Question about Refrigerators
There is a black plastic tube that comes out of the back of my refigerator about half way between the top and bottom. It is leaking water where it comes out of the refrigerator. How can I repair the leak?
  • lewis2 Jun 28, 2008
    The black tube which drained water to the defrost pan was clogged with a slimey residue. I ran a small plastice pipe through the tube and rinsed with water. Thank you for your response.
    President:
  • 1,462 Answers
Remove tube, cut off half an inch and refit using sealant
Posted on Jun 19, 2008
  • douglas smith Jun 28, 2008
    good idea to put a small jug of dilute bleach down the drain inside the fridge now and again. keeps it clean and stops this fault
I have a LG GRL207QVJA Fridge Freezer and have a leak behind the water dispenser. How do I remove the control panel to get behind it so that I can replace the leaking tube?
Hello Adrian;
My name is Peter. I am a retired field service refrigeration technician.
You must be in the UK. I can not pull up any information on your unit, but I will try and walk you through this.
Hopefully the water leak is directly behind the dispenser. If you have water leaking out the bottom of the door, then you are going to have to replace the whole door. It water is leaking out of the bottom of the door then the insulation in the door is saturated. Over time the water in the door will freeze and crack you door liner open. There is no way to dry the insulation out. So, lets say this is not the case.
You either have a contact pad or a paddle arm in your dispenser housing. You may have a plastic curved piece at the top of the dispenser housing. It is held in by plastic clips. Squeeze this on both sides to release.
Up plug the refrigerator. Their are electrical components behind this housing. On the bottom of the housing frame are 2 small slots. With a flat head screw driver, pop the bottom of the housing out. On the sides and top of the frame are plastic clips. Push in on the sides of the frame to release. If you have a control board on the top back of the frame - remove the connectors. They are idiot proof. Each connector is designed to only fit a special plug. Set the frame assembly aside. You may have to remove a control board fixed to the housing, A contact switch housing and the housing itself. There are screws that go around the housing frame for removal.
On the bottom of the door there is a spring and a tubing connector. Push in on the end of the connector to release the tubing. You may have to remove a black locking ring on the connector first.
The tubing assembly you are replacing is available as a part.
Here is the hard part. Using a good adhesive tape, tape the top end of the new tubing to the bottom of the old tubing. Feed the tubing up from the bottom.
If you do not have slots on the bottom of the frame, you must push inward on the frame to release the frame from it plastic retaining clips.
Peter, Baltimore, Maryland, USA
Oct 31, 2014 | Refrigerators
2002 park avenue leaking water from tensioner replacement part?
I assume that you are talking about the black plastic tube that runs from the lower intake to the tensioner. There is another black plastic tube that goes out the bottom of the tensioner too. These have little O rings towards the ends. The plastic breaks at that point and when you remove the plastic tube you have to try to fish the end out. Both of these tubes come in a little container. I think that they are like 5 bux at oreillys. If you let them know what you are looking for, they usually have it out on the shelf.
Apr 06, 2013 | 2002 Buick Park Avenue
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Our coffeemaker leaks water from the bottom while brewing
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
May 17, 2010 | DeLonghi BCO120T Programmable Espresso /...
The coffee side has started leaking profusely from the top, back of the water area when brewing.
There is a red hose that connects at the back and top of the unit. Make sure the hose has not come undone and also check that the top lid with the holes is not blocked with coffee grounds. However, the most probable problems will be the hose otherwise you will mostly have steam coming out the back.
Hope this helps!
Dec 07, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
When it rains, there is water in the passenger side floor
I have a 2001 with the same problem. Solved it by taking off the wipers, remove both sides of the black plastic cowl, then remove the large bottom half of the plastic cowl. The leak is most likely where that cowl seals to the a/c air intake. Half a tube of black silicone fixed mine.
Dec 06, 2009 | 2001 Lincoln Town Car
MY WHER25 REV. OS. IS LEAKING AT THE HOLE IN THE BOTTOM OF THE SPOUT . i CHANGED THE FILTERS.. IT STILL LEAKED.. I CHECKED THE DRAIN GOING INTO THE P-TRAP .. IT WAS CLEAR .. PLEASE HELP
Remove the faucet spout and unscrew the screw keeping the white plastic piece on the bottom (of the faucet). It's where the red and black tubes enter. Pull out the white plastic with the tubes and clear it of debris (usually placed there when your disposal backs up the black tube, which serves as the filter's drain tube). Once it is cleared of debris, make sure the black rubber washer is back in place (it may be stuck in the faucet, so look for it) and replace the plastic, screw the screw back in, and secure the faucet again. I had this same problem and doing this solved it. Should take about 5 minutes or so. Good luck.
Dec 02, 2009 | Whirlpool Home
I am getting a message on the washer saying "HF" what those this mean?
google " duetservicemanual.pdf" I see an error code "FH", but nothing listed as "HF".
Nov 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE GTH18KBM Refrigerator, top freezer ice-over trouble
It sounds like there is an issue with the drain tube from the freezer to the compressor pan. If it is open at the bottom then it will allow warm moist air to form an ice plug in the tube which will not allow water to flow out during a defrost, this will gradually build up then stop the freezer from functioning normally. This will be shown by large formation of clear solid/layered ice. Alternately if it is plugged with some foreign object then it will end up doing the same thing. The next time you do a defrost verify that there is water coming out to the pan at the compressor if not the tube will have to be cleared. The best way is compressed air but not too much since this is just a plastic tube. the obstruction should be blown out the top.
There should be a small trap on the bottom of the drain tube kind of like the one under the kitchen sink if it is not there then you will have to either make one or get one from your local parts dealer.
Jul 28, 2008 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
