nov 17, 2011 | Microwave Ovens
Touch pad on front panel is not working.
REplace the touch pad. The touch pad is more likely to have failed rather than the control board.
Feb 10, 2011 | Samsung MC1360WA Convection/Microwave Oven
I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
Dec 23, 2009 | Magic Chef CMV1000B Microwave Oven
The touch pad does not work. It displays menus
HI. this damaged touch pad board should be replaced asap. the board itself is not repairable.
Replacing the board will fix the issue.
Sep 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Touch pad does not work, clocke does, nothing else works
Hi this will happen when the touch pad circuits become unstable and damaged, due to abundant usage or , old age.
simply replacing the touch pad will fix this issue.
May 30, 2009 | GE JVM2070 Microwave Oven
Nothing on my touch pad works
My microwave way manafacture May 2008. Nothing on the touch pad works.???. It just abrubtly stopped
after a few seconds.
We brought it in July or August
Debbie
Mar 27, 2009 | Maytag MMV1153A Microwave Oven
Touch pad doesn't work
ut the tech sheet did mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser. That whupped that puppy! But then I went out on another service call, same oven, different house. The pink pencil eraser trick didn't work on this one so I had to apply some of that famous Samurai gray matter. To identify the problem on this one, I cut power to the range and disconnected the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then I re-applied power and let it sit that way for 24 hours after which the customer was instructed to call me and report on the error code status of the oven. If no error code was reported, I knew the touch pad was the problem. If, on the other hand, the F7 error code came back, then I knew the (ERC) was the culprit. In this case, the error code did not come back during the test period and, using my keen, Vulcan-like powers of deduction, concluded that the touch pad was defective. I replaced the touch pad and problem solved!
Mar 15, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
