Question about Panasonic KX-T7730 Corded Phone
Panasonic KX - T 7730
How do i assign a different ring tone for internal calls. how do i change the time and date setting?
  • rosemaryred Mar 30, 2009
    Need to change time setting on Panasonic KX-T7730
    Problem Solver:
  • 8 Answers
Look.................. a *****
Posted on Jun 25, 2008
How can we change the ringtone on Panasonic KX-T7730 phone?
You don't. Panasonic analog system phones have one ring tone. You can change the cadence (single double or triple) ring from outside calls, but not the tone.
Carl
Oct 26, 2011 | Panasonic KX-T7730 Corded Phone
Panasonic kx-tga101s -- problem regarding making conference call - this is very much helpfull. But i have weird problem, i did call 1 person, and then i asked the person to hold and i made the other call....
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 26, 2011 | Panasonic KX-TG2740 Cordless Phone
How do i cahgne the ring tone on the panasonic kx-t7565 phone. I have changed it but it only appears to have chagned if ring ring the number internally. we need the ring tone to change from external...
The ringtone for the CO or outside line buttons can be programmed by pressing program then press the
CO button twice, enter the ringtone you want by dialing 01 to 08, press enter or store then program to end. This will set the ringtone for that line assuming it is programmed to ring at that phone. Transferred calls will use the ringtone of the intercom button which can be set by the same procedure. Use the same procedure if calls ring to a Group Directory Number(GDN) on the phone. The 7600 series of digital phones have ringtone settings of 01 through 30.
Dec 15, 2010 | Panasonic KX-T7565 Corded Telephone
Hi i have a panasonic KX-TES824 installed with 2 co lines and 4 extensions. I want the ringtones to be different for internal telephones (ie call between the extensions) and the CO Lines (when call comes...
A Panasonic Analog PTS ring sound is not adjustable, however, the cadence is. An outside call rings with a single ring, an internal call is either voice announce or a double ring. The digital phones from Panasonic have either 8 or 30 different tones, but that's a different system.
Carl
Nov 21, 2010 | Panasonic KX-T7730 Corded Phone
Hi i bought my new panasonic KX-T7730 but when i bring it home and try to make a call its not working there is no dial tone can u plz help me
Did you just buy the 7730 or do you have other ones in your house? Since a 7730 is designed to plug into a Panasonic SYSTEM, you'll be waiting a long time to make it work if you're plugging it into a regular phone line :-)
Carl
Sep 28, 2010 | Panasonic KX-T7730 Corded Phone
Can't change ring tone on Panasonic KX-TCA175
I had the same problem. I was advised by Panasonic support that the PBX system needed a firmware upgrade to solve the issue. (still waiting for technician to do this...)
Apr 21, 2010 | Panasonic Lands Phones
Ring tones on KX-T7433
Wow, this is your lucky day :-)
From each phone, press PROGRAM 99 and the INTERCOM or CO buttons TWICE, then dial 1-8 and STORE. (default is 2). You can now make each line and intercom different, or each phone (up to 8) different. After you finish with each phone, just pick up and drop the handset back into the cradle to end programming.
The feature is called Ringing Tone Selection.
Carl
Apr 02, 2009 | Panasonic KX-T7453 Corded Phone
How to change the incomming ring tone on panasonic kx-t7630
Oh hell... you must be going nuts if its the ring tone I think you're stuck with. I loath the manual that comes with this system so here it is in English:
  • Press 'Prog'
  • Press 'Intercom' twice
  • Now you can either go through the different ring tones by pressing 'SEL' on the LCD screen or using the Up and Down keys on the circular pad on the bottom right of the phone.
  • Once you have the tone you like click on 'Enter'
  • Pick up handset and hangup to complete the process.
Dec 04, 2008 | Panasonic KX-T7630 Corded Phone
How to change ring tone of kx-t7730
sir please i want to when call my consol i'm not there i picup phon our telephone set plz suggest
Jun 16, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
520 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
