Defy D.A.W 322 Washing Machine. Circuit Board burned out, replaced with new board but machine still wont operate.
aborcass
  • 2651 Answers
SOURCE: Maytag Nepture MAH5500BWW burned control board
ummmm, honestly ive never replaced just the board(im an authorized maytag servicer) so our replacements have always been new, and in this case the repair kit containing both board and motor. that being said, i cant see a reason as to why you couldnt relace just the board itself, ,Ireally never found the reason why the board would burn out, but, as far as repair kit im certain that they were trying to get all circuit boards and motors back to only one model, instead of having 5 or six different boards andmotors, this will bring them all to the most recent board and motor, never was an issue with themotor, jusat that you couldnt wire in the new board without the neew wiring. As long as its the same board i cant see why that wont work. as far as the "wax motor" that was a seperate issue burning out the Top control board, total seperate then your problem,., dont really see an issue with installing your "used board"
Posted on Apr 08, 2008
Scott Ellin
  • 558 Answers
SOURCE: I have a problem, I
Hi Norm33,
The often found cause of this problem is the door interlock. There is a safety feature to stop any operation while the door is open. If this becomes faulty, the washer may still not work even when the door is closed. Check that when closing the door, the catch is activating the switch. To test the switch, first make sure the WASHER IS NOT PLUGGED IN, then use an electrician's meter to test the resistance across the switch. You should put the two electrodes on the contacts at the back of the switch. When the door is closed, the resistance reading should read a very low value.
Another possible cause for this is a fault on the timer. You should inspect the connecting wires for any sign of burnt plastic or charring on the spade connectors. You will need to replace the timer if this is the problem. Please dont forget to rank me.
Regards
ELLIN
Posted on Sep 20, 2008
  • 11 Answers
SOURCE: circuit board on candy washing machine
you must specif the model of the machine and getme more information
Posted on May 12, 2009
SOURCE: washing machine circuit diagram requested
you all need help
Posted on May 18, 2009
  • 64 Answers
SOURCE: bosch washing machine will not fill, spin,
If it won't fill it may not spin or drain unless the water level switch is bypassed. I would check the water valve & the water level switch and tube from level switch to tub must be air tight no holes.
The water level switch must kick in to agitate. I'm not sure on Bosch but some work like this..
Posted on Jun 10, 2009
How to put in the circuit board on hotpoint aquarius wf440 ?
this may be of some help good luck
otpoint control module configuration for selfix - YouTube
? 9:21
https://www.youtube.com/watch?v=cHpz2OcbHAY
16 Sep 2011 - Uploaded by Selfix UK
Hotpoint control module configuration for selfix ... How to change the display pcb on an Ariston Washing ...
How To Replace A Washing Machine PCB - YouTube
? 4:19
https://www.youtube.com/watch?v=vskrPU9zU5M
27 Apr 2013 - Uploaded by Selfix UK
How To Replace A Washing Machine PCB ... Repair HotpointWF541 WF540 WF740 with flashing lights ...
Modules & Control Boards ' Washing Machines ' Spare Parts ' Hotpoint
parts.hotpoint.co.uk/.../washing-machines/...boards/.../C8-RIC-LVTRC-...
Have you lost complete control of your washing machine? ... If your PCB assembly (printed circuit board) is faulty then replace today for an efficient and effective ...
How to Replace Washing Machine Control Panels - Hotpoint ' eSpares
www.espares.co.uk > Home > Advice Centre
8 Jun 2010 - Replacing any of the front panel controls on a washing machine is ... how to replace any of the knobs, buttons, printed circuit boards that sit ...
How to Diagnose Washing Machine Control and Program Problems ...
14 Nov 2013 - Watch Josh explain how to diagnose washing machine control and program problems. ... If you then suspect that the problem still lies in the circuit board ... to test the board and you'll actually just need to replace it altogether.
Hotpoint WD420 fault ' Page 2 ' DIYnot Forums
www.diynot.com > Forums > How to... > Appliances
31 Oct 2009 - 15 posts - ‎11 authors
hotpoint aquarius wf530 washing machine flash like Christmas tree when ... After reading this forum I took the PCB board out and the C17 ...
Hotpoint WF540 washing machine board issue - pics included ...
www.electro-tech-online.com > ... > Repairing Electronics
19 Mar 2011 - 14 posts - ‎9 authors
Just took the board out of the washing machine to check the c17 cap ... was gonna cost £150 just for a replacement board without fitting.
Hotpoint - EMW Electronics
https://emwelec.co.uk/index.php?l=product_list&c=13
This is the Mark 6 board fitted to late Hotpoint washing machines. The module will be programmed to your model number - ready to fit. Typical models are WF550P WF560G .... Hotpoint Arcadia PCB Modules. SKU: 256. Hotpoint Arcadia PCB ...
modules and PCB's for washing machines and washers for Candy ...
www.unifit.co.uk/washing-machine-washer-spares-parts-replacement-mo...
Hotpoint SCR, WMA, WMS washing machine pcb control board ... 1200RPM 6 KG 2003 TO CURRENT LINEN), HOTPOINT - WMA58N (AQUARIUS 1400 RPM 6 ...
  1. Hotpoint Appliance Parts‎
    Adwww.hotpoint.co.uk/SpareParts‎rating for hotpoint.co.uk
    Save £5 When You Spend £35 or More! Low Cost and Next Day Delivery.
    Price Match Guarantee · Spend £35 & Save £5
  2. Hotpoint Spares - Delivered Within 24-48 Hours.‎
    Adwww.hotpoint-spares.co.uk/Shop/Spares‎Machine Spares
  3. Dishwasher Parts
  4. Cooker Spares
  5. Fridge Spares
  6. Hob Spares
  7. Replacement Circuit Board - Fried the hard drive circuit board?‎
    Adwww.onepcbsolution.com/‎hotpoint washing machine circuit board
    hotpoint washing machine control board
    washing machine pcb repairs
    hotpoint washing machine pcb problem
    washing machine circuit board replacement
    hotpoint pcb repair
    hotpoint aquarius washing machine circuit board
    circuit board for hotpoint aquarius
1 2 3 4 5 6 7 8 9 10 Next
Nov 22, 2016 | Hotpoint Washing Machines
Defy DAW370
time to replace timer/electronic control board and fix it.
You can get part from www.repairclinic.com
God bless you
Jul 11, 2013 | Motorola Mobility Defy Cell Phone
No power - samsung model mfsui80ncc-t2
i have a samsung washing machine model wa91u3 no power supply. i check electronic board totally burn. board model mfsui80ncc-t2. please help me to buy sparepart. I need to change new electronic board.
Oct 09, 2012 | Washing Machines
My Candy sprint 1300 washing machine wont spin to drain water from my clothes
these washers have a printed circuit board that is know to burn out some components.If you can locate it and remove it, it can be resoldered at a local electronics shop, if your not confortable, most appliance repair shops can change this board at a reasonable cost. Hope this is helpful
Dec 27, 2010 | Washing Machines
Apr 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Zanussi FS1155W won't start
found out its the printed circuit board has burnt out behind the front panel two tracks on the panel leading to a green capacitor on the circuit board overheated so i resolded the tracks put the washing machine back together and so far its done several washes [touch wood its a sucess] the circuit board brand new from zanussi 135.00 pounds [so new washing machine if it fails] so hopefully theres a solution
Nov 30, 2006 | Zanussi FS1155W Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
