Question about Canon PIXMA MP600 all-In-One InkJet Printer
Canon mp600 error code 5110 - what is this and how do I fix it?
4 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: canon pixma mp600 error code 5100
try this solution..from fixmyprinter.com
This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 02, 2008
SOURCE: canon mp600 error 5110
i have the same problem anyone know what 5110 means???
Posted on Jul 20, 2008
hashchathy
  • 246 Answers
SOURCE: error code 5110..please help in my printer Mp600
try to reinstall the printer dirvers
Posted on Feb 13, 2009
What is the Canon MX850 Error Code 5110?
The paper goes in from the front, under the 'paper output' tray.
Feb 14, 2015 | Canon PIXMA Office Equipment & Supplies
It displays code 5110 what do i do
Movement of the Print Head Holder is blocked.
Clear the paper jam or foreign object that is preventing the Print Head Holder from moving. Cancel printing from your computer, then turn off the machine, and turn it back on again.
May 03, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 Printer - How do I fix error code 5100
Hi Whitey621
Error code 5100 Try
Solution 1:
Look inside for a tiny object like a piece of paper, a staple...
Solution 2:
There is a thin plastic strip running across the width in front of and below the drive belt: there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence.
Gently clean this strip with a damp lint-free tissue
Hope It Helps: Pineworks.
Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Error code 5110 Canon Pixma MP500
Error 5110 = Kann den Schlitten nicht anheben. (mechanischer Fehler)
Sep 28, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon mp600 error 5110
Jul 06, 2008 | Canon Office Equipment & Supplies
Canon Pixma MP600r - error code 5110
5110 ERREOR is carraige cant life. this can be down to a few things, carriage is stuck on the purge unit or the logic board is at fault. best to take it to a Canon dealer for repair or contact a supporter dealer who can do a chargeable call for you. in the uk i have few contacts . hope this helps
Dec 23, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma mp600
If its still under warranty send it back.
Solutions for error code 6800 Issue: Error code 6800 appears on the display (multifunction printers MFP)
1. Contact Canon for 6800 error - MP600 2. The MP600 may require repair
Oct 28, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
146 people viewed this question
old marine
old marine
