Question about Braun FreeControl 1775 Hair Trimmer
The long hair trimmer doesn't work. - Braun FreeControl 1775 Hair Trimmer
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
Phillips norelco nose and ear hair trimmer
If it is battery powered then the battery is probably flat. If the batteries are rechargeable then check the charger and if alkaline then get new one/s
Jul 18, 2013 | Philips Norelco NT9105 Nose and Ear Hair...
How to fix my wahl senior so it doesn't pull hair
It could be one of several problems, but the most likely problem is that the blade is too far back. There are two adjustment screws on the the blade -- loosen these a tiny bit, then slide the blade forward (away from the clipper) and then tighten the screws again.
Nov 23, 2011 | Andis 01690 Hair Trimmer
The trimmer on my Braun 1775 FreeControl shaver has stopped working. When it is engaged, the pitch (sound) of the shaver changes in the usual way with the usual increase in vibration. However the trimmer...
The trimmer is either broken or clogged up with a combination of shavings and skin oil. If it is broken, there are no replacements available. If it is clogged, you can fix it by thoroughly cleaning it. Dip the blades of the trimmer into some rubbing alcohol or other mild solvent type liquid. Soak it for about one minute. Then take an old toothbrush and firmly scrub the teeth. Then turn it on and it should free it up. If it still doesn't move you can advance the blade manually to get it 'unstuck'. One of the blades is fix and the other moves back and forth. You should be able to see which one is supposed to move by sight. Take a small flat screwdriver or similar object and push the blade to each side once. Turn it on and it should move freely. Dip the trimmer blades back in the rubbing alcohol while it is running and let it run for about 15 seconds.
If still not working it is beyond repair. The easiest and least expensive way to get working again would be to purchase a new ;lower unit' which includes the trimmer. You will find at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-1775-freecontrol-lower-unit-p-828.html
Aug 24, 2011 | Braun FreeControl 1775 Hair Trimmer
Clippers dont work at all, don;t cut hair and the dog hair is trapped
A reason your trimmer may not work is that the hair is trapped inside the trimmer and not allowing it to function properly.
Here is a link to a video to cleaning hair clippers.
www.youtube.com/watch?v=43CpUK2AghA
If the problem persists, then you most likely burnt up the engine in the clippers and there is no easy solution other than buying a new trimmer.
May 02, 2011 | Wahl 8550
What is nasal trimmer
This is a trimmer to clip those nasty hairs growing in your nose. J.
please rate my answer as very helpful. thanks
Mar 24, 2010 | Emjoi AP-4M Nasal/Ear Trimmer
My andis t hair trimmer doesnt work
hello. Chances are that the mechanism has rusted a wee bit. Get an aerosol can of WD-40 penetrating lubrication. Squirt some into the moving head and let it sit over night. Then turn it on. If it still doesn't work repeat the treatment. Joe
Mar 22, 2010 | Andis T-Outliner Hair Trimmer
Blades pull hair when cutting
Just make sure the blades are aligned precisely and make sure it is well oiled. It should be oiled after every use. I use WD40
Jul 17, 2009 | Remington HC-600 Hair Trimmer
Andis Outliner II Trimmers
look if the trimmer is pulling hair, its not lack of oil
its maybe the speed of the trimmer needs to be faster.
its the the plastic flat head skrew on the side.check if the blades separate easiley if theyt do sometimes that makes the trimmer pull hair to.there might be a little plate on the inside of the trimmer and its not holding the blades tight.adjust that not to tight though then the trimmer wont cut
Dec 06, 2007 | Andis Outliner II Hair Trimmer
Braun FreeControl 1775 Hair Trimmer Logo
56 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
