Question about Samsung SyncMaster 740N 17" LCD Monitor
How to open the monitor lcd back cover - Samsung SyncMaster 740N 17" LCD Monitor
Just find the screws then loosen it, after that be careful to open the cover by using flat screws
Posted on Nov 15, 2010
Dead on arrival need to open back cover
emtv_satc852, First visit YOUTUBE and watch some of them being pried apart at their perimeters around the four edges. That's how most of them are opened. Some people use an old CD or DVD disk, while some use thin blade screwdrivers. Try "lcd monitor disassembly" or "lcd monitor repair" on YOUTUBE. Good luck. Hope this helped. 12fixlouie
Feb 25, 2010 | ViewSonic VX2433WM 23.6" Monitor
Ho w to open the emprex lm 2203 monitor
jerry932, If you still have problem removing back cover form the front bezel after viewing some of the longer, more detailed video clips at YOUTUBE under "LCD monitor dissassembly" and "LCD monitor repair" we will try to help you. Also try www.ccl-la.com/badcaps.htm for ideas on how to "get inside". Dam, I wonder why everybody on the planet wants to open up their monitor's? Is there a problem out there??? Wow!!
Bye for now. 12fixlouie
Feb 20, 2010 | Emprex LM2201 22" LCD Monitor
Why does my LG flatron 1953T LCD monitor (19') goes white
Because the fuse on scaler PCB is blown. Open the monitor, open metal cover, disconnect all cables coming between display and boards, take the chassis off the display.
On back side of display you will see metal cover, mounted with tiny screws, take them off. Unscrew the board also and carefully tilt it up. Observe tiny chip fuse (referenced F1 or FU1 or something with "F") somewhere nearby the connector, ring it, replace it with solder drop.
Take everything back together.
Sep 11, 2009 | LG Flatron L1750S 17" LCD Monitor
How i can to open the cover of lcd hp L1706
1.- remove 14 screw on back
2.- remove front cover con un desarmador plano pequeño, como si pucharas hacia afuera y luego al frente por toda la orilla.
3.- quitar la base es solo con un simple apreton y click y listo, sale la parte de abajo y luego aprietas la parte de arriba y estiras. y ahi vas a ver unas tuercas te puedes ayudar con una llave española o perica pequeña.
y listo.
Jul 22, 2009 | HP L1706 17" LCD Monitor
Open the back door
remove all screws at the back. and unlock all snap lock at the back cover.
May 30, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
How can i open the body or case to repair of hp
Please check first if your LCD monitor is still under Warranty period, if yes, then I recommend to bring the unit to authorized service center to properly diagnose & fix the problem, because if you open it yourself & probably broken its seal then the Warranty will be Void & other problem/s that may arise / found will no longer be covered by their free service / part replacement.
If no longer covered by a Warranty, then you can open it by yourself, by turning (counterclockwise) its lock screws to open its back cover & check the circuit board parts / connections if loose/broken/defective. regards
May 17, 2009 | HP f2105 21" LCD Monitor
Benq FP731 LCD not start up, only green power lamp
Opening it will not likely solve your problem. Have you tried another monitor on the computer to see if the problem may be with the computer itself?
Mar 04, 2009 | BenQ FP731 - 17" LCD Monitor
LCD Monitor
1st remove the base cover by by squeezing to release the clips and remove the 6 base mounting screws. 2nd remove the 5 screws in the back cover. 3rd push and pry at the parting line to release the clips. 4th remove the base mount by removing the two attaching screws and sliding it down about a quarter inch. 5th remove the steel cover by removing the 4 wires, two screws from power outlet, two bolts from vga plug, and the other screw in the cover. and there you have it.
Oct 26, 2008 | Acer AL1717 17" LCD Monitor
How to open the back cover of the LCD monitor
Hi..there,
It's seems you got a backling inverter busted. Need to replaced a new one or repaired it. To repaired you need to replaced a bad capacitors with a bulged on top of each caps. Not sure...just replaced all the caps...:) Ok! to open the back cover, there are 2 types to open it. First unscrew the 4 corner screws. If there are some... First type it from the back. After you had removed all the screws. Get a good grip on the bottom R/H side with both hands pulling as hard as you can on the 2 joints. 2nd type from the front bezel. Laid your monitor screen upward and placed a piece of clothes to proctect the screen from smudged. Used 2 hands to lifted up the edged of a bezel...do the same on the other side... After that just removed the screws...and that's how to open the front and back cover... Have a nice day!
Oct 13, 2008 | AOC LM729 17" LCD Monitor
Acer LCD (AL1917W)
After removing the back cover screws that you saw, ok, there is a screw under the stand holder. Remove the cover that covers the stand holder joints. you can remove it using a flat head screw driver, it is removeable only it appeares stuck to the back cover. After you unscrew, use flat head screw driver and carefully by pushing to the side of the LCD bend. Carefull you might break the cover. Good Luck.
Oct 03, 2008 | Acer AL1917W LCD Monitor
Samsung SyncMaster 740N 17" LCD Monitor Logo
306 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
