Question about Sony FD Trinitron WEGA KV-27FS120 27" TV
KV-27FS120 blinks 2 times continuously...
I have a Trinitron WEGA model # KV-27FS120, Chasis BA6. It was manufactured in July 2005. When I plug it in and press the power button, it clicks, the stand by/timer LED blinks four times, pauses, then blinks 2 times. It continues this 2 blink pattern until I unplug it.
1. Is this an easy fix for a DIY'er?
2. Can I order the part through Sears?
3. Is there a diagram of what the part looks like and where it is located?
4. Is the tv worth fixing?
Thank you for your assistance.
Mike
    Genius:
  • Sony Master
  • 1,689 Answers
This is not for a DIY're.
It is possible that the flyback transformer and the horizontal output transistor have failed. Also there may be damage in the power supply when these components fail.
When troubleshooting, it is important that the tech locate the cause of the fault and also change the related components.
After the parts are changed, the power supply and the high voltage setups must be done to make sure that the voltages are in specs.
This type of work must be done by an experienced TV tech. He will have the necessary test equipment, tools, service manuals, and training. There are some very serious safety issues when working in a TV set.
Jerry G.
Posted on Jun 19, 2008
Sony FD Trinitron WEGA Tv - LAMP blinking 11 times
Sony tv has self protection program. The red Led blinking light indicate the probable cause location. For this model it is either 2,4 or 5 flashes every 3 second. Please check the blinking again
Feb 09, 2010 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Standby lighy blinks tv won't turn on
error code 4 is vertical deflecton failure . replace the vertical deflection ic. and the electrolytic capacitors in the vertical circuit. Or if you are lucky just resolder the vetical IC and resolder th horizontal section too.
Sep 28, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Turning itself off?
How many flashing light?
Or check this link and try to compare it to is blink code.
http://www.scribd.com/doc/2913233/SONY-KV20FS120-Chasis-BA6
its on page 8.
May 11, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony KV-13FS100 - channels cycling
you need to change the control board or the touch buttons
Apr 12, 2008 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Light blinks four times, screen doesn't turn on
PER TO WHAT SONY HAS TO SAY IT IS A VERTICAL PROBLEM. SOME TIMES TH EIC JUST NEEDS TO BE SOLDERED. IT IS ON A SMALL HEAT SINK IC545. IF IT IS NOT SOLDERED GOOD THE YOU PROBABLY NEED TO REPLACE IT.
There are three defects can cause the Standby/Timer LED to flash in groups of four:
1) +13V and/or –13V from FBT/pins 9 and 7 respectively are missing on Vertical Drive IC545.
2) Vertical Drive IC545 is defective (no reference pulses output on IC545/pin 3 to IC001/pin 78).DON...
Mar 09, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Screen Doesn't turn on, light blinks four times
Good day.
First, A resistor looks like a little tube with different colors placed in stripe form and has two ends or terminals. The colors represent the value the 1st and 2nd 3rd being the significant digits. The 3rd is the multiplier and the 4th is the tolerance.
Consider the vertical IC of your unit being the cause of this. Also, there are cases wherein the X-ray protector resistor is to be blamed.
chris
Mar 08, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
231 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
