Question about Intel Server Board SE7505VB2 Motherboard
Hi, I am currently trying a fresh install of XP Pro on a retired server however I seem to be getting the BSOD before the first Windows setup window. The error code reads 0x0000007B which stands for inaccessable boot device. I have swapped the old cd drive for a new DVD-R/RW Pioneer DVR-S18LBK (sata), I am using a 40 GB HDD sata which has not been swapped. The BIOS has been configured correctly as the DVD drive is the boot device and has been sata enabled. I am unsure if the old cd drive was sata or not as the old owner kept it. The new DVD drive does come with a firmware DVD but obviously I can't install it without an OS. The HDD has already been formatted. Any ideas people ?
  • 16 Answers
SOURCE: Connecting an IDE HDD to a SATA port using an IDE to SATA converter
Not complete product...need to buy additional adapter for IDE to SATA power source.
IDE drive will have to have the power source hooked up as well as the adaptor hooked up.
Installing the adaptor only will not work. Your computer should have the 4 pin plug for the power to the IDE drive, other wise you will have to buy another adaptor.
Posted on Mar 23, 2008
SOURCE: BSOD on XP64 fresh install
Here is an picture of the Blue screen I am getting
A larger version of the image can be seen here:
http://www.pjbproductions.com/bsod.jpg
it's a bit out of focus but should be ledgible. I don't think it's seeing it in the BIOS either. I will confirm tonight when I get home from work.
Posted on Apr 09, 2008
SOURCE: Problem with DG31PR board while loading windows 2003 server.
you can use 2003 server service pack 2 &fix this problem
Posted on Dec 20, 2009
  • 26 Answers
SOURCE: inaccessable boot device
I really don't know what you mean. Give all the specs of your PC , please also make sure your HDD is not set in your BIOS to RAID, Set it to IDE Mode
Posted on Jun 08, 2010
ghost2233
  • 3606 Answers
SOURCE: I am unable to install
Hi, here you can find drivers and a manual:
http://www.asus.com/Motherboards/Intel_Socket_775/P5RD1VM/#download
Please select your operating system.
Then select the driver and click on global for download.
The driver needs to be unziped before installation.
Here is a free unzip program:
http://www.7-zip.org/download.html
Just click on exe for download.
Check your windows disk for damage or dirt.
And check the bios for faulty settings
read about that in the manual.
Posted on Aug 22, 2011
Hi, I have a HP NX6310 notebook with Win Xp Pro installed. I need to reformat it after it was heavily virused, and reinstall Win Xp but without the recovery disks I am rather helpless. The recovery...
You can't see any HDD's when trying to install because your BIOS system was set the IDE controller to an AHCI, you can set this to native IDE and windows XP setup will read a HDD's..
If you need set the IDE controller to AHCI you need Intel AHCI controller driver for your system, you can see it during installation process to press F6, you must use floppy diskette and put the driver onto it.
Another way to install AHCI driver is Integrate the driver into Windows Installation directory..See here for more details..
Aug 10, 2011 | HP Compaq nx6310 Notebook
My ksuser dll for windows xp profesional
Just boot from the xp professional cd and run the recovery console.
Download the operating system from this link: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
or
if you have it, install it using the procedure below:Boot From the Windows XP CD
  • You must boot from your XP . Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
    you will be asked to press any key to boot from CD, so do just that.
    Step 3: System repair steps
  • A blue screen will appear and will begin loading XP setup from the CD.
    simply let the CD load without pressing F6.
    Once completed, you will be confronted with "Windows Setup". You will be asked to setup up Windows, or repair Windows with the recovery console. Choose the FIRST option, NOT recovery console.
Choose F8 to continue.
  • Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP.
    If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts
Apr 19, 2011 | Microsoft Windows XP Professional
Haha! I deleted folders inside the Local Disk C:\Program files then after that the computer would always ask to restart it, every time I try starting it. Huhu Help, and these folders are not inside the...
or
  • If this solution helped Never go to drive C: again. Vote for this solution and rate it
Apr 18, 2011 | Computers & Internet
For key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install...
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose your o/s
now run it and presto......
regards, dean
Jan 08, 2011 | Keyspan USB Server US-4A (d47710) Print...
I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
Sep 08, 2010 | Keyspan USB Server US-4A (d47710) Print...
BSOD at start of Windows XP Setup
try F8 to got to the startup menu, and choose last known good configuration, use a ps2 keyboard or an adaptor and nothing that needs the USB.SYS Driver to function, and you should be able to reinstall Windows, if last known good configuration doesn't work, i hope this helps, please give good rating
Apr 30, 2009 | Computers & Internet
Bsod, error code:0x00000024, hdd problem booting xp os
Can you do this
Boot from the Windows XP CD.
Watch for a Press any key to boot from CD... message similar to the one shown above.
Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, simply reboot and try to boot to the Windows XP CD again.
When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console
Select your OS and enter password (if needed)
When you reach the command prompt type the following and then press Enter:
expand d:\i386\hal.dl_ c:\windows\system32\hal.dll
Using the expand command as shown above, d represents the drive letter assigned to the optical drive that your Windows XP CD is currently in. While this is most often d, your system could assign a different letter. Also, c:\windows represents the drive and folder that Windows XP is currently installed on. Again, this is most often the case but your system could be different.
If you're prompted to overwrite the file, press Y.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Apr 24, 2009 | Sony VAIO VGN-T170P/L Notebook
VPN Using XP Servers and D-Link WBR-2310
I had exactly the same problem. The solution is to set up pptp as a virtual server pointing to the lan ip of the server. Port forwarding only forwards the port but not the GRE protocol (pptp passthrough)
Jul 26, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
BSOD
Your MEMORY (RAMS) are damaged if you have memory in multiple **** remove the ones in **** 1 and replace them
Jul 07, 2008 | Microsoft Windows Server Standard 2003 for...
Intel Server Board SE7505VB2 Motherboard Logo
51 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
