To put on wall - Televison & Video
  • 35 Answers
What is the problem? If you need to put it on the wall they sell Wall Mount kits you can get them at Target, walmart, home depot, .....
Posted on Nov 15, 2010
How do i put a door in a wall
you first need to determine if the wall you want to cut through is load baring, if so you need to restructure the hole you will make see engineer for exacts as every project differs. once all of that has been established you determine the size of the door you wish to install, be mindful of size if you plan to put any large furniture in 2_18_2014_5_40_04_pm.jpg
Feb 15, 2014 | Building Materials
Shower walls
You have got a lot of moisture behind your wall covering. Is that a plastic or fiberglass shower wall liner? You are going to have to tear out the shower walls, clean the studs, replace insulation and put in new walls. You must stop the leak too! You could be growing a lot of mold in the cavity behind your wall.
Jul 06, 2013 | Tools & Hardware - Others
I'm not sure how to put the string swing ukulele hanger inthe wall!!
It should come with mounting hardware, including screws and anchors. You'll need to:
1. Locate a stud in the wall.
2. Position the hanger where you want it.
3. Mark where the screw holes are.
4. Using a 1/8 in. drill bit, drill pilot holes on the marks you just made.
5. Put the hanger back up to the holes, and insert the screws.
If you have to use wall anchors, these should go in after drilling the pilot holes, but before screwing down the hanger.
If you need any clarification, let me know!
Hope that helps!
Feb 09, 2011 | String Swing Ukulele Wall Hanger w/ Wall...
Adjust headlights
Find a flat area near a wall and drive up as close to wall as you can with high beam on. Mark the brightest spot from each headlight. Reverse about 10 feet from the wall. Measure the distance and calculate the drop based on the percentage label on the crossmember (eg 6" if 5%). Put a mark on the wall at the calculated distance below the original marks.
Apr 25, 2010 | 1996 Jeep Grand Cherokee
How do I wire my digitial timer with only two wires in my wall?
By 2 wires I assume you mean this is a switch leg with a black & white wire + a ground wire and nothing else. If that is the case then power is flowing in on the black wire and out on the white wire. If this is what you have simply connect the black wire in the wall to the black wire on the timer. Now connect the white wire in the wall to the blue wire on the timer. The red wire is not used in this type connection so put a wire not on it and put everything back in the wall. Here is a diagram of how to connect it with on 2 wires in the wall. 4051d3d.png
Apr 25, 2010 | Intermatic Inc. ST01C Digital In-Wall...
What kind of glue should i use to attach sheets of stainless onto the wall without getting wrinkles?
I would use liquid nails on the wall once you put the glue on the wall you trowel it down to make it all even then you put the stainless up.
Good luck and please rate 4 thumbs for the free answer
Mar 11, 2010 | Stainless Kitchen Ranges
I was told that putting my de himidifier against to wall can cause damage to wall, if the unit touches to wall from the back of the unit. Can you please tell me the minimum distance the the dehumidifier...
If it vents or blows air out the top you can put it against a wall. If it blows air out the back it will heat the wall and also impede the airflow through it and make it work less efficient. I would check with the manufacturers owners manual or their website.
May 16, 2009 | Kenmore 54701 Dehumidifier
Wall mount dyna glo model RMC-40NGT
I have the same one i am looking for the wall brackets, I lost mine. I also bought mine at a garage sale the people had it attached to the wall completely hooked up .they had no fire backer on it .They only took it off the wall when i purchased it
Nov 02, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Thru the wall AC units(small)
If the Ac unit can not fit your window, you can put a wall unit, you don’t have to open the wall and mount a stable unit, you just need to buy a portable AC unit put on.
This way cost you not too much.
Jul 09, 2008 | Haier hwr10xc6 Air Conditioner
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
