Question about Samsung Office Equipment & Supplies
Hi, I use SmarThru 4 but it has a problem saving .pfd files to certain directories on a network drive... the file is placed there OK, but the PC running SmarThru4 completely freezes.
Start Smarthru4, open task manager (ctrl-shift-esc), locate task controlpanel.exe (which is smarthru4), right click, set priority, low.
You should now be able to use smarthru4 without the PC freezing. It works for me. Why? I do not know.
Posted on Feb 08, 2011
How to set up portable drive for portable storage only on windows and mac
Hi John,
If you're only using to transport files from one computer to others, I would simply directories for each computer that will have files copied to the drive - naming them: "ToComputerA", "ToComputerB", "ToComputerB" and so on (or similar). You just need to know which computer is associated with each directory on the drive - so name them any way that helps you know which is which.
I'd copy files from any / all computers that needs to get on Computer A into the "ToComputerA" directory. Likewise, I'd copy files from any / all computers that needs to get on Computer B into the "ToComputerB" directory. I'd do this as many times as there are computers that need files. Once the files have been successfully copied to the new computer, delete the files from the portable drive as not doing so will fill the drive and also cause you to need to remember if files have already been copied yet or not.
You may need to put the files in very specific or same directories on two or more computers. You should duplicate the computer's directory structure on the portable drive in this case. That way, if you place several files that all need to go in different places / directories - you'll not have to remember where they go - as the portable drive does it for you ie: "ToComputerA/C/Users/John/ AppData/Local/..."
Make sure you're using USB 3 cables and the computers all have USB 3 ports for the quickest transfer speeds via USB.
Feb 25, 2015 | Seagate 2TB Backup Plus Slim Portable 2.5...
Tip
How to assign a permanent drive letter for removable drives
1. Go to Start > Run
2. Type mmc in the box and hit enter.
3. Select File > New
4. Now select File > Add/Remove Snap-in.
5. Select “Disk Management” and click “Add
6. Select “OK“.
7. Select “This computer” and then “Finish
8. Now press “OK” on the “Add or Remove snap-ins” screen.
9. Now select “Disk Management” from the left menu.
10.You will now see all of your drives/partitions in the right hand side panel.
11.Right click the USB drive you want to assign a permanent letter to and select “Change Drive Letter and Paths…
12. Click on “Change
13. Select a permanent letter
14. Click “OK
15. It will warn you about making the change – there is little chance programs you use will be affected by this. If they will, you will probably already be aware of this so don’t worry.
16. The final step is to select File > Save and save the file in the default directory. Close the Console and you are done.
Now eject your usb drive and put it back in and see whether it is showing the assigned letter or not.
Please Vote for this Tip if you found it helpful….
on May 17, 2010 | Computers & Internet
Windows run doesn't keep my work history
you have to physically save any work
save the history to a usb drive in case you have computer failure
Plug the flash drive into your computer's rectangular-shaped USB drive.
Wait for Windows to recognize the system.
Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration.
Open the drive on your computer.
Open the "My Computer" directory if using Windows XP or the "Computer" directory if using
Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it.
Transfer files to the flash drive.
Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background.
Open the folders or locations of the files which you want to save to the flash drive.
Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window.
Release the mouse button to let the files "drop."
Close the windows and directory locations when finished.
Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option.
Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section.
Click the "Save" button to save the file onto the flash drive.
Close the windows and files when finished
hope this helps
Oct 17, 2012 | Microsoft Windows XP Professional Full...
Dell Wireless 5620 (EV-DO-HSPA) Mobile Broadband Mini-Card
Here's the link to download the driver.
http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R269884&formatcnt=0&libid=0&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=397433
Download
1.Click Download Now, to download the file.
2.When the File Download window appears, click Save this program to
disk (Windows XP users, click Save) and click OK. The Save In: window
appears.
3.From the Save In: field, click the down arrow then click to
select Desktop and click Save. The file will download to your desktop.
4.If the Download Complete window appears, click Close. The file
name icon appears on your desktop.
Install
1.Double-click the new icon on the desktop labeled DELL_WIRELESS-5620-EVDO-HSPA_A08_R269884.exe.
The Self-Extractor window appears.
2.Click OK or Continue.
The Self-Extracting Driver Installation window appears and prompts to
extract files to C:\DELL\DRIVERS\R269884.
3.Leave all of the default settings and click Unzip or OK. If the
directory doesn't exist, you'll be prompted to create one. Click Yes. A
Self Extractor window appears and indicates C:\DELL\DRIVERS\R269884 files were
extracted.
4.Click OK.
Follow the on-screen installation instructions in the window.
HTML Pop-Up With Install Now Button
1.The Dell Software Installation Documentation window appears.
2.Click the Install Now button. A File Download window appears.
3.Click Run this program from its current location and click OK.
