Question about Samsung Digimax L730 Digital Camera
My camera was dropped on the floor and the lens are now pushed in on one side and the power will not go on. is it fixable?
    Brigadier General:
  • 11,967 Answers
Try these:
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 15, 2010
I dropped the camera and the zoom lens got off line. It won't close or go back in the camera. It looks stuck and I tried pushing it in but I'm afraid that I might push hard that it'll break...
The lens may be fixable but most likely will need to be replaced.
If the lens is stuck straight or won't come out at all it needs to be replaced.
If the lens is stuck at an angle then you may be able to snap it back to the center by pressing the edge of the lens back towards center while holding on the outer ring of the lens.
Hope this helps!
Thomas Drayton
Owner, www Darntoothysam com Digital Camera Repair
Jul 21, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
Dropped the Camera, Lens is stuck open
I already tried posting this but I think it falied. Just in case, here it is again!
I just now fixed my own Nikon S220 (very similar to 210) which suffered the same fate as yours. However, I laid my camera down on a cushioned foot-rest (you could use a couch cushion or pillow on a table) with the lens facing UP, pressed down on both sides of lens front gently yet firmly, and BAM, the lens went back in all the way. I turned the power back on and the camera is good as new (except for the small dent from the fall of course).
I suggest you try this before spending $100 on repairs and/or buying a new camera!
Sep 09, 2009 | Nikon Coolpix S210 Digital Camera
My neice's camera fell onto a tiled floor when the zoom lens was out and now it is bent and the camera doesn't turn on or off is this fixable?
Nope.. they are disposable.. My son worked in a camera store and that was the best "new purchase" feature, a dropped camera.
Jul 23, 2009 | Cameras
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Jammed lense
Take the batteries out and let it power down push the lens in slowly to reset the motor, then put the batteries back in this should clear the jam if not it will need to be taken to a camera shop.. Thanks Rulds2008 please rate me!!
May 14, 2009 | Kodak EasyShare V803 Digital Camera
Dropped camera!
Electronics goods are only for safe use. Not for droping, if it happens then go to purchase new one.
If it was in India, there was an option for repairing. Otherwise through it away.
Nov 29, 2008 | Casio Exilim EX-S600 Digital Camera
Cannon A70 lens stuck in middle causing it to keep powering off
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but if the camera is out of warranty they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 06, 2008 | Canon PowerShot A70 Digital Camera
Dropped camera lightly, lens wont retract
my acm dropped and i messed up the lsenes it wont go in please help me how can i fix it my self?
Nov 03, 2007 | Canon PowerShot A540 Digital Camera
Casio lens stuck
I noticed that the lens was sticking out on center. After pushing it a little, it clicked and then everything worked fine again. I hope that's what happens for your camera, too.
Jun 03, 2007 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Samsung Digimax L730 Digital Camera Logo
24 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
