Question about Vacuums
How do you replace the handle release lever on the hoover windtunnel 6425-900
  • davedeb_harp
    davedeb_harp Feb 13, 2014
    The release lever is held in place by tabs molded into the base. You just need use a screwdriver or two to press the plastic tabs back and then push the release lever out. The new release lever can be just pushed into place and the plastic tabs will snap and hold it in place.
    New Friend:
Posted on Feb 13, 2014
5 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Hoover Self Propelled wind tunnel vacuum U6433-900
please go to thehooverstore on the web. they'll have an exploded diagram of how your machine goes together. I'm sure you'll find your solution there.
Posted on Sep 22, 2007
  • 294 Answers
SOURCE: Hoover windtunnel U5753-900 will not start
The most likely problem is the on off switch. but it could also be related to the motor or a connection.But definitely electrical in nature. suggest to take it in for service.
Posted on Mar 01, 2009
Vac Belts
  • 701 Answers
SOURCE: Hoover U6634-900 WindTunnel
You need to replace it periodically. Below I have listed a link to the belt you need and a link to the manual which has instructions.
Hoover U6634900 Replacement Belts
U6634900 Manual
Posted on Nov 03, 2009
SOURCE: The handle release lever (Part N. 38434-021) on my
You can buy Hoover Handle Release Lever 38434-021 at
http://partsreadyonline.com/item.php?ItemID=798
Posted on Jan 10, 2011
How to remove the hoover windtunnel handle release lever
Tilt the handle back and pry it out with a flat blade screwdriver.
Jan 23, 2013 | Hoover U6630-900 WindTunnel Bagless...
Hoover model U6425-920 falls backward
It sounds like the handle release lever is bad if the unit will not stand up. It's common when those units get a little older. It is unlikely you'll need the rear handle assembly (the part with the filter housing) but it does happen. Inspect the latch on the handle assembly to make sure it's not too worn to know for sure. Chances are, the handle release lever is just spent.
Here's the part you're looking for:
http://vacuummedic.com/product.php?id=171
As long as you're into it the belts and roller are always a great investment. Replacing them will make it clean like new again. I'll include the links for those parts as well.
Flat Belt:
http://vacuummedic.com/product.php?id=6
V-Belt:
http://vacuummedic.com/product.php?id=485
Brush:
http://vacuummedic.com/product.php?id=484
Happy Vacuuming!
The Vac Dr.
Dec 27, 2012 | Hoover Ultra U6430-900 WindTunnel Bagged...
Foot controlled handle release lever is broken. Where to get parts?
I had same problem - the foot release pedal would not spring into place when unit was upright (but would work if you nudged in place with your foot). I installed a replacement part, and it didn't fix the problem. I cut out a small sqare of sponge and jammed it behind the flat end of the bent plastic spring on the release pedal, and it now springs back as it shoud. Hope this helps.
Jan 11, 2010 | Hoover U6630-900 WindTunnel Bagless...
Just purchased the windtunnel T series pet version...I cannot turn the carpet height adjustment knob to save my life. Is it locked somehow? or is there a way to get it moving?
with the vacuum in the upright position push the handle foward then reach foward and slide the lever to the proper position that also works to ingauge the power drive or to release the handle thanks hope this helps Don the Vacuum Doctor Alb N.M.
Nov 01, 2009 | Hoover U5753-900 WindTunnel Bagless...
Stand up lever is plastic, broke when stepped on to release handle, can it be repaired, replaced with a better one, plastic breaks too easily?
The pedal release can be replaced but the base will need to be checked for cracks as well. if the base is broken most common is the socket the pedal release snaps into. some of the plastic parts have been made with better materials
Oct 20, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Foot latch is broken. need to replace with new one. how does one access to remove the foot pedal latch. By foot latch, I mean the foot lever that releases the upright to lower the handle and begin...
it is accessed from the bottom underneath by the rear wheel. However, If there are and cracks on the pedal release socket area then the base will need replacement. parts are little cost but the unit needs to be completely disassembled.
Oct 17, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
It does not stand up straight
the plastic locking mechanism to keep it upright is broken. It can be fixed, but not sure it is worth fixing. I know its a pain to lean it up against the wall all the time, but the cost for replacing the part is not worth the expense in my opinion. Good luck!
Jul 28, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Too much play in upright part of my Hoover upright wind tunnel
No. The handle release pedal is snapped into the bottom base assembly. Look underneath to check for cracks or damage in this area. this is the most likely issue. If it is, then the base will need to be repalced.
Jan 19, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Off/on switch does not work
The on/off switch in Hoover Windtunnel upright vacuum cleaners is operated by a lever in the handle assembly.  remove the two screws on the back ovf the vacuum and see if the lever has bypassed the switch assembly.  if so, re-assembly should fix the problem.  It is also possible that the switch activating lever has broken.  If so, replace the activating lever.
Oct 24, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
192 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