The Security Warning window appears.
4.Click Yes. The InstallShield Wizard window appears.
5.Follow the on-screen instructions.
Thanks,
Oliver
Jul 28, 2011 | Computers & Internet
I am having trouble changing the default "save" directory on the
The default 'save' directory for Livecam is fixed as: My Documents\My Pictures\LIvecam Files on C: drive.
However, you CAN change the location of My Documents e.g. put it on D: drive. See the MS Knowledge base for how to do this: http://support.microsoft.com/kb/310147
Mar 04, 2010 | Microsoft LIFECAM VX-7000 Webcam
How to install jar files (games) in samsung corby pro
i have most simpler solution.
1. in ur PC, open a new notepad file. (anyname.txt)
2. write <html><body><a href="yourApplicationName.jar">install yourApplicationName.jar</a></body></html>
3. save it and close the file. change file extension to .html
4. transfer this file to ur Corby along with the Jar & Jad files of ur application
6. open this file to run the application and click the link displayed
7. enjoy ur application
Jan 22, 2010 | Samsung Cell Phones
Ethernet driver for dell dimension 4600
Hi stefyboy - Below is a link where you can download your driver. After you get to the page just make sure it says Windows XP as the operating system. Then scroll down and click on the + next to where it says network. You want the intel 10/100 driver. I've included a few a ways to install it. If your kinda new to this the easiest is the download to desktop method and just remember where it unzipped it to, you can always move it to a driver directory where you can keep all your drivers for the future.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be glad to assist you further. Thanks.
Jeff
Hard Drive Installation (via WinZip) with HTML Pop-Up Window for R67150.EXE
Download
appears.
Install
1.Double-click the new icon on the desktop labeled R67150.EXE.
extract files to C:\DELL\DRIVERS\R67150.
3.Leave all of the default settings and click Unzip or OK. If the directory doesn't exist, you'll be prompted to create one. Click Yes. A Self Extractor window appears and indicates C:\DELL\DRIVERS\R67150 files were
extracted.
4.Click OK.
Jul 04, 2008 | Dell Dimension 4600 PC Desktop
Xerox Documate 152 file conversion issues
Try saving the file on your desktop first, and see if it converts and saves correctly. Next, make sure that your external harddrive is detected correctly and visible under My Computer.
You could also try reinstalling the software and drivers. Try this first and let me know how it goes..
Jun 23, 2008 | Office Equipment & Supplies
Churches are not loaded as POI's. on my ONE XL-S It usuall will not recognize any church a.k.a. place of worship, even if I enter the name. Please help!!
The Points of Interest (POI) database consists of two files:
An OV2 file, which contains the POI's information ov2.jpg A BMP logo of the POI (optional) bmp.jpg
Step 1: Download and unzip the POI file.
1. Download the POI zip file. Save the file on your computer by selecting “save” when prompted. Save the file in a place where you can easily find it again for step 3 of the installation (e.g. on your Desktop or in My Documents)
2. Unzip the POI file by right-clicking the file and selecting Extract All..
  • This will run the Extraction Wizard. Choose Next.
  • Click on Browse... and choose a location on your computer where you want to extract the files. Click Next.
  • Once the files have been extracted, choose Finish to view the files.
Step 2. Connect your TomTom to your PC
Connect your TomTom to your PC using the USB data cable or dock. When prompted if you want to connect to the computer, tap on YES.
Step 3. Copy the POI files from your PC
1. Go to the directory on the local hard drive of your PC where you extracted the files in Step 1.
2. Highlight these files then right-click them and choose Copy.
Step 4. Copy the POI files to your TomTom
1. Go to mycomputer.jpg.
2. Double-click your TomTom under Devices with Removable Storage tomtom.jpg.
3. Then go to the map directory, for example the folder na.jpg.
4. Righ-click and Paste the POI files into this folder.
5. Right-click your TomTom device and choose Eject before removing it from the USB cable or dock.
You can now use the new POI on your TomTom device via Navigate to... > Point of Interest.
Apr 07, 2008 | GPS
Sandisk Micro SD Card stops after 108 songs
If you formatted the card first, you should have had a true value of the Size.
Even a true 1 Gig card, only has a capacity of 960mb.
As the card has to allow for a valid boot-block to be written to it.
This is so the read/write device, can recognise the drive/cards format i.e FAT/FAT 32 et,c.
I,d suggest that you have a 512mb card, that has a 1 gig sticker on it.
The chinese have a way of doing this with MP4 Players. they sell them as 4 gig, when you format them, they,re actually 1 gig or smaller sometimes.
I,d suggest backing up yhe card, and formatting it, to see it,s true size. And that your also using the correct Format.
Mike @ compurepair.
Mar 14, 2008 | Electronics - Others
419 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
