Question about Saeco Supervapore 2500 Steam Vacuum
Water heats up in tank. Light goes on, showing it's ready, but no steam is emitted through hose. Waited several hours.
    New Friend:
Sounds like the switch on the hose has gone bad. May want to try taking hose to your trusted local electronics shop. They may be able to open it up and test it for you. Good luck. If you ever find where to find parts (I am looking for the tip and tools) please let me know knappge@comcast.net or if your machine is beyond repair and you'd like to sell me the tip. Thanks.
Posted on Apr 21, 2013
The heating element within the steam cleaner gets hot but does not emit any ateam
Hi norma, make sure all the tanks are full water and soap and operating properly. Refer to the manual, Greg.
Dec 20, 2014 | Vacuums
My shark stem mop will heat up, but it won't emit any steam
Did you use a pipe cleaner in the jets, (be careful if steam is hot)
keep doing until it emits steam. Good Luck
Sep 23, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Polti vaporetta comfort steam cleaner...no steam
if you put two much water in it it wont steam
Dec 26, 2012 | Vacuums
I need a small tube that runs from the water reservoir to the pump
Go to the hardware store with the old hose. They have several sizes and can cut to length for about a dollar. If you want it to last go to auto parts store and get rubber fuel hose.
May 27, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How to unclog a bissell proheat turbo carpet cleaner
proheat 9300
Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
Nov 24, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have the hoover steam vac f5906900 and im just trying to use the detachment. I plugged in the water part but i cant get any suction. the water is spraying out that is all....help my dog **** on my bed...
Hi, The attachment hose also has to be plugged into the dirty water recovery tank. The other end of the hose which has the square plug, must go in the spot on the recovery tank where the water comes up from the floor. To do this, Remove the lid of the recovery tank, slide out the little rectangle (usually same color as the recovery tank) which is located just above the clear water channel from the floor there, and insert the square piece for the attachment hose. It should only fit in one way. Replace the lid to the tank and you should be ready to attack the ****. Good luck. Mark
Nov 10, 2010 | Hoover F5906-900 Upright Steam Vacuum
My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have an electrolux Enviro multi steamer which I was using this morning. I turned the steamer off for approximately 1 1/2 to do some shopping, and when I turned it on again, the steamer light turned on...
Problem fixed itself. Turned off for couple of hours so unit can cool down completely and when I turned it back on it started working again.
Dec 14, 2008 | Vacuums
I can't get my shark steam blaster model EP95 to create steam?
pull the (3) coasters/feet out and unscrew the 3 screws. take off the one end of the steam"boiler" (two clamps). tilt open end up and pour white vinegar [carefully] in there, prop up so it does not fall over, and soak overnight. dump out lime and water scale and rinse out a couple of times. Be very careful to not get water on electrical parts.
Take an air pig and blow out the line (Black) from where you disattached it to where the steam comes out [at the handle]. Be sure to mark electrical connections [4 on one, 2 on the other] so you don't blow a breaker switch like I did.
Oct 26, 2008 | Euro-Pro S3325 Handheld Steam Vacuum
Saeco Supervapore 2500 Steam Vacuum Logo
133 people viewed this question
Top Saeco Vacuums Experts
Are you a Saeco Vacuum Expert? Answer questions, earn points and help others
